Discuss
F1 code Kenmore elite oasis toploading washer
 in
Washer Repair
My kenmore elite oasis toploading washer recently started giving an F1 code. If I push stop and then start a
Appliance Repair Forum > Appliance Repair Help > Washer Repair » F1 code Kenmore elite oasis toploading washer
  #1 (permalink)
Old 11-16-2009, 10:18 AM
Junior Member
JuliaD is on a distinguished road
Default F1 code Kenmore elite oasis toploading washer
Model Number: 110.27087602   Brand: Kenmore   Age: 1 - 5 years
My kenmore elite oasis toploading washer recently started giving an F1 code. If I push stop and then start a few times, I can get it to go. First thing I did to troubleshoot was to replaced the hoses. I still get F1. I saw in a blog that I may need to replace the electronic control board. There are 2 in this machine, part AP3919482 and AP4360738. Which one do i need? Thanks. Julia
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 11-17-2009, 04:48 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Hi Julia
That error message is for the machine/motor control board. Just to avoid confusion and possible error I suggest you call in the order to APP.
Here is a service manual (Whirlpool makes your machine) if you need it which will show you how to change it out.
https://secured.whirlpool.com/Servic...LE/8178582.pdf
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
help with kenmore elite oasis washer tdavid64 Washer Repair 9 01-01-2010 03:05 PM
F1 on Kenmore Elite Oasis easyrider812 Washer Repair 4 10-05-2009 10:01 AM
kenmore clothes washer, elite/ oasis wapiwulo Washer Repair 1 09-23-2009 09:59 AM
Kenmore Elite Oasis HE Washer bap2523 Washer Repair 0 09-09-2009 06:07 AM
Kenmore Elite Oasis: no light jkok2000 Washer Repair 0 03-05-2008 03:04 PM
