v mal
#1 Posted : Friday, November 13, 2009 6:52:40 AM(UTC)
v mal
the water dosn't shut off and it overflows and gets the floor wet
sidfink43
#2 Posted : Saturday, November 14, 2009 3:13:11 PM(UTC)
sidfink43
If it will not shut off when you shut off the machine you will need to replace your inlet valves.
If it does shut off when you shut off the machine it is likely the tube from the tub to the water pressure switch is obstructed or off, or the switch itself is faulty.
If you want more info please post your full model number and the results of checking what is stated above.
Water overflows ice maker and freezes on bottom. (Refrigerator & Freezer Repair)
by Kimlu 6/4/2016 8:43:37 AM(UTC)
Icemaker water overflows (Refrigerator & Freezer Repair)
by Capro22340 3/31/2011 2:25:01 PM(UTC)
Icemaker - water overflows during filling cycle (Refrigerator & Freezer Repair)
by BobW484 7/15/2010 11:45:22 AM(UTC)
Water Overflows (Washer Repair)
by COUNTRTAZ 5/31/2010 10:06:33 AM(UTC)
Water Overflows And Doesn't Stop On Fill Up (Washer Repair)
by GTA17 4/18/2010 1:14:58 PM(UTC)
by ChickenShack 4/6/2010 10:31:03 AM(UTC)
Water overflows; won't shut off. (Washer Repair)
by sstankss 1/18/2010 6:47:32 AM(UTC)
Water overflows when heavy loads are washed (Washer Repair)
by slgusta 12/26/2008 3:44:31 PM(UTC)
water overflows (Washer Repair)
by roadking666 10/21/2008 3:26:17 PM(UTC)
cold water overflows (Washer Repair)
by notsure 9/5/2007 10:48:47 AM(UTC)
