Discuss
Whirlpool won't drain, then spins VERY slow
 in
Washer Repair
Our Whirlpool washer motor started making a weird sound like the motor is overloaded. The tub does not drain at
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool won't drain, then spins VERY slow
  #1 (permalink)
Old 11-06-2009, 10:24 AM
nswaibel nswaibel is offline
Junior Member
nswaibel is on a distinguished road
Default Whirlpool won't drain, then spins VERY slow
Model Number: LSQ9500LQ0   Brand: Whirlpool   Age: 5 - 10 years
Our Whirlpool washer motor started making a weird sound like the motor is overloaded. The tub does not drain at all after a rinse and when it goes to spin out it spins very very slow for just a couple revolutions before coming to a halt.
I hesitate to spend $130+ on labor plus additional for parts (drive motor, gearcase, water pump, who knows) when the washer only cost $350 6 years ago.
I am not a mechanic, but fairly handy. Can anyone give me a place to start to see if I can do a home repair.
Related Models
Whirlpool LSQ9500LQ0
Whirlpool LSQ9500LT0
Whirlpool LSQ9510JQ0
Whirlpool LSQ9510JQ1
Whirlpool LSQ9510LQ0
Whirlpool LSQ9510LT0
Whirlpool LSQ9520LQ0
Whirlpool LSQ9520LT0
Whirlpool LSQ9544KQ0
Whirlpool LSQ9544KT0
Whirlpool LSQ9549LG0
Whirlpool LSQ9549LG1 Automatic Washer
Whirlpool LSQ9549LG2 Automatic Washer
Whirlpool LSQ9549LG3 Automatic Washer
Whirlpool LSQ9549LQ0
Whirlpool LSQ9549LQ1 Automatic Washer
Whirlpool LSQ9549LQ2 Automatic Washer
Whirlpool LSQ9549LQ3 Automatic Washer
Whirlpool LSQ9549LW0
Whirlpool LSQ9549LW1 Automatic Washer
Whirlpool LSQ9549LW2 Automatic Washer
Whirlpool LSQ9549LW3 Automatic Washer
Whirlpool LSQ9549PG0 Automatic Washer
Whirlpool LSQ9549PG1 Automatic Washer
Whirlpool LSQ9549PG2 Automatic Washer
Whirlpool LSQ9549PG3 Automatic Washer
Whirlpool LSQ9549PG5 Automatic Washer
Whirlpool LSQ9549PG6 Automatic Washer
Whirlpool LSQ9549PW0 Automatic Washer
Whirlpool LSQ9549PW1 Automatic Washer
Whirlpool LSQ9549PW2 Automatic Washer
Whirlpool LSQ9549PW3 Automatic Washer
Whirlpool LSQ9549PW5 Automatic Washer
Whirlpool LSQ9549PW6 Automatic Washer
Whirlpool LSQ9550PW0 Automatic Washer
Whirlpool LSQ9550PW1 Automatic Washer
Whirlpool LSQ9550PW2 Automatic Washer
Whirlpool LSQ9550PW3 Automatic Washer
Whirlpool LSQ9550PW4 Automatic Washer
Whirlpool LSQ9560PW0 Automatic Washer
Whirlpool LSQ9560PW1 Automatic Washer
Whirlpool LSQ9560PW3 Automatic Washer
Whirlpool LSQ9560PW4 Automatic Washer
Whirlpool LSQ9564JQ0
Whirlpool LSQ9564JQ1
Whirlpool LSQ9564JT0
Whirlpool LSQ9564JT1
Whirlpool LSQ9564JZ0
Whirlpool LSQ9564MQ0 Automatic Washer
Whirlpool LSQ9600JQ0
Whirlpool LSQ9600JQ1
Whirlpool LSQ9600JT0
Whirlpool LSQ9600JT1
Whirlpool LSQ9600LG0
Whirlpool LSQ9600LG1 Automatic Washer
Whirlpool LSQ9600LW0
Whirlpool LSQ9600LW1 Automatic Washer
Whirlpool LSQ9610JQ0
Whirlpool LSQ9610JQ1
Whirlpool LSQ9610JT0
Whirlpool LSQ9610JT1
Whirlpool LSQ9610LG0 Automatic Washer
Whirlpool LSQ9610LW0 Automatic Washer
Whirlpool LSQ9620LG0
Whirlpool LSQ9620LG1 Automatic Washer
Whirlpool LSQ9620LW0
Whirlpool LSQ9620LW1 Automatic Washer
Whirlpool LSQ9645KQ0
Whirlpool LSQ9645KQ1
Whirlpool LSQ9645KT0
Whirlpool LSQ9645KT1
Whirlpool LSQ9650PG0 Automatic Washer
Whirlpool LSQ9650PG1 Automatic Washer
Whirlpool LSQ9650PG2 Automatic Washer
Whirlpool LSQ9650PG3 Automatic Washer
Whirlpool LSQ9650PG4 Automatic Washer
