Busted the timer knob off and am trying to replace. Can't figure how to get inside the control panel. Thanks, Bill
Hi Bill
If you will gently slide a thin putty knife under the control panel assembly near the edges you will be able to release clips which hold it to the top of the cabinet.
It make take a little time and patience, but that should do it for you.
Good luck.
