Discuss
bosch WFMC gasket pt#0066747 door seal replacement
 in
Washer Repair
Hi I fix when ever I am able to eliminated service charge. just replace door seal for bosch washer that
Appliance Repair Forum > Appliance Repair Help > Washer Repair » bosch WFMC gasket pt#0066747 door seal replacement
  #1 (permalink)
Old 08-22-2018, 03:19 PM
Junior Member
acweyh is on a distinguished road
Smile bosch WFMC gasket pt#0066747 door seal replacement
Model Number: 500+wwfmc1301uc/12   Brand: Bosch   Age: 5 - 10 years
Hi I fix when ever I am able to eliminated service charge. just replace door seal for bosch washer that was leaking. This repair is for the mechanically inclines and logical problem solver. I read all the threads and you-tubes I could find, Frankly they scared me to do this repair. BUT!!! I found that commitment of some extra time made this an easy replacement. Honestly took me 3 hrs withoutthe cleaning time.
front seal was loose so wire band and spring was hanging. Pushed boot toward inside drum looked at 12:30 position as a clock. Gap in rubber and small 1/2 moon rubber tab see. Pulling on rubber tab pulled rubber fron inner drum note location of wire spring band. Old door boot out .Part number on boot if did not already order. May be long way but less frustrating repair done this way. Remove 4 control pannel screws, lay back over top; 2 center screws are short outside 2 are longer. This exposes 2 screws at top of next piece to remove inside U shaped pannel pushes up and is removes. Remove door lock switch two screwsslideto leftto release from panel. remove 4 screws fro white part at door hinge. this exposes heavy alunimium soor hinge. Remove door for cleaning. 2 screws revieled that loosen hinge, tap on bottom of hinge to unhook it and remove for cleaning. Now main pannel can be removed, 2 screws on either side bottom, two on top that were covered by control pannel. My machine had four screws inside center bottom connected to a brace and botton of machine. remove screws and angle brace I through it out and replaced 4 screws to cut step if had to remove pannel in future, Plastic clips hold pannel in and tight, push pannel into machine and push up, make sure all clips are free beforepulling pannel forward. this exposes tilted stainless drum and weights{2}. seeing small gap between weights and inside rim where gasket and wire spring band holds it in place, my gingers are not getting in there, because of the frustration of trying to put boot on in such tight quarters I remove weight, 4 nuts 8 washers, lower thres bracket will fall out, after removing weights, reposion the thread bracket so u see how it fits. Put boot on outer edge when secure add wire spring band will tke 2 or three times but stick to it when itis seated pull onitto make sure it is secured. 1/2 moon tab 12:30 3 holes at 6 o'clock. Clean all of gook and caked on detergent and lint, oops clean edge where door boot sits on rims as well as wire /springband: expand and contract spring manybe 10 times to loosen some tention of spring ,but not enough to strech the spring and break off crud.
now replace all in reverse order until all pannel on except door and control pannel. and inner U pannel this includes door hingeand door catchlock, 9slid into spot L to R attach with two screws. Now time to put on outer door bot in place . Attach boot to outer edge when secure put wire springplant into grove, there is a indentation at 6 O'clock in rubber seal where spring goes. when i got wire in from top and springlined up with indenttion clamp whent right back on. wire and spring bands are source of frustration, but dissasembly especially weights lessens this. Reasemble restof machine and your done. Little extra work of disassembly and increase time makes this all easier than I expected. Good luck.
Related Models
Amana 500.014 COMMERCIAL MICROWAVES
Amana 500.015 COMMERCIAL MICROWAVES
Amana 500.017 COMMERCIAL MICROWAVES
Amana 500.018 COMMERCIAL MICROWAVES
Amana 500.019 COMMERCIAL MICROWAVES
Hoover 5020
Frigidaire 5050A AIR CONDITIONER
Frigidaire 5057A AIR CONDITIONER
Frigidaire 5057B AIR CONDITIONER
Frigidaire 5057C AIR CONDITIONER
Frigidaire 5057D AIR CONDITIONER
Frigidaire 5060009 FRIGIDAIRE ROOM AIR CONDITIONER
Frigidaire 5068007 AIR CONDITIONER
Frigidaire 5068007A AIR CONDITIONER
Frigidaire 5068007B AIR CONDITIONER
Frigidaire 5068A AIR CONDITIONER
Frigidaire 5069008A AIR CONDITIONER
Frigidaire 5070A AIR CONDITIONER
Frigidaire 5077A AIR CONDITIONER
Frigidaire 5077B AIR CONDITIONER
Frigidaire 5078004 AIR CONDITIONER
Frigidaire 5078004A AIR CONDITIONER
Frigidaire 5078004B AIR CONDITIONER
Frigidaire 5078A AIR CONDITIONER
Frigidaire 5078C AIR CONDITIONER
Frigidaire 5079005A AIR CONDITIONER
Amana 50A-1 ROOM AIR CONDITIONER
Amana 50A-2 ROOM AIR CONDITIONER
Amana 50A-256 ROOM AIR CONDITIONER
Amana 50S-256 ROOM AIR CONDITIONER
Hoover 51
Frigidaire 5100A AIR CONDITIONER
Frigidaire 5107B AIR CONDITIONER
Frigidaire 5117A ROOM AIR CONDITIONER
Frigidaire 5118A AIR CONDITIONER
Frigidaire 5119A AIR CONDITIONER
Frigidaire 5121A AIR CONDITIONER
Frigidaire 5127A AIR CONDITIONER
Frigidaire 5128A AIR CONDITIONER
Frigidaire 5129A AIR CONDITIONER
Hoover 5130
Frigidaire 5130009B Frg(v0) / Room Air Conditioner
Hoover 5131
Frigidaire 5131A AIR CONDITIONER
Frigidaire 5132001 FRIGIDAIRE ROOM AIR CONDITIONER
Frigidaire 5132001A Frg(v0) / Room Air Conditioner
Hoover 5137
Frigidaire 5137006A AIR CONDITIONING 5200 B.T.U.
