Discuss
inner drum removal difficulty
 in
Washer Repair
Replacing shaft basket gasket, spanner nut finally removed with difficulty even with spanner wrench, (showed corrosion and broken tread at
Appliance Repair Forum > Appliance Repair Help > Washer Repair » inner drum removal difficulty
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 09-27-2018, 02:00 PM
Junior Member
terraphysics is on a distinguished road
Default inner drum removal difficulty
Model Number: LSR5233EQO   Brand: Whirlpool   Age: More than 10 years
Replacing shaft basket gasket, spanner nut finally removed with difficulty even with spanner wrench, (showed corrosion and broken tread at bottom of nut), but inner drum will not come out. Tried shaking drum hard, side to side, up/ drown, drum will not come out. Notice that inner tub, drive block (part#17 on diagram) and tab portion of shaft easily move up and down together about 1/4 inch. Since this is a very early model (over 30 years old), is something else stopping this other than corrosion and crud? Can the inner drum and drive block be removed as a unit by replacing the spanner nut loosely back on the drive block (enough treads to completely grip, but not completely tight) and using a gear puller, pulling up on the spanner nut against the drive shaft ? Would this damage the drive shaft?
Update
After checking with support help, they didn't recommend using a gear puller, however without any other options left, I decided to try it. Using a 3 jaw , 2 ton gear puller, I pulled up on the reinstalled spanner nut against a steel plate over the center transmission shaft. The drive block and inner tub came out together fairly easy. there was no evidence of damage to the center transmission shaft. The inside portion of the inner tub was completely rusted, the inner tub would never have been pulled off. I still have not separated them, currently soaking with penetrating oil. The outer portion of the center basket drive was also completely rusted about 1/16 inch thick. Also discovered a large crack ( ~ 3 " long) in the outer basket at a bottom plastic support. Uncertain whether this was the source of the original leak and was enlarged by the shaking trying to remove the inner tub. Any in case, the cost of just replacing these two items makes the repair of the unit exceed its worth. I may try JB Weld and fiberglassing the crack as an experiment, but it is at a vertical support stress point, so not too encouraged. Maybe time to retire the unit after 31 years.
Update #2
Status of inner tub and drive bock. After turning the inter tub upside down and scraping away the rust and crud under the drive block, I poured penetrating oil around the bottom of the drive block and let it sit for about 8 hours. I then turned the tub upright and and with a block of wood hammer out the drive block. A couple good hard blows freed the two units. The lip at the bottom of the drive block was completely filled with hard crud about 1/4 inch thick. It was cleaned up with a knife and hard scraping. The bottom threads on the drive block showed corrosion and parts were missing (this matched the damage shown on the spanner nut ). Both spanner nut and drive block would require replacing. The outer basket crack repair awaits another day.
Related Models
Whirlpool LSR6132BN0 DIRECT-DRIVE WASHER
Whirlpool LSR6132BW0 DIRECT-DRIVE WASHER
Whirlpool LSR6132BW1 AUTOMATIC WASHER
Whirlpool LSR6132DQ0 DIRECT-DRIVE HOME WASHERS
Whirlpool LSR6132DZ0 DIRECT-DRIVE HOME WASHERS
Whirlpool LSR6132EQ0 AUTOMATIC WASHER
Whirlpool LSR6132EQ1 AUTOMATIC WASHER
Whirlpool LSR6132EZ0 AUTOMATIC WASHER
Whirlpool LSR6132EZ1 AUTOMATIC WASHER
Whirlpool LSR6132HQ0 AUTOMATIC WASHER
Whirlpool LSR6132HQ1 AUTOMATIC WASHER
Whirlpool LSR6132HZ0 AUTOMATIC WASHER
