| » will not go to high speed rinse cycle clothes are still wet |
Model Number: MAH3000AWW Brand: Maytag Age: 5 - 10 years
I have a maytag neptune clothes washer for some reason the machine will not go to the speed spin cycle at the end of wash. I have already checked to make sure it is level,checked drain pumpand hose for blockage, performed a R11/Q6 repair to the control board. After I did the R11/Q6 repair now and then it would goto the speed rinse cycle, sometimes I would have to turn the dial to the spin cycle two orthree times to extract water now it never goes to the spin cycle . whats next thank you
Related Models |
You may have blown out the board again if you failed to replace the wax motor!
Info for this is at www.neptunewaxmotor. com
__________________
when I did the r11 q6 repair it camewith the waxmotor ,door light bulb. Ater I performed this R11/Q6 repair it would go to the spin cycle probably every other load, sometimes I would turn the dial back spin cycle and I could get it to extract water. Now I have noticed when the wash cycle is complete ,door locked light is off,on light is off,delay light is off when I turn the dial depending on where Im at on dial It will start adding water It acts as if it never shut off.I checked R11/Q6 they look to be good. thanks again for help
You may have messed the board up when you repaired it, these are very dense boards. Also it contains a few other triacs that can fail.
Go to web site Maytag No Spin Problem - Alternate Solution - Appliance Blog Forums to get an elcheapo repair! Please post your results.
__________________
I bought mine at Radio Shack. I think I got two 100 ohm resistors and will stick them in series. I think they where 5 watt each. Or get two 400 ohm resistors at 5 watt each, stick them in parallel.
__________________
- Last edited by richappy : 03-10-2008 at 03:03 AM. |
hi again I have my 200 ohm 10 watt resistor, I understand I need to connect 1 end of the resistor to the P7-4, the other end needs to connect to the black wire on start/stop switch theres two black wires going to one terminal however there is some kind of resistor between two terminals on that switch which is smaller gauge wire with black casing. If its the two black do I tie into one or both looks to be one might go to dial not sure where other goes to. thanks again for help
| Display Modes | |
| Dishwasher skips the wash cycle and stops at the rinse cycle | jasporo | Dishwasher Repair | 6 | 06-08-2009 05:11 PM |
| Tub on spin cycle loosing its speed | rishat | Washer Repair | 3 | 02-15-2008 08:17 PM |
| Runs rinse cycle all the way through the spin cycle | hebirdseye | Washer Repair | 1 | 01-20-2008 06:10 PM |
| Gentle cycle/slow spin speed problem | WFH | Washer Repair | 1 | 01-19-2008 09:17 PM |
| clothes wet after spin,does not seem to come up to full speed | geno d | Washer Repair | 1 | 12-03-2007 03:34 PM |
