Discuss
Frigidaire washer tub just rocks back an forth
 in
Washer Repair
The tub on my front load Frigidaire washer won't make a complete revolution. It just rocks back and forth
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Frigidaire washer tub just rocks back an forth
  #1 (permalink)
Old 11-06-2009, 12:48 PM
jfwsmith jfwsmith is offline
Junior Member
jfwsmith is on a distinguished road
Default Frigidaire washer tub just rocks back an forth
Model Number: LTF530FS0   Brand: Frigidaire   Age: 1 - 5 years
The tub on my front load Frigidaire washer won't make a complete revolution. It just rocks back and forth through the cycle. We've tried various sizes of wash loads, including empty. Any suggestions? Is there a service manual available for this model?
Jeff
Related Models
Frigidaire LTF530FS0 Frigidaire/washer
Frigidaire LTF6000ES0 Frigidaire/washer
Frigidaire LTF6000ES1 Frigidaire/washer
Frigidaire LTF6000FS0 Frigidaire/washer
Frigidaire LTF7000EG0 Frigidaire/washer
Frigidaire LTF7000ES0 Frigidaire/washer
Frigidaire LTF7000ES1 Frigidaire/washer
Frigidaire LTF7000FG0 Frigidaire/washer
Whirlpool LTG5243BN0
Whirlpool LTG5243BN1
Whirlpool LTG5243BN2
Whirlpool LTG5243BW0
Whirlpool LTG5243BW1
Whirlpool LTG5243BW2
Whirlpool LTG5243DQ0
Whirlpool LTG5243DQ1
Whirlpool LTG5243DQ2
Whirlpool LTG5243DQ3
Whirlpool LTG5243DQ4 Washer/dryer Laundry System
Whirlpool LTG5243DQ5 Washer/dryer Laundry System
Whirlpool LTG5243DQ6 Washer/dryer Laundry System
Whirlpool LTG5243DQ7 Washer/dryer Laundry System
Whirlpool LTG5243DT2
Whirlpool LTG5243DT3
Whirlpool LTG5243DT4 Washer/dryer Laundry System
Whirlpool LTG5243DT5 Washer/dryer Laundry System
Whirlpool LTG5243DT6 Washer/dryer Laundry System
Whirlpool LTG5243DT7 Washer/dryer Laundry System
Whirlpool LTG5243DZ0
Whirlpool LTG5243DZ1
Whirlpool LTG5243DZ2
Whirlpool LTG6234AN0
Whirlpool LTG6234AN1
Whirlpool LTG6234AN2
Whirlpool LTG6234AN3
Whirlpool LTG6234AW0
Whirlpool LTG6234AW1
Whirlpool LTG6234AW2
Whirlpool LTG6234AW3
Whirlpool LTG6234DQ0
Whirlpool LTG6234DQ1
Whirlpool LTG6234DQ2 Washer/dryer Laundry System
Whirlpool LTG6234DQ3 Washer/dryer Laundry System
Whirlpool LTG6234DQ4 Washer/dryer Laundry System
Whirlpool LTG6234DQ5 Washer/dryer Laundry System
Whirlpool LTG6234DT1
Whirlpool LTG6234DT2 Washer/dryer Laundry System
Whirlpool LTG6234DT3 Washer/dryer Laundry System
Whirlpool LTG6234DT4 Washer/dryer Laundry System
Whirlpool LTG6234DT5 Washer/dryer Laundry System
Whirlpool LTG6234DZ0
Whirlpool LTG6234DZ1
Whirlpool LTG7245AN0
Whirlpool LTG7245AW0
Whirlpool LUD2100X0
Whirlpool LUD2100X1
Whirlpool LUD2100X3
Whirlpool LUD2100X4
Whirlpool LUD2100X5
Whirlpool LUD2100X6
Whirlpool LUD2100X7
General Electric LUD3100V57WB Dishwasher
General Electric LUD3100V60WB Dishwasher
General Electric LUD3100V64WB Dishwasher
General Electric LUD3100X66WB Dishwasher
Bosch LV010-000
Whirlpool LV55
Whirlpool LV551
Whirlpool LV5511
Whirlpool LV651
Whirlpool LVA4000W0
Whirlpool LVA4000W1
Whirlpool LVA4000W2
Whirlpool LVA4000W3
Whirlpool LVA4000W4
Whirlpool LVA4000W5
Whirlpool LVA4000W6
Whirlpool LVA4000W7
Whirlpool LVA4005W0
Whirlpool LVA4005W1
Whirlpool LVA4005W2
Whirlpool LVA4005W3
Whirlpool LVA4005W4
Whirlpool LVA4005W5
Whirlpool LVA4005W6
Whirlpool LVA4005W7
Whirlpool LVA4800W0
Whirlpool LVA4805W0
Whirlpool LVA4805W1
Whirlpool LVA5300W0
Whirlpool LVA5300W1
Whirlpool LVA5304W0
Whirlpool LVA5304W1
Whirlpool LVA5305W0
Whirlpool LVA5305W1
Whirlpool LVA5309W0
Whirlpool LVA5309W1
Whirlpool LVA5400W0
Whirlpool LVA5405W0
Whirlpool LVA5500W0
Whirlpool LVA5505W0
Whirlpool LVA5540W0
Whirlpool LVA5540W1
Whirlpool LVA5545W0
Whirlpool LVA5545W1
Whirlpool LVA5560W0
Whirlpool LVA5560W1
Whirlpool LVA5565W0
Whirlpool LVA5565W1
Whirlpool LVA6300W0
Whirlpool LVA6304W0
Whirlpool LVA6305W0
Whirlpool LVA6309W0
Whirlpool LVA6400W0
Whirlpool LVA6400W1
Whirlpool LVA6404W0
Whirlpool LVA6404W1
Whirlpool LVA6405W0
Whirlpool LVA6405W1
Whirlpool LVA6409W0
  #2 (permalink)
Old 11-06-2009, 06:51 PM
denman denman is online now
Senior Expert
APP Volunteer
denman will become famous soon enough
Default
Replacement parts for FRG LTF530FS0 | AppliancePartsPros.com
Have never worked on these but can at least give you some info
Here is the tech sheet
http://manuals.frigidaire.com/prodin.../134576200.pdf
And here are two manual do not know which is the closest match to your unit but they may have info that is helpful
http://frigidaireservicetips.com/pdf...ionWashers.pdf
http://frigidaireservicetips.com/pdf...isWasherSM.pdf
I hope the above is helpful.
I would check that the tub will make a full revolution manually, in case it is jamming for some reason.
If OK
I would investigate the motor drive circuits and components.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire range conversion back to nat. gas problem Danno185 Oven Repair (including Ranges and Cooktops) 1 09-27-2009 09:32 PM
Convert Frigidaire LP back to NG danmcnally Oven Repair (including Ranges and Cooktops) 1 05-01-2009 02:32 PM
Convert Frigidaire LP back to NG danmcnally Oven Repair (including Ranges and Cooktops) 0 05-01-2009 12:52 PM
washer rocks/unbalance - leveling mechanism failed? alt2mn Washer Repair 2 11-17-2008 09:01 AM
How do I get the front panel back on Frigidaire door? Daddo Dishwasher Repair 1 09-27-2008 05:50 PM
