Discuss
"Repaired" Centennial not agitating? Flashing red light.
 in
Washer Repair
My top loading Maytag wasn't agitating, sounded like a jet engine and had sprayed brown liquid (not oily, though) from
Appliance Repair Forum > Appliance Repair Help > Washer Repair » "Repaired" Centennial not agitating? Flashing red light.
  #1 (permalink)
Old 07-03-2018, 07:22 AM
Junior Member
gvbill is on a distinguished road
Post "Repaired" Centennial not agitating? Flashing red light.
Model Number: MVWC400XW3   Brand: Maytag   Age: 5 - 10 years
My top loading Maytag wasn't agitating, sounded like a jet engine and had sprayed brown liquid (not oily, though) from the gearcase. Fault codes were F7E5 and F7E1. Was going to replace splutch but there is no signs of wear or play. I replaced the gearcase and actuator. I also have a replacement harns-wire if necessary. (The replacement gearcase came with a plastic drive hub and a plastic clip to lock in the inner tub to the drive shaft. The original had the metal drive hub, drive block and spanner nut, but AppliancePartsPros confirmed the replacement gearcase was the appropriate replacement for my model.) Once reassembled, I recalibrated, which I assume went fine. Tried a light load but machine has up to a minute delay between cycles and cycle indicator lights don't seem to align with what the washer is doing. Ultimately, unit stopped without spinning and red lid lock light flashed. Did two text cycles: first one stopped after wash/rinse lights were on and red light continued flashing and could not be cancelled (I had to wait several minutes for the machine to cancel). Second one ran through everything ok. Both times there was a loud buzzing sound when the washer light was activated. Initially is was short, repeated buzzes, then an extended buzz for a few seconds. Checked faults: F2E1 and F7E1. The tub spins fine (if a bit of wobble). I'm wondering if the agitator is not spinning. Is the replaces gearcase (W11132267) in fact the proper one?
Related Models
Maytag MVWC450WW0 AUTOMATIC WASHER
Maytag MVWC500VW0 AUTOMATIC WASHER
Maytag MVWC500VW1 AUTOMATIC WASHER
Maytag MVWC5ESXW0 AUTOMATIC WASHER
Maytag MVWC6ESWW0 AUTOMATIC WASHER
Maytag MVWC6ESWW1 AUTOMATIC WASHER
Maytag MVWC700VJ0 AUTOMATIC WASHER
Maytag MVWC700VJ1 AUTOMATIC WASHER
Maytag MVWC700VW0 AUTOMATIC WASHER
Maytag MVWC700VW1 AUTOMATIC WASHER
Maytag MVWC7ESWW0 AUTOMATIC WASHER
Maytag MVWX500XL0 AUTOMATIC WASHER
Maytag MVWX500XW0 AUTOMATIC WASHER
Maytag MVWX550XW0 AUTOMATIC WASHER
Maytag MVWX600XW0 AUTOMATIC WASHER
Maytag MVWX700XL0 AUTOMATIC WASHER
Maytag MVWX700XW0 AUTOMATIC WASHER
Whirlpool MW1000XP0 Microwaves*
Whirlpool MW1000XP1 Microwaves*
Whirlpool MW1000XS0 MICROWAVE
Whirlpool MW1000XS1 Microwaves*
Whirlpool MW1000XW0 Microwaves*
 MW1030BA MWAVE- CNTRTP / STAND ALONE
 MW1030SB MWAVE- CNTRTP / STAND ALONE
 MW1030SB/XAA MWAVE- CNTRTP / STAND ALONE
 MW1030WA MWAVE- CNTRTP / STAND ALONE
 MW1040BC MWAVE- CNTRTP / STAND ALONE
 MW1040BC/XAA MWAVE- CNTRTP / STAND ALONE
 MW1040WC MWAVE- CNTRTP / STAND ALONE
 MW1040WC/XAA MWAVE- CNTRTP / STAND ALONE
 MW1080STA MWAVE- CNTRTP / STAND ALONE
 MW1135WB MWAVE- CNTRTP / STAND ALONE
 MW1135WB/XAA MWAVE- CNTRTP / STAND ALONE
 MW1150WA MWAVE- CNTRTP / STAND ALONE
