Discuss
Washer Won't Stop Filling/
 in
Washer Repair
Hi. Yesterday my tub was not spinning and I purchased a coupler kit and replaced it. I felt like McGyver
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer Won't Stop Filling/
  #1 (permalink)
Old 11-06-2009, 11:19 AM
cfj cfj is offline
Junior Member
cfj is on a distinguished road
Default Washer Won't Stop Filling/
Model Number: LSR7233BW2   Brand: Whirlpool   Age: More than 10 years
Hi. Yesterday my tub was not spinning and I purchased a coupler kit and replaced it. I felt like McGyver and the tub /spin cycle worked.
Problem now is that the water will not stop filling the TB. It did work before I did the above repair. If I let it go it would overflow. I have done some research and I did make sure the clear tube in back of the control panel was clear and not bent.
When I fill the tub the washer will work in the wash cycle near the end of the cycle for about 3 minutes then drains and moves to rinse and I have to watch it again to make sure it does not overflow.
I have been told it is the fill switch that needs to be replaced. If this is true then why when I stop the water from going into the tub, why would not the washer still work and wash the clothes?
I am trying to decide if I should fix the unit further or by a new washer.
Any help would be appreciated. Thanks
Related Models
Whirlpool LSR7233BW2
Whirlpool LSR7233BWO WASHER
Whirlpool LSR7233BZ0
Whirlpool LSR7233BZ2
Whirlpool LSR7233DQ0 WASHER
Whirlpool LSR7233DQ1 AUTOMATIC WASHER
Whirlpool LSR7233DW0 WASHER
Whirlpool LSR7233DZ0 WASHER
Whirlpool LSR7233DZ1 AUTOMATIC WASHER
Whirlpool LSR7233EQ0 WASHER
Whirlpool LSR7233EQ1 AUTOMATIC WASHER
Whirlpool LSR7233EW0 DIRECT-DRIVE WASHER
Whirlpool LSR7233EZ0 DIRECT-DRIVE WASHER
Whirlpool LSR7233EZ1 AUTOMATIC WASHER
Whirlpool LSR7233HQ0 AUTOMATIC WASHER
Whirlpool LSR7233HZ0 AUTOMATIC WASHER
Whirlpool LSR7300PQ0 AUTOMATIC WASHER
Whirlpool LSR7300PQ1 AUTOMATIC WASHER
Whirlpool LSR7300PQ2 AUTOMATIC WASHER
Whirlpool LSR7333PQ0 AUTOMATIC WASHER
Whirlpool LSR7333PQ1 AUTOMATIC WASHER
Whirlpool LSR7333PQ3 AUTOMATIC WASHER
Whirlpool LSR7333PQ4 AUTOMATIC WASHER
Whirlpool LSR8010PQ0 AUTOMATIC WASHER
Whirlpool LSR8010PQ1 AUTOMATIC WASHER
Whirlpool LSR8010PQ2 AUTOMATIC WASHER
Whirlpool LSR8010PT0 AUTOMATIC WASHER
Whirlpool LSR8010PT1 AUTOMATIC WASHER
Whirlpool LSR8010PT2 AUTOMATIC WASHER
Whirlpool LSR8133HQ0 AUTOMATIC WASHER
Whirlpool LSR8133HZ0 AUTOMATIC WASHER
Whirlpool LSR8200EQ0 AUTOMATIC WASHER
Whirlpool LSR8200EZ0 AUTOMATIC WASHER
Whirlpool LSR8233EQ0 HOME WASHERS DIRECT-DRIVE
Whirlpool LSR8233EQ1 AUTOMATIC WASHER
Whirlpool LSR8233EZ0 HOME WASHERS DIRECT-DRIVE
Whirlpool LSR8233EZ1 AUTOMATIC WASHER
Whirlpool LSR8233JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSR8233JQ1 WASHER
Whirlpool LSR8233JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSR8233JT1 WASHER
Whirlpool LSR8244BN0
Whirlpool LSR8244BN1
Whirlpool LSR8244BN2
Whirlpool LSR8244BW0
Whirlpool LSR8244BW1
Whirlpool LSR8244BW2
Whirlpool LSR8244DQ0
Whirlpool LSR8244DZ0
Whirlpool LSR8244EQ0
Whirlpool LSR8244EQ1
Whirlpool LSR8244EZ0
Whirlpool LSR8244EZ1
Whirlpool LSR8300EQ0
