Discuss
Common belt problem with a (possible?) twist
 in
Washer Repair
So yes, the belt replacement, with or without the special GE tool instructions and the videos are great but my
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Common belt problem with a (possible?) twist
  #1 (permalink)
Old 06-07-2018, 02:49 AM
Junior Member
PerplexedMonkey is on a distinguished road
Default Common belt problem with a (possible?) twist
Model Number: WLSR3000G5WW   Brand: GE   Age: 5 - 10 years
So yes, the belt replacement, with or without the special GE tool instructions and the videos are great but my issue *might* be a twist on the no spin/no agitate/replace belt topic that's so common.
Correct belt ordered (GE WH01X10302), old belt was stretched and partially shredded though it has only three grooves and the belt as a whole is much more narrow than the new belt., seemed straight-forward. Yes, the new belt is extremely tight and difficult to slowly turn into place (zip tie trick!). Got all of that. I replaced the motor a number of years ago after a flood in the cellar and reused the previous, original belt but here is where the weirdness begins after five or so years.
The new belt has six grooves that match the motor perfectly. The flywheel/drive pulley has no grooves - it's smooth all the way around its surface. The new belt appears to have an additional 1-2 mm of overlap on both the top and bottom when trying to get it onto the drive pulley and turned. Without measuring (difficult with the whole machine tilted to get my hands underneath the tub) it seems as if it's the wrong belt. Not likely - crazy talk, right?
I've managed to slowly inch the belt onto the motor and drive pulley a few times but it will not make it back around another full turn of the tub/drive pulley, regardless of how careful and gentle I am. If I didn't know better, it sorta looks like the motor pulley is not parallel to the drive pulley by 5 mm or more so the belt is ever so slightly angled and it would be no surprise for the machine to toss the belt.
Am I being looney here? I'm trying to decide, based on other part failures, as to whether or not I should pull the motor for sale/reuse and scrap the remainder or to keep at it without spending more money on it and get a used washer from craigslist or similar. $10-$15 at a laundromat has a new (to me) washer paid for in a month or so. Scrap it or keep banging away at it?
Any hints beyond "watch the videos" in order to not have to finally admit defeat?
Thanks for any pointers you may be able to offer.
Related Models
General Electric WLSR3000G5WW WASHER
General Electric WLSR3000G6WW WASHER
Frigidaire WLW0 Frg(v1) / 27 " Washer
Frigidaire WLW1 Frg(v1) / 27 " Washer
General Electric WLW1500BAL Washer
General Electric WLW1500BBL Washer
General Electric WLW1500BCL Washer
General Electric WLW1500BNL Washer
General Electric WLW1500RBL Washer
General Electric WLW2330BAL Washer
General Electric WLW2500BAL Washer
General Electric WLW2500BBL Washer
General Electric WLW2500BCL Washer
General Electric WLW2500BNL Washer
General Electric WLW2500RBL Washer
Frigidaire WLW3 Frg(v1) / 27 " Washer
General Electric WLW3000BAL Washer
General Electric WLW3000BBL Washer
General Electric WLW3000BCL Washer
General Electric WLW3000BNL Washer
General Electric WLW3000RBL Washer
General Electric WLW3000SALWH Washer
General Electric WLW3200SALWH Washer
General Electric WLW3200SBLWH Washer
General Electric WLW3300BBL Washer
General Electric WLW3300BCL Washer
General Electric WLW3300BNL Washer
