Discuss
Washer motor won't rotate
 in
Washer Repair
The machine runs through the cycle Ok but won't spin or rotate. I've checked through the data sheet with the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer motor won't rotate
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 09-10-2018, 01:12 PM
Junior Member
debenriver is on a distinguished road
Default Washer motor won't rotate
Model Number: GLEH6412DS0   Brand: Frigidaire   Age: More than 10 years
I've checked through the data sheet with the machine and the speed control seems all OK, with one exception:
Step 4 check the voltages between pins 1,2,6 & 10 on the 10-pin plug and pin 5 on the 6-pin plug. It should be 0v, 120v, 120v, 120v. I get 120v, 0v, 120v, 120v. i.e. pin 1 and 2 are reversed. Checked the timer and it seems correct: contacts 1,5 & 7 closed; contact 2 open.
Checked the fuse on the speed control board - seems Ok
Checked the resistances on the speed control board – seem within range.
Checked the resistances on the motor - seem correct.
Checked voltage at motor plug - 210v between ground and pin 1 (machine switch heavy wash on)
I assumed that, because I have voltage at the motor - but it doesn't run. that it's a faulty motor - but why do I get 210v reading not 110v??
George
Related Models
Frigidaire GLEQ2152EE0 Frigidaire/dryer
Frigidaire GLEQ2152EE1 DRYER
Frigidaire GLEQ2152ES0 Frigidaire/dryer
Frigidaire GLEQ2152ES1 DRYER
Frigidaire GLEQ2170KE0 ELECTRIC DRYER
Frigidaire GLEQ2170KS0 ELECTRIC DRYER
Frigidaire GLEQ221AS2 Frigidaire/electric Dryer
Frigidaire GLEQ332AS0 Dryer - Frig Gallery
Frigidaire GLEQ332AS1 Dryer - Frig Gallery
Frigidaire GLEQ332AS2 Frigidaire/electric Dryer
Frigidaire GLEQ442CES0 Frigidaire/electric Dryer
Frigidaire GLEQ642AS0 Dryer - Frig Gallery
Frigidaire GLEQ642AS1 Dryer - Frig Gallery
Frigidaire GLEQ642AS2 Frigidaire/electric Dryer
Frigidaire GLEQ942CS0 Frigidaire/dryer
Frigidaire GLER1042FC0 Frigidaire/dryer
Frigidaire GLER1042FS0 Frigidaire/dryer
Frigidaire GLER104FSS0 Frigidaire/dryer
Frigidaire GLER331AQ1 Dryer - Frigidaire Gallery
Frigidaire GLER331AQ2 Frigidaire/dryer
Frigidaire GLER331AS0 Dryer - Frig Gal
Frigidaire GLER331AS1 Dryer - Frigidaire Gallery
Frigidaire GLER331AS2 Frigidaire/dryer
Frigidaire GLER341AS0 Dryer - Frigidaire Gallery
Frigidaire GLER341AS1 Dryer - Frigidaire Gallery
Frigidaire GLER341AS2 Frigidaire/electric Dryer
Frigidaire GLER341CC0 Frigidaire/dryer
Frigidaire GLER341CDC0 Frigidaire/dryer
Frigidaire GLER341CES0 Frigidaire/dryer
Whirlpool GLER5434BN0 ELECTRIC DRYER
Whirlpool GLER5434BN1 ELECTRIC DRYER
Whirlpool GLER5434BQ1 ELECTRIC DRYER
Whirlpool GLER5434BW0 ELECTRIC DRYER
Whirlpool GLER5434BW1 ELECTRIC DRYER
Frigidaire GLER642AS0 Dryer - Frigidaire Gallery
Frigidaire GLER642AS1 Dryer - Frigidaire Gallery
Frigidaire GLER642AS2 Dryer - Frig Gallery
Frigidaire GLER642AS3 Frigidaire/dryer
Frigidaire GLES388ASA Frigidaire/electric Range
Frigidaire GLES388ASB Frigidaire/electric Range
Frigidaire GLES388ASC Frigidaire/electric Range
Frigidaire GLES388ASD Frigidaire/electric Range
Frigidaire GLES388ASE Frigidaire/electric Range
Frigidaire GLES388CSA Frigidaire/electric Range
Frigidaire GLES388CSB Frigidaire/electric Range
Frigidaire GLES388DBA Frigidaire/electric Range
Frigidaire GLES388DBB Frigidaire/electric Range
Frigidaire GLES388DQA Frigidaire/electric Range
Frigidaire GLES388DQB Frigidaire/electric Range