Whirlpool LSR8300EQ1
Whirlpool LSR8300EZ0
Whirlpool LSR8300EZ1
Whirlpool LSR8433KQ0 WASHER
Whirlpool LSR8433KQ1 AUTOMATIC WASHER
Whirlpool LSR8433KQ2 AUTOMATIC WASHER
Whirlpool LSR8433KT0 WASHER
Whirlpool LSR8433KT1 AUTOMATIC WASHER
Whirlpool LSR8433KT2 AUTOMATIC WASHER
Whirlpool LSR8444LQ0 WASHER
Whirlpool LSR8444LQ1 AUTOMATIC WASHER
Whirlpool LSR8444LT0 WASHER
Whirlpool LSR9355DQ0
Whirlpool LSR9355DZ0
Whirlpool LSR9434PQ0 AUTOMATIC WASHER
Whirlpool LSR9434PQ1 AUTOMATIC WASHER
Whirlpool LSR9434PQ3 AUTOMATIC WASHER
Whirlpool LSR9434PQ4 AUTOMATIC WASHER
Whirlpool LSR9434PT0 AUTOMATIC WASHER
Whirlpool LSR9434PT1 AUTOMATIC WASHER
Whirlpool LSR9434PT3 AUTOMATIC WASHER
Whirlpool LSR9434PT4 AUTOMATIC WASHER
General Electric LSS25XGTABB Refrigerator
General Electric LSS25XGTAWW Refrigerator
General Electric LSS25XGTBBB Refrigerator
General Electric LSS25XGTBWW Refrigerator
General Electric LSS25XGTEBB Refrigerator
General Electric LSS25XGTEWW Refrigerator
General Electric LSS25XSTASS Refrigerator
General Electric LSS25XSTBSS Refrigerator
General Electric LSS25XSTESS Refrigerator
General Electric LSS25XSWASS REFRIGERATOR W SERIES
General Electric LSS25XSWCSS REFRIGERATOR W SERIES
Whirlpool LSS7233AN0
Whirlpool LSS7233AN1
Whirlpool LSS7233AW0
Whirlpool LSS7233AW1
Whirlpool LSS7233DQ0
Whirlpool LSS8244AQ0
Whirlpool LSS8244AW0
Whirlpool LSS8244AZ0
Whirlpool LSS9244EQ0 WASHER
Whirlpool LSS9244EZ0 WASHER
Whirlpool LST6132AG0
Whirlpool LST6132AN0
Whirlpool LST6132AW0
Whirlpool LST6132BN0
Whirlpool LST6132BW0
Whirlpool LST6132BW1
Whirlpool LST6132DQ0
Whirlpool LST7233AG0
Whirlpool LST7233AN0
Whirlpool LST7233AN1
Whirlpool LST7233AQ0
Whirlpool LST7233AQ1
Whirlpool LST7233AW0
Whirlpool LST7233AW1
Whirlpool LST7233AZ0
Whirlpool LST7233AZ1
Whirlpool LST7233DQ0
Whirlpool LST7233DQ1
Whirlpool LST7233DZ0
Whirlpool LST7233DZ1
Whirlpool LST8244AN0
Whirlpool LST8244AQ0
Whirlpool LST8244AW0
  #2 (permalink)
Old 11-06-2009, 04:25 PM
Senior Member
applianceman is on a distinguished road
Default
First you need to check to see if the tube got pulled off the tub when you done the last repair. The tube should be connected to the tub (I believe on the back right).
Assuming that isn’t your problem (if it is disregard this part) either the water valve or the water level control is bad. I am not sure I quite follow your post are you saying the washer will start to wash but the water keeps entering the tub? If so it sounds more like the water valve. If you have to cut the water valve off (at the wall) to make the water stop flowing replace the water inlet valve. If turning off the washer stops the water flow replace the water level control (provided the tube isn’t clogged or off). Hope this help!
Clothes Washer Repair Guide
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer will not stop filling TOM901 Washer Repair 1 01-15-2010 10:58 AM
washer wouldn't stop filling verm Washer Repair 2 09-14-2009 04:08 PM
GE Washer won't stop filling scrabs Washer Repair 2 07-06-2009 07:26 PM
washer won't stop filling!!!! dalejrmaniac Washer Repair 18 09-05-2008 04:02 PM
washer won't stop filling mnestinger Washer Repair 1 11-14-2007 11:25 AM
