| » Washer Slow Fill |
Model Number: MAH4000AWW Neptune Brand: Maytag Age: More than 10 years
My Maytag Neptune fills very slow on the wash and Rinse 1 and Rinse 2. No difference between hot and cold cycles. It frequently stops mid-fill on Wash Cycle and in Rinse Cycle and has to be restarted. On Rinse 3, which is fabric softener, the water flow is much greater. I have checked the hoses and filters and no clogs. If the problem was clogged hoses or filters then I wouldn't get normal flow on Rinse 3.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Have you cleaned it at this time? Have you do it in accordance with the manufacturer instructions?
Otherwise the problem can be a clogged screens in the inlet water valve (where the inlet hoses are connected to). - The water inlet valve Part number: AP4027591 Here are the breakdown diagrams and Replacement parts for MAYTAG MAH4000AWW | AppliancePartsPros.com Gene.
__________________
Have cleaned both hose screens and found nothing in the Hot water screen but found alot of rust pieces in the Cold water screen. After cleaning the screen, replacing it into the hose end, the cold water flowed flawlessly as one would expect from the hose. As soon as the hose is connected to the machine the cold water continues to flow in a trickle. What could cause this in the machine to choke off the water. We cannot get anything less than a hot water use out of this. Have owned same machine as new and it's atleast over 5yrs. old. Could this be the Water Flow valve located where the water hoses attach to the washer ?
Any help is appreciated & welcomed, bikemannc |
Yes, it can be a bad or clogged water inlet valve. You may want to replace it.
- The water inlet valve Part number: AP4028726 Here are the breakdown diagrams and Replacement parts for MAYTAG MAV6250AWW Washer, Atlantis | AppliancePartsPros.com Gene.
__________________
| Display Modes | |
| Washer Slow Fill On Cold | sdrtgr | Washer Repair | 4 | 04-03-2012 05:46 PM |
| Slow fill | William Wittman | Washer Repair | 1 | 09-23-2009 06:33 AM |
| Maytag topload washer slow to fill | allie33 | Washer Repair | 1 | 04-20-2009 11:05 AM |
| maytag washer wiil fill slow on spin cycle | sancortez | Washer Repair | 0 | 04-11-2008 06:34 PM |
| Washer is slow to fill | Dbowls | Washer Repair | 1 | 08-30-2007 02:22 PM |