Frigidaire GLES388DSA Frigidaire/electric Range
Frigidaire GLES388DSB Frigidaire/electric Range
Frigidaire GLES389EBA Frigidaire/electric Range
Frigidaire GLES389EBB Frigidaire/electric Range
Frigidaire GLES389EBC Frigidaire/electric Range
Frigidaire GLES389EBD Frigidaire/electric Range
Frigidaire GLES389EBE Frigidaire/electric Range
Frigidaire GLES389EQA Frigidaire/electric Range
Frigidaire GLES389EQB Frigidaire/electric Range
Frigidaire GLES389EQC Frigidaire/electric Range
Frigidaire GLES389EQD Frigidaire/electric Range
Frigidaire GLES389EQE Frigidaire/electric Range
Frigidaire GLES389ESA Frigidaire/electric Range
Frigidaire GLES389ESB Frigidaire/electric Range
Frigidaire GLES389ESC Frigidaire/electric Range
Frigidaire GLES389ESD Frigidaire/electric Range
Frigidaire GLES389ESE Frigidaire/electric Range
Frigidaire GLES389FBA Frigidaire/electric Range
Frigidaire GLES389FBB Frigidaire/electric Range
Frigidaire GLES389FBC ELECTRIC RANGE
Frigidaire GLES389FBD ELECTRIC RANGE
Frigidaire GLES389FBE ELECTRIC RANGE
Frigidaire GLES389FBF ELECTRIC RANGE
Frigidaire GLES389FQA Frigidaire/electric Range
Frigidaire GLES389FQB Frigidaire/electric Range
Frigidaire GLES389FSA Frigidaire/electric Range
Frigidaire GLES389FSB Frigidaire/electric Range
Frigidaire GLES389FSC ELECTRIC RANGE
Frigidaire GLES389FSD ELECTRIC RANGE
Frigidaire GLES389FSE ELECTRIC RANGE
Frigidaire GLET1031CS0 Frigidaire/laundry Center
Frigidaire GLET1031FS0 Frigidaire/laundry Center
Frigidaire GLET1031FS1 LAUNDRY CENTER
Frigidaire GLET1031FS2 LAUNDRY CENTER
Frigidaire GLET1031FS4 LAUNDRY CENTER
Frigidaire GLET1041AS0 Lc - Frig Gallery
Frigidaire GLET1041AS1 Lc - Frig Gallery
Frigidaire GLET1041AS2 Frigidaire/laundrycenter
Frigidaire GLET1142CS0 Frigidaire/laundry Center
Frigidaire GLET1142FS0 Frigidaire/laundry Center
Frigidaire GLET1142FS1 LAUNDRY CENTER
Frigidaire GLET1142FS2 LAUNDRY CENTER
Frigidaire GLFC1326FW0 Frigidaire/freezer
Frigidaire GLFC1326FW1 Frigidaire/freezer
Frigidaire GLFC1326FW2 FREEZER
Frigidaire GLFC1326FW3 FREEZER
Frigidaire GLFC1526FW0 Frigidaire/freezer
Frigidaire GLFC1526FW1 Frigidaire/freezer
Frigidaire GLFC1526FW2 FREEZER
Frigidaire GLFC1526FW3 FREEZER
Frigidaire GLFC1526FW4 FREEZER
Frigidaire GLFC1526FW5 FREEZER
Frigidaire GLFC1526FW6 FREEZER
Frigidaire GLFC1526FW7 FREEZER
Frigidaire GLFC2027FW0 Frigidaire/freezer
Frigidaire GLFC2027FW1 Frigidaire/freezer
Frigidaire GLFC2027FW2 Frigidaire/freezer
Frigidaire GLFC2027FW3 Frigidaire/freezer
Frigidaire GLFC2027FW4 FREEZER
Frigidaire GLFC2027FW5 FREEZER
Frigidaire GLFC2027FW6 FREEZER
Frigidaire GLFC2528FW0 Frigidaire/freezer
Frigidaire GLFC2528FW1 Frigidaire/freezer
Frigidaire GLFC2528FW10 FREEZER
Frigidaire GLFC2528FW2 Frigidaire/freezer
Frigidaire GLFC2528FW3 Frigidaire/freezer
Frigidaire GLFC2528FW4 FREEZER
Frigidaire GLFC2528FW5 FREEZER
Frigidaire GLFC2528FW6 FREEZER
Frigidaire GLFC2528FW7 FREEZER
Frigidaire GLFC2528FW8 FREEZER
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Motor just hums quietly. Electric odor. Drum doesn't rotate woodtf Dryer Repair 0 07-04-2018 10:51 AM
Washer Motor Question -- how easy to rotate? sb4 Washer Repair 0 03-27-2016 12:58 PM
Washer arms do not rotate. Seawolf Dishwasher Repair 1 05-25-2013 10:49 AM
Maytag washer motor does not run/Drum does not rotate elaraujo Washer Repair 1 03-21-2013 03:42 PM
Motor Does Not Rotate Drum slappetito Washer Repair 5 05-19-2009 01:56 PM
