tjmerker
#1 Posted : Saturday, November 14, 2009 4:16:07 PM(UTC)
tjmerker
After changing the drive coupling, I have blown 2 capacitors. I can't figure out why. Machine agitates and spins fine. The capacitor starts to smoke and blows.
Can anyone help?
#2 Posted : Sunday, November 15, 2009 3:46:16 AM(UTC)
Controls and rear panel replacement parts for WHIRLPOOL GSW9650LW0 | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/d...0Sheet%20-%203955503.pdf
And here is some basic unit repair info
https://secured.whirlpoo...2007475cb/$FILE/L-55.pdf
Could be the centrifugal switch is not opening.
May also be a bad start winding.
tjmerker
#3 Posted : Sunday, November 15, 2009 10:22:51 AM(UTC)
tjmerker
I can here motor humming also. Does that make any difference? Also, the 1st capacitor actually blew up. The 2nd one only kinda whistled and I cut power. Is the 2nd capacitor shot now?
#4 Posted : Monday, November 16, 2009 7:01:15 AM(UTC)
If it is humming it is trying to start but cannot could be the start winding is shorted to the frame or another winding.
Probably
tjmerker
#5 Posted : Tuesday, November 17, 2009 3:49:18 PM(UTC)
tjmerker
Thanks or your help..I just called in a favor with an appliance sevice chain that I insure and he said its the start winding in the motor. Probably went bad working overtime from the bad drive coupler which started this mess!
Thanks again Denman
