| » eb2 error code |
Model Number: atf7000ep0 Brand: Frigidaire Age: 1 - 5 years
I'm getting a eb2 error code on my washer. The code states volts are above 130. I checked the outlet and it's right at 120. any advise?
Measure the voltage under the load (with the washer plugged in and running). Also keep in mind that it go up and down sporadically. It's always a good idea to install a surge protector for any computerized appliance.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
I tried it under a load and the highest it got was 120.6 volts. It will run for about 5 minutes and then it just kinda trips out. it will turn off and on and beep, and the door lock will click on and off. I'm thinking it might be the control board.
Sorry for the delay. If there is nothing wrong with the incoming voltage, then you are right - the control board is the culprit.
- The control board Part number: AP3900211 Here are the breakdown diagrams and Replacement parts for FRG ATF7000EP0 | AppliancePartsPros.com Gene.
__________________
| Display Modes | |
| error code 40 | kimbrecht69@hotmail.com | Oven Repair (including Ranges and Cooktops) | 1 | 11-03-2010 12:07 AM |
| frigidaire error code F10 - not listed in your error codes | Skully26 | Oven Repair (including Ranges and Cooktops) | 2 | 02-16-2010 04:29 AM |
| GE error code F3 | Mako | Oven Repair (including Ranges and Cooktops) | 20 | 04-10-2008 09:03 PM |
| F33 error code | daphil | Washer Repair | 1 | 03-27-2008 06:02 PM |
| error code f13 | banks | Oven Repair (including Ranges and Cooktops) | 1 | 01-17-2008 11:11 AM |
