Discuss
washer won't drain
 in
Washer Repair
Just finished 7 loads of laundry, and on the last one, the tub wouldn't drain. We checked the drains, and
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer won't drain
  #1 (permalink)
Old 08-15-2007, 08:54 PM
Junior Member
jmsnewton is on a distinguished road
Default washer won't drain
Brand: Kenmore   Age: More than 10 years
Just finished 7 loads of laundry, and on the last one, the tub wouldn't drain. We checked the drains, and they don't appear to be clogged. So, before we go and buy parts we may not need, how do you determine if the pump is bad, or is there something else that may be involved?
TIA,
joanne
Ads By Google
  #2 (permalink)
Old 08-15-2007, 10:47 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Joanne
We might be able to help you but we need the complete model number of your washer.
  #3 (permalink)
Old 08-28-2007, 08:04 AM
Junior Member
lizclo is on a distinguished road
Lightbulb kenmore washer 8 yrs old have to spin twice
please help! my washer is not spinning out enough water from my clothes. what can i do to fix it. i find myself 2 hrs on one load to wash and dry. cant afford to buy a new one right now. liz
  #4 (permalink)
Old 08-28-2007, 09:08 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi lizclo
One of the most common cause of such problem is a unbalanced load.
If your washer is shaking during the spin cycle it never will go on full speed. The first thing check if the washer is leveled, then if you see it's shaking, open the lid and redistribute the garments inside.
If it does not work then I need the complete model number of your washer. You can find it under the lid.
Good luck.
  #5 (permalink)
Old 08-29-2007, 11:16 AM
Junior Member
Default 8 yr old kenmore that has to spin twice
thanks for replying so quickly gene,
but it doesnt do any of that. it looks to be running ok just needs to spin twice. i will get that number for tonight.
thanks,
liz
  #6 (permalink)
Old 09-04-2007, 10:45 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi lizclo
Are you sure the problem is the washer and not the dryer?
If the dryer vent is clogged up, it takes much longer time to dry. Try to disconnect the vent hose from the back of the dryer and run a couple loads to see how long it takes.
Good luck.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer does not drain acer_620_u Washer Repair 1 12-09-2009 06:15 AM
washer does not drain leh Washer Repair 0 08-22-2009 03:08 PM
Washer won't drain aerrickson Washer Repair 2 05-17-2009 02:40 PM
GE Washer won't drain Wannafix Washer Repair 0 06-12-2008 07:57 AM
Calypso Washer Washer Won't Drain SamB Washer Repair 3 11-27-2007 01:41 PM