Frigidaire 5137007E1 AIR CONDITIONER
Frigidaire 5138007 FRIGIDAIRE AIR CONDITIONER
Frigidaire 5138007E AIR CONDITIONER
Frigidaire 5138007G1 AIR CONDITIONER
Frigidaire 5139008 FRIGIDAIRE AIR CONDITIONER
Frigidaire 5139008A FRIGIDAIRE AIR CONDITIONER
Frigidaire 5139008E1 AIR CONDITIONER
Frigidaire 5139A AIR CONDITIONER
Hoover 5140
Frigidaire 5144000 AIR CONDITIONER
Frigidaire 5144000B AIR CONDITIONER
Frigidaire 5145001 WESTINGHOUSE AIR CONDITIONER
Frigidaire 5145001B AIR CONDITIONER
Hoover 5146
Frigidaire 5146002 AIR CONDITIONER
Frigidaire 5146002A AIR CONDITIONER
Frigidaire 5147003 FRIGIDAIRE AIR CONDITIONER
Hoover 5148
Frigidaire 5148004A AIR CONDITIONER
Frigidaire 5148004E FRIGIDAIRE ROOM AIR CONDITIONER
Frigidaire 5149A AIR CONDITIONER
Amana 515.000 MWAVE - FAMILY SIZE (60 HZ)
Hoover 5150
Frigidaire 5154007 AIR CONDITIONER
Hoover 5158
Hoover 5158-01
Frigidaire 5159B AIR CONDITIONER
Hoover 5160
Frigidaire 5164004 AIR CONDITIONER
Frigidaire 5167A AIR CONDITIONER
Frigidaire 5167B AIR CONDITIONER
Hoover 5168
Hoover 5168-01
Frigidaire 5169B AIR CONDITIONER
Frigidaire 5174001 AIR CONDITIONER
Frigidaire 5174001B AIR CONDITIONER
Frigidaire 5176003A ROOM AIR CONDITIONER
Frigidaire 5177004A AIR CONDITIONER
Frigidaire 5177004B AIR CONDITIONER
Frigidaire 5178A AIR CONDITIONER
Frigidaire 5179A AIR CONDITIONER
Frigidaire 5179B AIR CONDITIONER
Frigidaire 5180004 WESTINGHOUSE AIR CONDITIONER
Frigidaire 5180004A AIR CONDITIONER
Frigidaire 5187A AIR CONDITIONER
Frigidaire 5187B AIR CONDITIONER
Frigidaire 5187C AIR CONDITIONER
Frigidaire 5193004 AIR CONDITIONER
Frigidaire 5193004A AIR CONDITIONER
Frigidaire 5193004B AIR CONDITIONER
Frigidaire 5195006 FRIGIDAIRE AIR CONDITIONER
Frigidaire 5195006A AIR CONDITIONER
Frigidaire 5197A AIR CONDITIONER
Frigidaire 5198A AIR CONDITIONER
Frigidaire 5198B AIR CONDITIONER
Frigidaire 5198C AIR CONDITIONER
Frigidaire 5198G AIR CONDITIONER
Magic Chef 51FA-1K RANGE- D/I STD GAS
Magic Chef 51FA-1KXS-ON RANGE- D/I STD GAS
Magic Chef 51FA-2KLX-ON RANGE- D/I CONT CLEAN GAS
Magic Chef 51FA-2KW RANGE- D/I STD GAS
Magic Chef 51FA-2KW-BS RANGE- D/I STD GAS
Magic Chef 51FA-2KX-ON RANGE- D/I STD GAS
Magic Chef 51FA-2KXS-ON RANGE- D/I STD GAS
Magic Chef 51FK-2KLX-64 RANGE- D/I CONT CLEAN GAS
Magic Chef 51FK-2KLX-ON RANGE- D/I CONT CLEAN GAS
Magic Chef 51FN-1K RANGE- D/I STD GAS
Magic Chef 51FN-1KX RANGE- D/I STD GAS
Magic Chef 51FN-2KLX-ON RANGE- D/I CONT CLEAN GAS
Magic Chef 51FN-2KW RANGE- D/I STD GAS
Magic Chef 51FN-2KW-BS RANGE- D/I STD GAS
Magic Chef 51FN-2KX-ON RANGE- D/I STD GAS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Deep Freezer Lid Gasket/Seal Replacement Keystone34 Refrigerator & Freezer Repair 0 07-24-2017 10:56 AM
Bosch Door seal replacement Printerman 21 Dishwasher Repair 0 08-05-2011 11:38 AM
Bosch dishwasher door seal replacement jmarshj Dishwasher Repair 0 06-16-2010 05:25 PM
New Door gasket won't seal garthpro Refrigerator & Freezer Repair 4 12-20-2007 03:34 PM
Where does this gasket go? (seal replacement) g3_ultra Washer Repair 0 09-01-2007 10:09 AM
