Discuss
Matag LA512 will not rinse
 in
Washer Repair
I had to remove the top of the inner tub to get a small sponge that had gotten between the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Matag LA512 will not rinse
  #1 (permalink)
Old 08-16-2007, 08:40 PM
battersh battersh is offline
Junior Member
battersh is on a distinguished road
Default Matag LA512 will not rinse
Model Number: LA512   Brand: Maytag   Age: 5 - 10 years
I had to remove the top of the inner tub to get a small sponge that had gotten between the inner and outer tub and blocked the drain. After I put the washer back together it will not fill to rinse. It fill and goes through the wash cycle okay. When it reaches the rinse cycle, the pointer on the switch just quits moving. If you move the switch manually and turn it on through the rinse cycle, nothing happens. If you move it into the spin cycle, it begins to spin. Any suggestions?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-16-2007, 09:28 PM
ApplianceJunk's Avatar
ApplianceJunk ApplianceJunk is offline
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
Did you unplug any wires?
How about the lid switch?
__________________
You can Repair your Appliance & we can help with our Appliance Repair Forum and Appliance Repair Blog.
  #3 (permalink)
Old 08-16-2007, 10:51 PM
magician59 magician59 is offline
Senior Expert
APP Volunteer
magician59 is on a distinguished road
Default Maytag La512
Sounds like a timer problem to me.
  #4 (permalink)
Old 08-17-2007, 04:19 AM
Junior Member
Default
I did not unplug any wires. I checked them an cannot find any that might have been knocked loose.
  #5 (permalink)
Old 08-19-2007, 05:38 AM
Junior Member
Default
The problem turned out to be that I had turned off the cold water to fix a leak and not turned it back on. The rinse uses cold water. I would like to add than when replacing the inner tub top, be certain to clean the area where the seal goes very well or you will some leaks.
  #6 (permalink)
Old 08-19-2007, 06:55 AM
Senior Expert
APP Volunteer
Default
Thats great!
Thanks for the update..
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer keeps repeating the rinse cycle hiltonacres Washer Repair 2 12-13-2007 08:22 PM
Washer thumps in wash and rinse stevepowell Washer Repair 1 08-14-2007 10:14 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
