Paul H
#1 Posted : Sunday, November 8, 2009 7:17:50 PM(UTC)
Paul H
The hub plate is broken. I cannot get the hub nut off. I have soaked it over night with wd40, still will not move. How can I get it off? Once hub is off, any parts that should be replaced at this time? A new hub nut, hub seal, split ring, hub washer, anything else.
Thanks for your help,
Paul
sidfink43
#2 Posted : Monday, November 9, 2009 3:10:21 PM(UTC)
sidfink43
Hi Paul
That nut should be left hand threaded, so that may be part of the cause of your problem. If you already knew that (and you probably did) it is just a matter of working with it to get it off.
As far as anything else is concerned, just take a good look at everything, and clean everything you can.
Good luck.
Paul H
#3 Posted : Tuesday, November 10, 2009 3:15:19 AM(UTC)
Paul H
Thanks for the advice. Knew it was was a left hand thread, but still cannot get it to move. Looks like I'll try cutting the nut off.
Thanks again. Paul.
Frigidaire Affinity Washing Machine - Leaking only sometimes (Washer Repair)
by omf_24 2/24/2024 4:45:41 PM(UTC)
Stem question about Naytag 2-belt washing machine (Washer Repair)
by Hotrodjohn71 1/2/2024 7:50:48 AM(UTC)
Maytag Oasis HE Washing Machine (Washer Repair)
by Guest 12/8/2023 12:55:45 PM(UTC)
Whirlpool Washing Machine won't start/fill (Washer Repair)
by greekguy7 12/8/2023 4:53:34 AM(UTC)
whirlpool model wtw7300dw2 washing machine (Washer Repair)
by Guest 11/8/2023 9:27:17 AM(UTC)
MVWB965HC0 Washing Machine - Need Service Manual or Video to Replace Touchpad and Control Assembl (Washer Repair)
by Guest 10/30/2023 8:11:10 PM(UTC)
Best vintage, American made washing machines (Washer Repair)
by Guest 10/30/2023 5:27:34 AM(UTC)
Washing machine not washing clothes properly (Washer Repair)
by Guest 9/20/2023 11:56:24 AM(UTC)
Washing Machine fill with water but will not spin, rinse or agitate. (Washer Repair)
by jmaiso 9/1/2023 7:04:07 AM(UTC)
Washing machine do not complete the cycle (Washer Repair)
by Guest 8/16/2023 10:02:15 AM(UTC)
Mayag washing machine - possibly locked motor? (Washer Repair)
by crp0499 5/19/2023 3:02:19 AM(UTC)
Recommended replacement for WP22001311 Maytag Washing Machine Unbalance lever (Washer Repair)
by Guest 4/29/2023 12:17:37 PM(UTC)
Whirlpool washing machine drive hub (Washer Repair)
by Guest 4/23/2023 7:29:26 AM(UTC)
Extension hose for GE washing machine GFW850SPNRS (Washer Repair)
by Guest 3/17/2023 9:53:53 PM(UTC)
Maytag washing machine MHW6630HW - looking for electrical diagram (Washer Repair)
by jessman1128 2/8/2023 12:45:11 PM(UTC)
