Discuss
washer leaks water
 in
Washer Repair
washer leaks water from tub above the transmission Ads By Google Related Models Frigidaire  FWX233RES4  Frg(v0) / Washer Frigidaire  FWX233RES5
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer leaks water
  #1 (permalink)
Old 02-27-2008, 08:12 AM
Junior Member
watson-1 is on a distinguished road
Default washer leaks water
Model Number: FWX233RES4   Brand: Frigidaire   Age: 5 - 10 years
Ads By Google
Related Models
Frigidaire FWX233RES5 Frg(v0) / Washer
Frigidaire FWX233RES6 Frg/washer
Frigidaire FWX233RES7 Washer - Frigidaire
Frigidaire FWX233RET0 Frg(v0) / Free Standing Washer
Frigidaire FWX233RET1 Frg/washer
Frigidaire FWX414RGS0 Frg(v0) / Free Standing Washer
Frigidaire FWX414RGS1 Washer - Frigidaire
Frigidaire FWX433RBS0 Frg(v1) / 27 " Washer
Frigidaire FWX433RBS1 Frg(v1) / 27 " Washer
Frigidaire FWX433RBS2 Frg(v3) / Washer
Frigidaire FWX433RBS3 Frg(v1) / Washer
Frigidaire FWX433RBS4 Frg(v1) / Washer
Frigidaire FWX433RBS5 Frg(v1) / Washer
Frigidaire FWX433RBT0 Frg(v2) / 27 " Washer
Frigidaire FWX433RBT1 Frg(v2) / 27 " Washer
Frigidaire FWX433RBT2 Frg(v4) / Washer
Frigidaire FWX433RBT4 Frg(v2) / Washer
Frigidaire FWX433RBT5 Frg(v2) / Washer
Frigidaire FWX435RHS0 Frg(v0) / Washer
Frigidaire FWX435RHS1 Washer - Frigidaire
Frigidaire FWX435RHT0 Frg(v0) / Washer
Frigidaire FWX435RHT1 Washer - Frigidaire
Frigidaire FWX445LBS0 Frg(v1) / 27 " Washer
Frigidaire FWX445LBS1 Frg(v1) / 27 " Washer
Frigidaire FWX445LBS2 Frg(v1) / Washer
Frigidaire FWX445LBS3 Frg(v2) / Washer
Frigidaire FWX445LBS4 Frg(v0) / Washer
Frigidaire FWX445NBS0 Frg(v2) / 27 " Washer
Frigidaire FWX445NBS1 Frg(v2) / 27 " Washer
Frigidaire FWX445NBS2 Frg(v3) / Washer
Frigidaire FWX445NBS3 Frg(v2) / Washer
Frigidaire FWX445NBS4 Frg(v0) / Washer
Frigidaire FWX445RFS0 Frg(v1) / Washer
Frigidaire FWX445RFS1 Frg(v1) / Washer
Frigidaire FWX445RFS2 Frg(v1) / Washer
Frigidaire FWX445RFS3 Frg(v1) / Washer
Frigidaire FWX445RFS4 Frg(v1) / Free Standing Washer
Frigidaire FWX445RFS5 Washer - Frigidaire
Frigidaire FWX445RFT0 Frg(v2) / Washer
Frigidaire FWX445RFT1 Frg(v2) / Washer
Frigidaire FWX445RFT2 Frg(v2) / Washer
Frigidaire FWX445RFT3 Frg(v2) / Washer
Frigidaire FWX445RFT4 Frg(v2) / Free Standing Washer
Frigidaire FWX645DBD0 Frg(v2) / 27 " Washer
Frigidaire FWX645DBD1 Frg(v1) / 27 " Washer
Frigidaire FWX645DBW0 Frg(v1) / 27 " Washer
Frigidaire FWX645DBW1 Frg(v2) / 27 " Washer
Frigidaire FWX645GES0 Frg(v0) / Washer
Frigidaire FWX645GES1 Frg(v0) / Washer
Frigidaire FWX645LBS0 Frg(v1) / 27 " Washer
Frigidaire FWX645LBS1 Frg(v0) / 27 " Washer
Frigidaire FWX645LBS2 Frg(v4) / Washer
Frigidaire FWX645LBS3 Frg(v3) / Washer
Frigidaire FWX645LBS4 Frg(v1) / Washer
Frigidaire FWX645LBT2 Frg(v5) / Washer
Frigidaire FWX645LBT4 Frg(v2) / Washer
Frigidaire FWX645NBS0 Frg(v1) / 27 " Washer
Frigidaire FWX645NBS1 Frg(v1) / 27 " Washer
Frigidaire FWX645NBS2 Frg(v2) / Washer
Frigidaire FWX645NBS3 Frg(v0) / Washer
Frigidaire FWX645NBT0 Frg(v2) / 27 " Washer
Frigidaire FWX645NBT1 Frg(v2) / 27 " Washer
Frigidaire FWX645NBT2 Frg(v3) / Washer
Frigidaire FWX645RFS0 Frg(v0) / Washer
Frigidaire FWX645RFS1 Frg(v0) / Washer
Frigidaire FWX6968HW0 Frg(v0) / Washer
Frigidaire FWX6970EW0 Frg(v0) / Washer
Frigidaire FWX6970EW1 Frg(v0) / Washer
Frigidaire FWX6970EW2 Frg(v0) / Washer
Frigidaire FWX6970EW3 Frg(v0) / Washer
Frigidaire FWX6970EW4 Frg/washer
Frigidaire FWX6970EW5 Frg(v0) / Washer
Frigidaire FWX6971EW0 Frg(v0) / Washer
Frigidaire FWX6971EW1 Frg(v0) / Washer
Frigidaire FWX6971EW2 Frg(v0) / Washer
Frigidaire FWX6975EW0 Frg(v0) / Washer
Frigidaire FWX6975EW1 Frg(v0) / Washer
Frigidaire FWX6975EW2 Frg(v0) / Washer
Frigidaire FWX833AS0 Washer - Frigidaire
Frigidaire FWX833AS1 Washer - Frigidaire
Frigidaire FWX833AS2 Frigidaire/washer
Frigidaire FWX833AS3 Frigidaire/washer
Frigidaire FWX833MAS0 Frigidaire/washer
Frigidaire FWX833SAQ0 Washer - Frig/gallery
Frigidaire FWX833SAS0 Washer - Frig/gallery
Frigidaire FWXB23RGS0 Frg(v0) / Washer
Frigidaire FWXB45RGS0 Washer - Frig/best Buy
Frigidaire FWXB45RGS1 Washer - Frig/best Buy
Frigidaire FWY833KAS0 Frigidaire/washer
Frigidaire FWY833KCS0 Frigidaire/washer
Maytag G Range - S/c F/s Gas
