Discuss
F20 error on normal wash and not quick wash
 in
Washer Repair
Summary: received F20 error after cleaning/replacing drain filter and pump Brand: Whirlpool Duet Steam Model #: WFW9600TA01 Error: F20 While
Appliance Repair Forum > Appliance Repair Help > Washer Repair » F20 error on normal wash and not quick wash
  #1 (permalink)
Old 06-20-2018, 10:13 AM
Junior Member
Jsmith16 is on a distinguished road
Default F20 error on normal wash and not quick wash
Model Number: Wfw9600ta01   Brand: Whirlpool   Age: 5 - 10 years
Error: F20
While washing a load of laundry, I received an F20 error on the display panel.
I checked the tub tubbing and did not find anything that could block the drain
checked the Washer Inlet value filters and cleaned them
I replaced the water hoses with new ones and checked that there was enough pressure
I removed the washer bottom plate and cleaned the drain filter and pulled out small items including baby socks
I ran a spin/drain cycle and it looked to work fine. I ran a rinse/spin cycle and got a F20 error. I reset the washer and ran a drain/spin cycle and got a SUD error.
Checked a few more cables/tubes and everything looked in decent condition
Ran a normal cycle and got an F20 error 6 minutes in
Reset the washer and ran a drain/spin cycle, the water no longer drained
I placed my hand on the drain pump and it was vibrating just lightly and was not draining
I purchased a new drain pump and replaced this.
Rinse/spin cycle now works
Spin/Drain cycle now works every time
Clean machine cycle also now works fine
Ran normal wash cycle and in 4-8 minutes I got another F20 error
Reset the washer and spin/drain works, rinse spin works, and now quick wash works
Checked all tubes/connections again and ran normal cycle, F20 error
Tried several more cycles and the small ones work (hand wash, quick wash, etc.)
Normal, bulky, etc. all give F20 errors
Does anyone have any suggestions on what could be the problem? The wash drains fine on quick settings and it is a new pump, so I believe I have fixed the drain issues.
I was looking at the water inlet and it appears fine and was clean. With the other cycles working, I am not sure this is the issue. The pressure hose appears fine, but I plan to replace this anyway since half the machine is apart and this is an inexpensive item.
Any help would be appreciated.
Related Models
Whirlpool WFW9600TA01 AUTOMATIC WASHER
Whirlpool WFW9600TA02 AUTOMATIC WASHER
Whirlpool WFW9600TB00 AUTOMATIC WASHER
Whirlpool WFW9600TC00 AUTOMATIC WASHER
Whirlpool WFW9600TU00 AUTOMATIC WASHER
Whirlpool WFW9600TW00 AUTOMATIC WASHER
Whirlpool WFW9600TW01 AUTOMATIC WASHER
Whirlpool WFW9600TW02 AUTOMATIC WASHER
Whirlpool WFW9600TZ00 AUTOMATIC WASHER
Whirlpool WFW9640XW00 AUTOMATIC WASHER
Whirlpool WFW9700VA00 AUTOMATIC WASHER
Whirlpool WFW9700VA01 AUTOMATIC WASHER
Whirlpool WFW9700VW00 AUTOMATIC WASHER
Whirlpool WFW9700VW01 AUTOMATIC WASHER
Whirlpool WFW9750WL00 AUTOMATIC WASHER
Whirlpool WFW9750WL01 AUTOMATIC WASHER
Whirlpool WFW9750WL02 AUTOMATIC WASHER
Whirlpool WFW9750WR00 AUTOMATIC WASHER
Whirlpool WFW9750WR01 AUTOMATIC WASHER
Whirlpool WFW9750WR02 AUTOMATIC WASHER
Whirlpool WFW9750WW00 AUTOMATIC WASHER
Whirlpool WFW9750WW01 AUTOMATIC WASHER
Whirlpool WFW9750WW02 AUTOMATIC WASHER
Whirlpool WFW97HEXL0 WASHER
Whirlpool WFW97HEXL1 WASHER
Whirlpool WFW97HEXL2 AUTOMATIC WASHER
Whirlpool WFW97HEXR0 WASHER
Whirlpool WFW97HEXR1 WASHER
Whirlpool WFW97HEXR2 AUTOMATIC WASHER
Whirlpool WFW97HEXW0 WASHER
Whirlpool WFW97HEXW1 WASHER
Whirlpool WFW97HEXW2 AUTOMATIC WASHER
