Discuss
Dreaded F06 error in Whirlpool Duet washer
 in
Washer Repair
I was ready to test the MCU and the control electronics to find the problem of a F06 error display,
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Dreaded F06 error in Whirlpool Duet washer
  #1 (permalink)
Old 02-26-2008, 05:20 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default Dreaded F06 error in Whirlpool Duet washer
Brand: Whirlpool   Age: 1 - 5 years
I was ready to test the MCU and the control electronics to find the problem of a F06 error display, then I checked the spin basket and found it would barely turn.
I pulled the tub drain hose feeding the pump,and found a big glob of lint and some pieces of a broken paddle. Once all the stuff was pulled out, the basket turned freely. Customer was happy to save a lot of money as the next step would be a tub dismantle!
Hope this info helps someone.
I might add that this seems to be a poor design as the lint collects on top of the heater. This makes it easier to jam and harder to clean out.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Duet Washer jimgosnell Washer Repair 1 01-18-2008 02:17 PM
Whirlpool washer Duet job aid richappy General Talk 0 12-28-2007 04:26 AM
Whirlpool duet Error Code F30 mcjej@yahoo.com Washer Repair 0 11-24-2007 10:31 PM
error codes on whirlpool duet sport Thad Steele Washer Repair 1 11-02-2007 03:12 PM