Hardwick G-433 Surface Unit - Ele
Hardwick G-436 Surface Unit - Ele
Hardwick G-445 Surface Unit - Ele
Jenn-Air G0206B-8 Electric Grill Outdoor
Jenn-Air G100 Surface Unit - Ddraft Ele
Jenn-Air G101 Surface Unit - Ddraft Ele
Jenn-Air G102 Surface Unit - Ddraft Ele
Jenn-Air G103 Surface Unit - Ddraft Ele
International G1110PRA Range - F/s Std Gas
International G1110PRW Range - F/s Std Gas
Frigidaire G12W
Frigidaire G15W
Frigidaire G18W
Frigidaire G21CL0 Frg(v1) / Gas Range
Frigidaire G21CW0 Frg(v2) / Gas Range
Frigidaire G21CW2 Frg(v1) / Gas Range
Frigidaire G21CW3 Frg(v2) / Gas Range
Frigidaire G21PCL0 Frg(v1) / Gas Range
Frigidaire G21PCL1 Frg(v3) / Gas Range
Frigidaire G21PCL3 Frg(v2) / Gas Range
Frigidaire G21PCL4 Frg(v2) / Gas Range
Frigidaire G21PCL5 Frg(v4) / Gas Range
Frigidaire G21PCW0 Frg(v2) / Gas Range
Frigidaire G21PCW1 Frg(v4) / Gas Range
Frigidaire G21PCW3 Frg(v1) / Gas Range
Frigidaire G21PCW4 Frg(v1) / Gas Range
Frigidaire G21PCW5 Frg(v3) / Gas Range
Frigidaire G22W
  #2 (permalink)
Old 02-28-2008, 10:40 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Most likely the central seal (#26 on the transmission break down diagram) and the bearing (#26 on the motor/tub break down diagram) have to be replaced.
- The part number for the central seal is AP2142342
- The part number for the bearing is AP2131587
Here are the break down diagrams for the Frigidaire washer Model FWX233RES4
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 03-03-2008, 05:17 PM
Junior Member
RicardofromPR is on a distinguished road
Default Water leak problem
Hi, I'm having the same problem with my Maytag (PAV3300AWW), undecisive on which part to purchase for the problem. Please help. Need part number.
  #4 (permalink)
Old 03-03-2008, 08:28 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Ricardo,
What exactly is wrong with your washer?
Post it as a new thread, please.
__________________
  #5 (permalink)
Old 03-04-2008, 12:02 PM
Junior Member
Default Re:Water leak.
In rinse cycle, tub collects water fine, turns really slow, and visual leak between tub and top part of what I believe to be the transmission. I'm understanding that the part that I need for this is tub and seal kit
# 35-2974. Is this correct?
Hi Ricardo,
  #6 (permalink)
Old 03-04-2008, 01:03 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
In order to fix this leak you have to replace the tub and seal kit.
The kit comes with the complete instructions and to do the job right you need a few special tools.
- The part number for the tub and seal kit is AP3875413
- The part number for the spring removal tool is AP3854720
- The part number for the seal nut is AP3873487
- The part number for the spanner wrench is AP3854730
Here are the break down diagrams for the Maytag washer Model PAV3300AWW
__________________
  #7 (permalink)
Old 03-18-2008, 02:01 PM
Junior Member
Default Part for another machine
Hi Gene, it's me again, I apologize for bothering so much. Would you know the part number for the ball bearings of the transmission of a Frigidaire Model #FWX833ASO? I'm assuming it's within the two seals. Please correct me if I'm wrong.
  #8 (permalink)
Old 03-18-2008, 03:05 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Ricardo.
As far as I know Frigidaire does not sell any transmission parts separate.
__________________
  #9 (permalink)
Old 08-28-2008, 02:39 PM
Junior Member
hybrid999 is on a distinguished road
Default how to take it appart
can one of you guys give me a bit of advice in order to take it appart. I am mechanically inclined but I can't figure out how to take the tub out ...
thanks a lot !
  #10 (permalink)
Old 08-28-2008, 06:34 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
hybrid999,
What is the complete model number of the washer?
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer leaks water out bottom jag11727 Washer Repair 3 05-12-2009 10:26 AM
washer leaks water centurionballer Washer Repair 2 11-20-2008 06:23 PM
washer leaks water puttputt1953 Washer Repair 5 10-21-2008 01:18 PM
Washer Leaks Water Into Tub After Cycle zinnco Washer Repair 1 09-11-2008 04:51 PM
Washer leaks water cpete Washer Repair 0 09-06-2008 11:06 AM