Amana WG1010.000 COMMERCIAL MICROWAVES
Amana WG1010.010 COMMERCIAL MICROWAVES
Amana WG1010.200 COMMERCIAL MICROWAVES
Amana WG1021.000 COMMERCIAL MICROWAVES
Amana WG1021.200 COMMERCIAL MICROWAVES
Amana WG1065.000 COMMERCIAL MICROWAVES
Amana WG1120.500 COMMERCIAL MICROWAVES
Amana WG1120.600 COMMERCIAL MICROWAVES
Amana WG1121.000 COMMERCIAL MICROWAVES
Amana WG1165.000 COMMERCIAL MICROWAVES
Amana WG1165.700 COMMERCIAL MICROWAVES
Amana WG1166.500 COMMERCIAL MICROWAVES
 WG1804R Air Conditioner
 WG1805RY6 Air Conditioner
Jenn-Air WG200 WALLOVEN- CONT CLEAN GAS
Jenn-Air WG206 WALLOVEN- CONT CLEAN GAS
Jenn-Air WG24000B WALLOVEN- STD GAS
Jenn-Air WG24000W WALLOVEN- STD GAS
Jenn-Air WG30100B WALLOVEN- S/C GAS
Jenn-Air WG30100W WALLOVEN- S/C GAS
Amana WG445.1 COMMERCIAL MICROWAVES
Amana WG445.2 COMMERCIAL MICROWAVES
 WG5200R Air Conditioner
Whirlpool WGD4750XQ0 29" GAS DRYER
Whirlpool WGD4750XQ1 29" GAS DRYER
Whirlpool WGD4800XQ0 DRYER
Whirlpool WGD4850XQ0 29" GAS DRYER
Whirlpool WGD4890XQ0 29" GAS DRYER
Whirlpool WGD4900XW0 29" GAS DRYER
Whirlpool WGD4910XQ0 29" GAS DRYER
Whirlpool WGD5000VQ1 29" GAS DRYER
Whirlpool WGD5100SQ0 29" GAS DRYER
Whirlpool WGD5100VQ0 29" GAS DRYER
Whirlpool WGD5100VQ1 29" GAS DRYER
Whirlpool WGD5200TQ0 29" GAS DRYER
Whirlpool WGD5200VQ0 29" GAS DRYER
Whirlpool WGD5200VQ1 29" GAS DRYER
Whirlpool WGD5300SQ0 29"GAS DRYER
Whirlpool WGD5300ST0 29"GAS DRYER
Whirlpool WGD5300VW0 29" GAS DRYER
Whirlpool WGD5300VW1 29" GAS DRYER
Whirlpool WGD5310SQ0 29"GAS DRYER
Whirlpool WGD5320SQ0 29"GAS DRYER
Whirlpool WGD5321SQ0 29"GAS DRYER
Whirlpool WGD5500SQ0 29"GAS DRYER
Whirlpool WGD5500ST0 29"GAS DRYER
Whirlpool WGD5500XL0 27" ELECTRIC DRYER
Whirlpool WGD5500XL1 27" ELECTRIC DRYER
Whirlpool WGD5500XW0 27" ELECTRIC DRYER
Whirlpool WGD5500XW1 27" ELECTRIC DRYER
Whirlpool WGD5510VQ0 29"GAS DRYER
Whirlpool WGD5510VQ1 29"GAS DRYER
Whirlpool WGD5520SQ0 29" GAS DRYER
Whirlpool WGD5521SQ0 29"GAS DRYER
Whirlpool WGD5530SQ0 29"GAS DRYER
Whirlpool WGD5540SQ0 29"GAS DRYER
Whirlpool WGD5540ST0 29"GAS DRYER
Whirlpool WGD5550SQ0 29" GAS DRYER
Whirlpool WGD5550ST0 29" GAS DRYER
Whirlpool WGD5550XW0 27" GAS DRYER
Whirlpool WGD5550XW1 27" GAS DRYER
Whirlpool WGD5560SQ0 29" GAS DRYER
Whirlpool WGD5590VQ0 29" GAS DRYER
Whirlpool WGD5590VQ1 29" GAS DRYER
Whirlpool WGD5600SQ0 29" GAS DRYER
Whirlpool WGD5600ST0 29" GAS DRYER
Whirlpool WGD5600VQ0 29" GAS DRYER
Whirlpool WGD5600XW0 27" GAS DRYER
Whirlpool WGD5600XW1 27" GAS DRYER
Whirlpool WGD5610XW0 27" GAS DRYER
Whirlpool WGD5610XW1 27" GAS DRYER
Whirlpool WGD5700SW0 29" GAS DRYER
Whirlpool WGD5700VH0 29" GAS DRYER
Whirlpool WGD5700VH1 29" GAS DRYER
Whirlpool WGD5700VW0 29" GAS DRYER
Whirlpool WGD5700VW1 29" GAS DRYER
Whirlpool WGD5700XL0 27" GAS DRYER
Whirlpool WGD5700XL1 27" GAS DRYER
Whirlpool WGD5700XW0 27" GAS DRYER
Whirlpool WGD5700XW1 27" GAS DRYER
Whirlpool WGD5790SQ0 29" GAS DRYER
Whirlpool WGD5790ST0 29" GAS DRYER
Whirlpool WGD5790VQ0 29" GAS DRYER
Whirlpool WGD5790VQ1 29" GAS DRYER
Whirlpool WGD5800SG0 29"GAS DRYER
Whirlpool WGD5800SW0 29"GAS DRYER
Whirlpool WGD5810SW0 29"GAS DRYER
Whirlpool WGD5820SW0 29"GAS DRYER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Normal wash and light wash flash alternating chiefgeek Dishwasher Repair 0 09-11-2017 05:33 AM
Maytag Washer- Normal, Spin & Quick Wash buttons no longer work BobG68 Washer Repair 2 06-08-2011 01:18 PM
Flashing clean light & normal wash & heavy wash buttons dalegolgert Dishwasher Repair 1 12-23-2010 08:40 AM
Quick Wash thurgo Dishwasher Repair 0 02-21-2009 06:33 PM
