donk95023
#1 Posted : Monday, November 16, 2009 1:26:25 PM(UTC)
donk95023
During the spin cycle of my whirlpool wtw6600sw2, it emits a loud bearing howl type noise that is getting louder by the day. I had a repair service check it, which consisted of putting the machine into spin/drain and listening to it. he says it is a main drive bearing. In looking at the schematics of this machine, it does not show any bearings on the drum. Does this sound familiar for this model, and what part is really the issue? Also, it seems to get off balance easy, I have never had a code occur.
thanks.
sidfink43
#2 Posted : Wednesday, November 18, 2009 6:13:57 AM(UTC)
sidfink43
To diagnose something like this we really need to be there, listen to the noise and then tear down the machine. I am thinking the Tech did not want to get involved with your model, (it is a much more complicated machine than a traditional top loader) and just wanted to get out of there. That's not the way you diagnose a problem like yours with a machine like yours.
I am guessing the problem is in the hub components, but you are going to have to open up the machine to check things out. You might also have a problem with the drain pump, filter or something caught in the mechanism.
Here is a service manual
https://secured.whirlpoo...540a8f/$FILE/8178582.pdf
Good Luk.
