Discuss
Ge washer wonít always drain and spin
 in
Washer Repair
Iíve recently just moved and up until that point my washer didnít have one issue. But now it will wash
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Ge washer wonít always drain and spin
  #1 (permalink)
Old 07-09-2018, 05:05 AM
Junior Member
K.socha14 is on a distinguished road
Default Ge washer wonít always drain and spin
Brand: GE   Age: 1 - 5 years
Iíve recently just moved and up until that point my washer didnít have one issue. But now it will wash and only sometimes drain and spin. If I put in a large load, it wonít drain and spin at all so I only do medium sized loads and even then it doesnít always drain and spin and Iíll have to take something out and then put it on the drain and spin cycle for it to work.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer won't spin in Normal cycle, but will if set to Drain and Spin AlisonJ Washer Repair 0 06-01-2018 07:17 AM
Washer will drain but not spin coaco Washer Repair 3 01-30-2013 04:31 PM
washer does not spin, fills up and drain the water nornal but do not spin leaderman Washer Repair 0 10-04-2010 02:28 PM
My Hotpoint washer won't drain or spin, but it will if I drain the hose by gravity? ks_becker Washer Repair 0 08-10-2010 10:25 AM
washer will not drain for 1st spin cycle. Does finish with spin dry tec6422 Washer Repair 1 01-23-2009 07:44 AM