Whirlpool LSQ9650PW0 Automatic Washer
Whirlpool LSQ9650PW1 Automatic Washer
Whirlpool LSQ9650PW2 Automatic Washer
Whirlpool LSQ9650PW3 Automatic Washer
Whirlpool LSQ9650PW4 Automatic Washer
Whirlpool LSQ9659LG0
Whirlpool LSQ9659LG1 Automatic Washer
Whirlpool LSQ9659LW0
Whirlpool LSQ9659LW1 Automatic Washer
Whirlpool LSQ9659PG0 Automatic Washer
Whirlpool LSQ9659PG1 Automatic Washer
Whirlpool LSQ9659PG2 Automatic Washer
Whirlpool LSQ9659PG3 Automatic Washer
Whirlpool LSQ9659PG4 Automatic Washer
Whirlpool LSQ9659PW0 Automatic Washer
Whirlpool LSQ9659PW1 Automatic Washer
Whirlpool LSQ9659PW2 Automatic Washer
Whirlpool LSQ9659PW3 Automatic Washer
Whirlpool LSQ9659PW4 Automatic Washer
Whirlpool LSQ9660PG0 Automatic Washer
Whirlpool LSQ9660PG1 Automatic Washer
Whirlpool LSQ9660PG2 Automatic Washer
Whirlpool LSQ9660PG3 Automatic Washer
Whirlpool LSQ9660PG4 Automatic Washer
Whirlpool LSQ9660PW0 Automatic Washer
Whirlpool LSQ9660PW1 Automatic Washer
Whirlpool LSQ9660PW2 Automatic Washer
Whirlpool LSQ9660PW3 Automatic Washer
Whirlpool LSQ9660PW4 Automatic Washer
Whirlpool LSQ9665JQ0
Whirlpool LSQ9665JQ1
Whirlpool LSQ9665JQ2
Whirlpool LSQ9665JQ3
Whirlpool LSQ9665JQ4
Whirlpool LSQ9665JT0
Whirlpool LSQ9665JT1
Whirlpool LSQ9665JT2
Whirlpool LSQ9665JT3
Whirlpool LSQ9665JT4
Whirlpool LSR4100HQ0
Whirlpool LSR4311DQ0
Whirlpool LSR5100HQ0
Whirlpool LSR5100KQ0
Whirlpool LSR5100LQ0
  #2 (permalink)
Old 11-06-2009, 05:14 PM
sidfink43 sidfink43 is offline
Senior Expert
APP Volunteer
sidfink43 is on a distinguished road
Default
If you are lucky the problem is something jammed in the pump, or the pump itself which is an inexpensive and easy repair.
This video will show you how to take off the cabinet to get to the pump. Even if you do not find anything in the pump, after you take it off by pass the lid switch by inserting a solid insulated wire into the two outer holes n the plastic connector coming from the console and turn the time to spin, and see if the motor engages. If it does, replace the pump.
YouTube - Direct Drive Washing Machine Repair Video Tutorial *Watch in HIGH Quality!*
Good luck, let us know how it turns out.
__________________
  #3 (permalink)
Old 11-09-2009, 10:31 AM
Junior Member
Default
Another case of Find the Missing Baby Sock has been resolved! Found the sock in the water pump suction and it locked up the drive motor. I removed the sock and thankfully the motor was not burnt up. The washer works great again and I was able to avoid calling in the repairman. Thanks for the reply! The YouTube video was EXTREMELY helpful and made this less than an hour repair. Thank you, thank you!
  #4 (permalink)
Old 11-09-2009, 12:01 PM
Senior Expert
APP Volunteer
Default
Great, not only did you get it repaired but you got a sock back.
Thanks for the update.
__________________
  #5 (permalink)
Old 11-09-2009, 12:34 PM
Junior Member
Default
The sock was actually a casualty, but I'm just happy to have my washer back.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer spins slow Jamie2009 Washer Repair 1 08-18-2009 07:36 PM
spins slow and wont drain kaavman66 Washer Repair 1 07-07-2009 04:48 PM
washer spins slow kenfink Washer Repair 1 04-29-2009 06:43 PM
Whirlpool spins slow and sporatic MelMitch Washer Repair 4 03-01-2009 01:45 PM
washer spins too slow soggyclothes Washer Repair 1 02-10-2009 02:17 PM