Whirlpool LSR6232JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSR6232JQ1 WASHER - DIRECT DRIVE
Whirlpool LSR6232JQ2 AUTOMATIC WASHER
Whirlpool LSR6233BG0 AUTOMATIC WASHER
Whirlpool LSR6233BN0 AUTOMATIC WASHER
Whirlpool LSR6233BN1 WASHER
Whirlpool LSR6233BW0 AUTOMATIC WASHER
Whirlpool LSR6233BW1 WASHER
Whirlpool LSR6233DN0 AUTOMATIC WASHER
Whirlpool LSR6233DW0 AUTOMATIC WASHER
Whirlpool LSR6244AW0 Washers*
Whirlpool LSR6332KQ0 WASHER
Whirlpool LSR6332KQ1 AUTOMATIC WASHER
Whirlpool LSR6334LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR6334LQ1 AUTOMATIC WASHER
Whirlpool LSR6335LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR7010PQ0 AUTOMATIC WASHER
Whirlpool LSR7010PQ1 AUTOMATIC WASHER
Whirlpool LSR7010PQ2 AUTOMATIC WASHER
Whirlpool LSR7133KQ0 WASHER
Whirlpool LSR7133KQ1 AUTOMATIC WASHER
Whirlpool LSR7133PQ0 AUTOMATIC WASHER
Whirlpool LSR7133PQ1 AUTOMATIC WASHER
Whirlpool LSR7133PQ2 AUTOMATIC WASHER
Whirlpool LSR7200EQ0 AUTOMATIC WASHER
Whirlpool LSR7200EZ0 AUTOMATIC WASHER
Whirlpool LSR7233BG0
Whirlpool LSR7233BG1
Whirlpool LSR7233BG2
Whirlpool LSR7233BGO WASHER
Whirlpool LSR7233BN0
Whirlpool LSR7233BN1
Whirlpool LSR7233BN2
Whirlpool LSR7233BNO WASHER
Whirlpool LSR7233BQ0
Whirlpool LSR7233BQ1
Whirlpool LSR7233BQ2
Whirlpool LSR7233BQO WASHER
Whirlpool LSR7233BW0
Whirlpool LSR7233BW1
Whirlpool LSR7233BW2
Whirlpool LSR7233BWO WASHER
Whirlpool LSR7233BZ0
Whirlpool LSR7233BZ2
Whirlpool LSR7233DQ0 WASHER
Whirlpool LSR7233DQ1 AUTOMATIC WASHER
Whirlpool LSR7233DW0 WASHER
Whirlpool LSR7233DZ0 WASHER
Whirlpool LSR7233DZ1 AUTOMATIC WASHER
Whirlpool LSR7233EQ0 WASHER
Whirlpool LSR7233EQ1 AUTOMATIC WASHER
Whirlpool LSR7233EW0 DIRECT-DRIVE WASHER
Whirlpool LSR7233EZ0 DIRECT-DRIVE WASHER
Whirlpool LSR7233EZ1 AUTOMATIC WASHER
Whirlpool LSR7233HQ0 AUTOMATIC WASHER
Whirlpool LSR7233HZ0 AUTOMATIC WASHER
Whirlpool LSR7300PQ0 AUTOMATIC WASHER
Whirlpool LSR7300PQ1 AUTOMATIC WASHER
Whirlpool LSR7300PQ2 AUTOMATIC WASHER
Whirlpool LSR7333PQ0 AUTOMATIC WASHER
Whirlpool LSR7333PQ1 AUTOMATIC WASHER
Whirlpool LSR7333PQ3 AUTOMATIC WASHER
Whirlpool LSR7333PQ4 AUTOMATIC WASHER
Whirlpool LSR8010PQ0 AUTOMATIC WASHER
Whirlpool LSR8010PQ1 AUTOMATIC WASHER
Whirlpool LSR8010PQ2 AUTOMATIC WASHER
Whirlpool LSR8010PT0 AUTOMATIC WASHER
Whirlpool LSR8010PT1 AUTOMATIC WASHER
Whirlpool LSR8010PT2 AUTOMATIC WASHER
Whirlpool LSR8133HQ0 AUTOMATIC WASHER
Whirlpool LSR8133HZ0 AUTOMATIC WASHER
Whirlpool LSR8200EQ0 AUTOMATIC WASHER
Whirlpool LSR8200EZ0 AUTOMATIC WASHER
Whirlpool LSR8233EQ0 HOME WASHERS DIRECT-DRIVE
Whirlpool LSR8233EQ1 AUTOMATIC WASHER
Whirlpool LSR8233EZ0 HOME WASHERS DIRECT-DRIVE
Whirlpool LSR8233EZ1 AUTOMATIC WASHER
Whirlpool LSR8233JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSR8233JQ1 WASHER
Whirlpool LSR8233JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSR8233JT1 WASHER
Whirlpool LSR8244BN0
Whirlpool LSR8244BN1
Whirlpool LSR8244BN2
Whirlpool LSR8244BW0
Whirlpool LSR8244BW1
Whirlpool LSR8244BW2
Whirlpool LSR8244DQ0
Whirlpool LSR8244DZ0
Whirlpool LSR8244EQ0
Whirlpool LSR8244EQ1
Whirlpool LSR8244EZ0
Whirlpool LSR8244EZ1
Whirlpool LSR8300EQ0
Whirlpool LSR8300EQ1
Whirlpool LSR8300EZ0
Whirlpool LSR8300EZ1
Whirlpool LSR8433KQ0 WASHER
Whirlpool LSR8433KQ1 AUTOMATIC WASHER
Whirlpool LSR8433KQ2 AUTOMATIC WASHER
Whirlpool LSR8433KT0 WASHER
Whirlpool LSR8433KT1 AUTOMATIC WASHER
Whirlpool LSR8433KT2 AUTOMATIC WASHER
Whirlpool LSR8444LQ0 WASHER
Whirlpool LSR8444LQ1 AUTOMATIC WASHER
Whirlpool LSR8444LT0 WASHER
Whirlpool LSR9355DQ0
Whirlpool LSR9355DZ0
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Drum removal hollywood1962 Dryer Repair 5 03-12-2013 08:16 PM
Drum Removal Help HARRY HEN Washer Repair 1 10-20-2009 07:06 PM
Drum Removal Help HARRY HEN Washer Repair 1 10-20-2009 11:56 AM