General Electric WLW3300RBL Washer
General Electric WLW3310BBL Washer
General Electric WLW3310BCL Washer
General Electric WLW3310BNL Washer
General Electric WLW3310RBL Washer
General Electric WLW3400SALAD Washer
General Electric WLW3400SALWH Washer
General Electric WLW3400SBLAD Washer
General Electric WLW3400SBLWH Washer
General Electric WLW3440SALAD Washer
General Electric WLW3440SALWH Washer
General Electric WLW3440SBLAD Washer
General Electric WLW3440SBLWH Washer
General Electric WLW3500BAL Washer
General Electric WLW3500BBL Washer
General Electric WLW3500BCL Washer
General Electric WLW3500BNL Washer
General Electric WLW3500RBL Washer
General Electric WLW3505BAL Washer
General Electric WLW3505BBL Washer
General Electric WLW3600BBL Washer
General Electric WLW3600BCL Washer
General Electric WLW3600BNL Washer
General Electric WLW3600SALAD Washer
General Electric WLW3600SALWH Washer
General Electric WLW3600SBLAD Washer
General Electric WLW3600SBLWH Washer
General Electric WLW3610SALWW Washer
General Electric WLW3610SBLWW Washer
General Electric WLW3700BAL Washer
General Electric WLW3700BBL Washer
General Electric WLW3700BCL Washer
General Electric WLW3700BNL Washer
General Electric WLW3700BPL Washer
General Electric WLW3700RBL
General Electric WLW3700RBLWW Washer
General Electric WLW3750BAL Washer
General Electric WLW3750BBL Washer
General Electric WLW3750BNL Washer
General Electric WLW3750RBL Washer
General Electric WLW3760RBLWW Washer
General Electric WLW3800SALAD Washer
General Electric WLW3800SALWH Washer
General Electric WLW3800SBLAD Washer
General Electric WLW3800SBLWH Washer
General Electric WLW3810SALWW Washer
General Electric WLW3810SBLWW Washer
General Electric WLW4700BAL Washer
General Electric WLW4700BBL Washer
General Electric WLW4700BCL Washer
General Electric WLW4700BNL Washer
General Electric WLW5700BAL Washer
General Electric WLW5700BBL Washer
General Electric WLW5700BCL Washer
General Electric WLW5700BNL Washer
General Electric WLW5700RBL Washer
General Electric WLW5900MAL Washer
General Electric WLW5900MNL Washer
Frigidaire WLXG42RED0 Wwh(v1) / Laundry Center
White Westinghouse WLXG42RED1 Laundry Center - W.westinghouse
Frigidaire WLXG42RED3
Frigidaire WLXG42REW0 Wwh(v2) / Laundry Center
White Westinghouse WLXG42REW1 Laundry Center - W.westinghouse
White Westinghouse WLXG42REW2 Laundry Center - West/famsa
White Westinghouse WLXG42REW3 White Westinghouse/laundry Center
White Westinghouse WLXG42REW4 White Westinghouse/laundry Center
White Westinghouse WLXG42REW5 White Westinghouse/laundry Center
General Electric WLXR1020T2WB Washer
General Electric WLXR1020T3WB Washer
General Electric WLXR1020T4WB Washer
General Electric WLXR1020T5WB Washer
General Electric WLXR1020T8WB Washer
General Electric WLXR1020TAWB Washer
 WM0001HTMA Washer
 WM0532HW Washer
 WM0642HW Washer
 WM0742HGA Washer
 WM0742HWA Washer
 WM1333HW Washer
 WM1812CW Washer
 WM1814CW Washer
 WM1815CS Washer
 WM1832CW Washer
 WM2010CW Washer
 WM2016CW Washer
 WM2032HS Washer
 WM2032HW Washer
 WM2042CW Washer
 WM2075CW Washer
 WM2077CW Washer
 WM2101HW Washer
 WM2233HD Washer
 WM2233HS Washer
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer agitater doesn't twist Bessie Kelly Washer Repair 2 08-11-2011 02:36 PM
Common Problem? GE Washer won't spin/agitate Katie1011 Washer Repair 6 09-13-2010 07:38 PM
Kitchenaid F5:E3 with a twist... jaredpgh Oven Repair (including Ranges and Cooktops) 3 06-10-2010 05:44 AM
Another No Drainer (GE Triton) But With a Twist outofmyleague Dishwasher Repair 3 12-22-2008 03:22 PM