Whirlpool MW1200XP0 Microwaves*
Whirlpool MW1200XP1 Microwaves*
Whirlpool MW1200XS0 Microwaves*
Whirlpool MW1200XS1 MICROWAVE
Whirlpool MW1200XW0 Microwaves*
Whirlpool MW120EXP0 Microwaves*
 MW1245BB MWAVE- CNTRTP / STAND ALONE
Whirlpool MW1500XP0 Microwaves*
Whirlpool MW1500XP1 Microwaves*
Whirlpool MW1500XS0 Microwaves*
Whirlpool MW1500XS1 Microwaves*
Whirlpool MW1500XW0 Microwaves*
Whirlpool MW1501XS1 Microwaves*
Whirlpool MW1501XW0 Microwaves*
Roper MW157 Microwave
Maytag MW29000TB0 LAUNDRY WORKSURFACE
Maytag MW29000TU0 LAUNDRY WORKSURFACE
Maytag MW29000TW0 LAUNDRY WORKSURFACE
Whirlpool MW3000XM0 Microwaves*
Whirlpool MW3000XM1 Microwaves*
Whirlpool MW3000XP0 Microwaves*
Whirlpool MW3000XP1 Microwaves*
Whirlpool MW3000XP2 Microwaves*
Whirlpool MW3200XM0 Microwave
Whirlpool MW3200XM1 Microwave
Whirlpool MW3200XP0 Microwave
Whirlpool MW3200XP1 Microwave
Whirlpool MW3200XP2 Microwave
Whirlpool MW3200XS0 Microwave
Whirlpool MW3200XW0 Microwave
Whirlpool MW3500XM0 Microwaves*
Whirlpool MW3500XM1 Microwaves*
Whirlpool MW3500XP1 Microwaves*
Whirlpool MW3500XP2 Microwaves*
Whirlpool MW3500XP3 Microwaves*
Whirlpool MW3500XS0 Microwaves*
Whirlpool MW3500XW0 Microwaves*
Whirlpool MW3520XP1 Microwaves*
Whirlpool MW3520XP2 Microwaves*
Whirlpool MW3520XP3 Microwaves*
Whirlpool MW352EXP1 Microwaves*
Whirlpool MW3600XS0 Microwaves*
Whirlpool MW3600XW0 Microwaves*
Whirlpool MW3600XW1 Microwaves*
Whirlpool MW3601XS0 Microwaves*
Whirlpool MW3601XW0 Microwaves*
Whirlpool MW3601XW1 Microwaves*
Amana MW41 MWAVE- CNTRTP / STAND ALONE
Amana MW42 MWAVE- CNTRTP / STAND ALONE
Amana MW43 MWAVE- CNTRTP / STAND ALONE
Amana MW500.000 COMMERCIAL MICROWAVES
 MW5380W MWAVE- CNTRTP / STAND ALONE
Roper MW557 Microwave
Roper MW5571 Microwaves
 MW5592W MWAVE- CNTRTP / STAND ALONE
 MW5592W/XAA MWAVE- CNTRTP / STAND ALONE
Amana MW56 MWAVE- CNTRTP / STAND ALONE
Amana MW57 MWAVE- CNTRTP / STAND ALONE
Amana MW58 MWAVE- CNTRTP / STAND ALONE
Amana MW600.000 COMMERCIAL MICROWAVES
 MW640BA MWAVE- CNTRTP / STAND ALONE
 MW640WA MWAVE- CNTRTP / STAND ALONE
Amana MW700.000 COMMERCIAL MICROWAVES
Amana MW72 MWAVE- CNTRTP / STAND ALONE
 MW730BB MWAVE- CNTRTP / STAND ALONE
 MW735WB MWAVE- CNTRTP / STAND ALONE
 MW735WB/XAA MWAVE- CNTRTP / STAND ALONE
Whirlpool MW7400XW0 Microwaves*
Whirlpool MW7500XW0 Microwaves*
 MW7695GS MWAVE- CNTRTP / STAND ALONE
Whirlpool MW8100XL0 MICROWAVE
Whirlpool MW8100XL1 MICROWAVE
Whirlpool MW8100XL2 MICROWAVE
Whirlpool MW8100XP0 MICROWAVE
Whirlpool MW8100XR0 MICROWAVE
Whirlpool MW8200XL0 Microwaves*
Whirlpool MW8200XL1 Microwaves*
Whirlpool MW8200XL2 Microwaves*
Whirlpool MW8200XP0 Microwaves*
Whirlpool MW8200XR0 Microwaves*
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch Dishwasher "Active" Light Flashing & Won't Start joy.rob53 Dishwasher Repair 6 08-23-2016 09:39 PM
GE triton profile dishwasher flashing "normal" light william1475 Dishwasher Repair 9 02-06-2016 11:12 AM
Whirlpool Imperial 11 green light flashing above "clean" Barb L. Dishwasher Repair 1 11-03-2014 02:16 AM
Kenmore dishwasher flashing "water miser" light rhj911 Dishwasher Repair 0 10-04-2013 06:34 PM
Whirlpool Quiet Partner III dead "Clean xpress" light flashing flyboy3633 Dishwasher Repair 0 07-24-2010 04:47 PM
