Discuss
Direct Drive Basket Spin Not Engaging
 in
Washer Repair
I have a Roper RAS8333PQ0. It was spinning slowly and would sometimes not spin at all during drain cycles. I
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Direct Drive Basket Spin Not Engaging
  #1 (permalink)
Old 11-07-2009, 08:02 PM
jdrds17 jdrds17 is offline
Junior Member
jdrds17 is on a distinguished road
Default Direct Drive Basket Spin Not Engaging
Brand: Roper   Age: 5 - 10 years
I have a Roper RAS8333PQ0. It was spinning slowly and would sometimes not spin at all during drain cycles. I thought the problem was dragging brake shoes, so I did the brake shoe replacement service including new brake shoes and a new clutch assembly. The motor coupling was in near perfect condition, so I did not replace it. Also, I pulled the basket while I had the spanner nut off and did not find any foreign objects between the basket and the outer tub. After the service the spin is definitely faster. However, the spin engagement of the basket is still intermittent. On draining after the rinse, it seems to engage about 50% of the time. On draining after the wash, it seems much less - probably less than 25% of the time. Simply opening the lid far enough to trip the lid switch to turn the machine off and then reclosing the lid will get the basket to engage - no manual turning of the basket is required. Also, during reassembly I checked the coupler input to the transmission before replacing the motor - it was easier to turn than before, but still not easy. Do I have a transmission problem? Possibly something else? Thanks for any assistance!
  #2 (permalink)
Old 11-09-2009, 01:39 PM
sidfink43 sidfink43 is offline
Senior Expert
APP Volunteer
sidfink43 is on a distinguished road
Default
See Richappy's sticky on direct drive brake shoes. If it is difficult to turn the transmission shaft in a clockwise direction using the plastic coupling piece then you probably have a transmission problem.
I would first remove and reinstall the brake tube and transmission just in case you have something hung up from your previous work.
Good luck.
__________________
  #3 (permalink)
Old 11-10-2009, 04:36 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Another possible problem is a jammed thrust washer that sits on top of the tranny. If not seated right, it will partially jam the spin tube.
__________________
  #4 (permalink)
Old 11-14-2009, 06:21 PM
Junior Member
Default Fixed?
Well, I disassembled the pump, motor, and gearcase/clutch assembly. Everything seemed in order and the spin tube thrust washer seemed to be correctly seated. There was some grease splattered about (I think I over did it a bit when installing the new brake shoes) which I cleaned up. The transmission input turned easily and smoothly with it disassembled and I could engage both the agitate and spin modes. Also, turning the basket by the brake cam driver was easy and smooth. Not knowing what else to check I reassembled the the transmission/clutch to the basket drive. At this point turning the transmission input by hand was a bit harder, but maybe easier than last assembly but hard to judge. It shouldn't be totally easy since you are compressing the brake spring, correct? I completed reassembly and lo and behold the washer seems to be running fine. I've got at least 5 complete cycles with no missed spins! Thanks again for all your efforts and hopefully I won't have to revive this thread sometime later!
  #5 (permalink)
Old 11-14-2009, 06:49 PM
Senior Expert
APP Volunteer
Default
Great, that remove and reinstall works sometimes. Glad you got it fixed and thanks for the update.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Spin problem Direct Drive partymonster Washer Repair 12 08-23-2009 03:51 PM
Kenmore Direct Drive Won't Spin!! cjcoles Washer Repair 4 11-09-2008 01:38 PM
New clutch and basket drive - still no spin jbrad4ou Washer Repair 9 05-09-2008 04:47 AM
Whirlpool direct-drive sporadic final spin alan1125 Washer Repair 1 04-13-2008 05:43 PM
Kenmore direct drive basket/filter plate/plugs GeorgeG Washer Repair 1 03-24-2008 10:51 PM
