Discuss
Whirlpool Duet Washer
 in
Washer Repair
My Duet Washer display panel reads F 6 and does not dispense the fabric softener or the bleach. What could
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool Duet Washer
  #1 (permalink)
Old 11-17-2009, 05:54 PM
KAREN COX KAREN COX is offline
Junior Member
KAREN COX is on a distinguished road
Default Whirlpool Duet Washer
Model Number: GHW9150PW4   Brand: Whirlpool   Age: 1 - 5 years
My Duet Washer display panel reads F 6 and does not dispense the fabric softener or the bleach. What could the problem be?
Related Models
Whirlpool GHW9150PW4 Automatic Washer
Whirlpool GHW9160PW0 Automatic Washer
Whirlpool GHW9160PW1 Automatic Washer
Whirlpool GHW9160PW2 Automatic Washer
Whirlpool GHW9160PW3 Automatic Washer
Whirlpool GHW9160PW4 Automatic Washer
Whirlpool GHW9200LQ0
Whirlpool GHW9200LW0
Whirlpool GHW9250ML0 Automatic Washer
Whirlpool GHW9250ML1 Automatic Washer
Whirlpool GHW9250ML2 Automatic Washer
Whirlpool GHW9250MQ0 Automatic Washer
Whirlpool GHW9250MQ1 Automatic Washer
Whirlpool GHW9250MQ2 Automatic Washer
Whirlpool GHW9250MT0 Automatic Washer
Whirlpool GHW9250MT1 Automatic Washer
Whirlpool GHW9250MT2 Automatic Washer
Whirlpool GHW9250MW0 Automatic Washer
Whirlpool GHW9250MW1 Automatic Washer
Whirlpool GHW9250MW2 Automatic Washer
Whirlpool GHW9300PW0 Automatic Washer
Whirlpool GHW9300PW1 Automatic Washer
Whirlpool GHW9300PW2 Automatic Washer
Whirlpool GHW9300PW3 Automatic Washer
Whirlpool GHW9300PW4 Automatic Washer
Whirlpool GHW9400PL0 Automatic Washer
Whirlpool GHW9400PL1 Automatic Washer
Whirlpool GHW9400PL2 Automatic Washer
Whirlpool GHW9400PL3 Automatic Washer
Whirlpool GHW9400PL4 Automatic Washer
Whirlpool GHW9400PT0 Automatic Washer
Whirlpool GHW9400PT1 Automatic Washer
Whirlpool GHW9400PT2 Automatic Washer
Whirlpool GHW9400PT3 Automatic Washer
Whirlpool GHW9400PT4 Automatic Washer
Whirlpool GHW9400PW0 Automatic Washer
Whirlpool GHW9400PW1 Automatic Washer
Whirlpool GHW9400PW2 Automatic Washer
Whirlpool GHW9400PW3 Automatic Washer
Whirlpool GHW9400PW4 Automatic Washer
Whirlpool GHW9400SU0 Automatic Washer
Whirlpool GHW9460PL0 Automatic Washer
Whirlpool GHW9460PL1 Automatic Washer
Whirlpool GHW9460PL2 Automatic Washer
Whirlpool GHW9460PL3 Automatic Washer
Whirlpool GHW9460PL4 Automatic Washer
Whirlpool GHW9460PW0 Automatic Washer
Whirlpool GHW9460PW1 Automatic Washer
Whirlpool GHW9460PW2 Automatic Washer
Whirlpool GHW9460PW3 Automatic Washer
Whirlpool GHW9460PW4 Automatic Washer
Whirlpool GHWT160JXX0
Whirlpool GI1500PHB0
Whirlpool GI1500PHB3
Whirlpool GI1500PHB4 Ice Cube Maker
Whirlpool GI1500PHB5 Ice Cube Maker
Whirlpool GI1500PHB6 Ice Cube Maker
Whirlpool GI1500PHB7 Ice Cube Maker
Whirlpool GI1500PHB8 Ice Cube Maker
Whirlpool GI1500PHW0
Whirlpool GI1500PHW3
Whirlpool GI1500PHW4 Ice Cube Maker
Whirlpool GI1500PHW5 Ice Cube Maker
Whirlpool GI1500PHW6 Ice Cube Maker
Whirlpool GI1500PHW7 Ice Cube Maker
Whirlpool GI1500PHW8 Ice Cube Maker
Whirlpool GI1500XHB0
Whirlpool GI1500XHB1
Whirlpool GI1500XHB2
Whirlpool GI1500XHB3
