Discuss
Washer is not draining
 in
Washer Repair
I can't seem to locate my model number for this washer on any of the lists. My washer is
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer is not draining
  #1 (permalink)
Old 02-24-2008, 08:21 AM
MMBell MMBell is offline
Junior Member
MMBell is on a distinguished road
Default Washer is not draining
Model Number: LSR5132PQ0   Brand: Whirlpool   Age: 5 - 10 years
I can't seem to locate my model number for this washer on any of the lists. My washer is not draining, although it spins and runs through the cycles completely, however there is a clicking sound on the dial when it reaches the draining/spinning part of the cycle. When I first noticed it there was a burning smell. I have checked and the hoses are not clogged. Help! My laundry is piling up!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-24-2008, 12:42 PM
ApplianceJunk's Avatar
ApplianceJunk ApplianceJunk is offline
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
This is a direct drive washer and if the tub is spinning then the pump is turning too.
I would take a second look for restrictions on the drain hose.
Take a look were the drain hose slips on the back of the washer.
There is a elbow there. Remove the drain hose and looking inside that elbow.
__________________
You can Repair your Appliance & we can help with our Appliance Repair Forum and Appliance Repair Blog.
  #3 (permalink)
Old 02-25-2008, 11:56 AM
Junior Member
Default
Hi...Took drain hose off and the water gushed out of the elbow on the back of the washer. Snaked the drain pipe 25 feet out of the house and poured water down and it drained fine and the hose from the washer to the pipe as well. But the washer still spins and does not empty!!! Ready to throw in the towel (literally!). Any other suggestions? Short on $ and really can't afford the repair guy...but...
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer fills but just keeps draining jeepman Washer Repair 2 02-22-2008 08:48 PM
Washer leaks when filling and draining jds.girl_2006 Washer Repair 1 02-11-2008 05:25 PM
not draining Belkey Washer Repair 1 12-09-2007 09:15 PM
GE Washer: Not spinning or draining Vonnie2 Washer Repair 0 11-10-2007 10:54 PM
my washer stopped draining or spining jesse Washer Repair 1 10-09-2007 03:16 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