Whirlpool GI1500XHB4 Ice Cube Maker
Whirlpool GI1500XHB5 Ice Cube Maker
Whirlpool GI1500XHB6 Ice Cube Maker
Whirlpool GI1500XHB7 Ice Cube Maker
Whirlpool GI1500XHB8 Ice Cube Maker
Whirlpool GI1500XHB9 Ice Cube Maker
Whirlpool GI1500XHN0
Whirlpool GI1500XHN1
Whirlpool GI1500XHN2
Whirlpool GI1500XHN3
Whirlpool GI1500XHN4 Ice Cube Maker
Whirlpool GI1500XHS0
Whirlpool GI1500XHS1
Whirlpool GI1500XHS2
Whirlpool GI1500XHS3
Whirlpool GI1500XHS4 Ice Cube Maker
Whirlpool GI1500XHS5 Ice Cube Maker
Whirlpool GI1500XHS6 Ice Cube Maker
Whirlpool GI1500XHS7 Ice Cube Maker
Whirlpool GI1500XHS8 Ice Cube Maker
Whirlpool GI1500XHS9 Ice Cube Maker
Whirlpool GI1500XHT1
Whirlpool GI1500XHT2
Whirlpool GI1500XHT3
Whirlpool GI1500XHT4 Ice Cube Maker
Whirlpool GI1500XHT5 Ice Cube Maker
Whirlpool GI1500XHT6 Ice Cube Maker
Whirlpool GI1500XHT7 Ice Cube Maker
Whirlpool GI1500XHT8 Ice Cube Maker
Whirlpool GI1500XHT9 Ice Cube Maker
Whirlpool GI1500XHW0
Whirlpool GI1500XHW1
Whirlpool GI1500XHW2
Whirlpool GI1500XHW3
Whirlpool GI1500XHW4 Ice Cube Maker
Whirlpool GI1500XHW5 Ice Cube Maker
Whirlpool GI1500XHW6 Ice Cube Maker
Whirlpool GI1500XHW7 Ice Cube Maker
Whirlpool GI1500XHW8 Ice Cube Maker
Whirlpool GI1500XHW9 Ice Cube Maker
Whirlpool GI15NDXTB0 Ice Cube Maker
Whirlpool GI15NDXTB1 Ice Cube Maker
Whirlpool GI15NDXTQ0 Ice Cube Maker
Whirlpool GI15NDXTQ1 Ice Cube Maker
Whirlpool GI15NDXTQO Ice Cube Maker
Whirlpool GI15NDXTS0 Ice Cube Maker
Whirlpool GI15NDXTS1 Ice Cube Maker
Whirlpool GI15NFLTB0 Ice Cube Maker
Whirlpool GI15NFLTB1 Ice Cube Maker
Whirlpool GI15NFLTBO Ice Cube Maker
  #2 (permalink)
Old 11-19-2009, 04:23 PM
sidfink43 sidfink43 is offline
Senior Expert
APP Volunteer
sidfink43 is on a distinguished road
Default
Hi Karen
This is one of those error codes that tells you nothing. The official explanation is that the central control unit is not getting info from the motor that the machine is working, but then you already know that.
I would try a couple of things.
1. Take off the lower panel and clean out the drain hoses and pump.
2. Check for a wiring problem between the control unit and the door assembly and the motor.
After you do this leave the machine unplugged for a while and see if itg clears out the error.
If none of this does the trick you are looking at changing out the door lock assembly or central control unit on speculation, which is a costly way to have to repair something, but that is the world of micro processor controls.
Here is a service manual for your machine.
https://secured.whirlpool.com/Servic...0Job%20Aid.pdf
Good luck, hope this helps.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool duet washer catrat Washer Repair 0 02-24-2010 09:02 AM
whirlpool duet washer catrat Washer Repair 0 02-10-2010 04:18 PM
whirlpool duet washer misterfixall Washer Repair 1 06-27-2009 05:53 PM
Whirlpool Duet HT Washer PeterMNelson Dishwasher Repair 0 05-09-2008 03:36 PM
Whirlpool Duet Washer jimgosnell Washer Repair 1 01-18-2008 01:17 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
