Discuss
Motor overheats when spin cycle begins
 in
Washer Repair
I have a big problem with my ancient, but faithful, Maytag washer. When the problem started I had a load
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Motor overheats when spin cycle begins
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 05-18-2018, 04:56 PM
Junior Member
Harley Monster is on a distinguished road
Default Motor overheats when spin cycle begins
Model Number: LA712   Brand: Maytag   Age: More than 10 years
When the problem started I had a load going and in the spin cycle I heard loud screeching and the smell of rubber burning.
I replaced the belts and the brake and the motor would cut out (overheat) at the beginning of the spin cycle.
I replaced the motor, but the motor still cuts out due to overheat. I replaced the mounting stem and boot along with a tub bearing kit and the motor still overheats after about 10 seconds into the spin cycle. The agitation cycle works perfectly and has strong action, the motor never cuts out in the wash cycle.
The pulley turns easily both directions by hand. To check out the pump I took both belts off and put the pump belt back on, the washer drains as it should. With both belts on I have noticed there is no pump action before the motor cuts out in the spin cycle. I tried running the washer with only the main drive belt hooked up, with no water in the machine and the motor still overheats and shuts down as the spin cycle starts.
A couple times the washer would go into the spin cycle and run all the way through, one thing I have noticed is as the spin basket speeds up it reaches a speed where there is a click at the motor and the spin increases in speed. When this happens, when I get that click, the washer will complete the spin cycle. This has happened only a couple time in about 7 or 8 tries.
I am at a loss, I have watched nearly every repair video on this site as well as YouTube and I can't figure this out. I feel I am close and I don't want to give up because this has been a great machine (first repair in over 30 years) plus I have so much money in it in parts I don't want to give up now.
I need help!
Related Models
Maytag LA712 WASHER-TOP LOADING
Maytag LA7300 WASHER-TOP LOADING
Maytag LA7400 WASHER-TOP LOADING
Whirlpool LA7400XMW0
Whirlpool LA7400XMW1
Whirlpool LA7400XMW2
Whirlpool LA7400XMW3
Whirlpool LA7450XMW0
Whirlpool LA7450XMW1
Whirlpool LA7460XMW0
Maytag LA7500 WASHER-TOP LOADING
Maytag LA7500S WASHER-TOP LOADING
Maytag LA7500W WASHER-TOP LOADING
Whirlpool LA7500XKW0
Frigidaire LA750EXD3 Wwh(v6) / Washer
Frigidaire LA750EXF3 Wwh(v7) / Washer
Frigidaire LA750EXH3 Wwh(v8) / Washer
Frigidaire LA750EXV3 Wwh(v9) / Washer
Frigidaire LA750EXW3 Wwh(v10) / Washer
Frigidaire LA750MXD1 Wwh(v2) / 27 " Washer
Frigidaire LA750MXW1 Wwh(v1) / 27 " Washer
Whirlpool LA7680XKW1
Whirlpool LA7680XKW2
Whirlpool LA7680XMW0 Washers*
Whirlpool LA7680XPW0
Whirlpool LA7680XPW1
Whirlpool LA7680XPW2
Whirlpool LA7680XSW0
Whirlpool LA7680XSW1
Whirlpool LA7680XTF0
Whirlpool LA7680XTF1
Whirlpool LA7680XTG0
Whirlpool LA7680XTG1
Whirlpool LA7680XTM0
Whirlpool LA7680XTM1
Whirlpool LA7680XTN0
Whirlpool LA7680XTN1
Whirlpool LA7680XTW0
Whirlpool LA7680XTW1
Whirlpool LA7681XSW0
Whirlpool LA7681XSW1
Whirlpool LA7685XKW1
Whirlpool LA7685XPW0
Whirlpool LA7685XPW1
Whirlpool LA7685XPW2
Whirlpool LA7700XPW0
Whirlpool LA7700XPW1
Whirlpool LA7700XPW3
Whirlpool LA7700XPW4
Whirlpool LA7700XPW5
Whirlpool LA7700XSW0
Whirlpool LA7700XWN0
Whirlpool LA7700XWW0
Whirlpool LA7780XSW0
Whirlpool LA7780XSW1 Washers*
Whirlpool LA7780XSW2
Maytag LA7800 WASHER-TOP LOADING
Whirlpool LA7800XKW2
Whirlpool LA7800XMW0
Whirlpool LA7800XPW0
Whirlpool LA7800XPW1 Washers*
Whirlpool LA7800XSF2 AUTOMATIC WASHER
Whirlpool LA7800XSG2 AUTOMATIC WASHER
Whirlpool LA7800XSM2 AUTOMATIC WASHER
Whirlpool LA7800XSN1 AUTOMATIC WASHER
Whirlpool LA7800XSN2 AUTOMATIC WASHER
Whirlpool LA7800XSW0
Whirlpool LA7800XSW1
Whirlpool LA7800XSW2
Whirlpool LA7800XTF0 AUTOMATIC WASHER
Whirlpool LA7800XTF1 AUTOMATIC WASHER
Whirlpool LA7800XTG0 AUTOMATIC WASHER
Whirlpool LA7800XTG1 AUTOMATIC WASHER
Whirlpool LA7800XTM0 AUTOMATIC WASHER
Whirlpool LA7800XTM1 AUTOMATIC WASHER
Whirlpool LA7800XTN0 AUTOMATIC WASHER
Whirlpool LA7800XTN1 AUTOMATIC WASHER
Whirlpool LA7800XTW0
Whirlpool LA7800XTW1
Whirlpool LA7801XTF0
Whirlpool LA7801XTG0
Whirlpool LA7801XTM0
Whirlpool LA7801XTN0
Whirlpool LA7801XTW0
Whirlpool LA7899XPW3
Whirlpool LA7900XPW1
Whirlpool LA7900XSW0
Whirlpool LA7900XSW1
Whirlpool LA7900XSW2
Whirlpool LA7900XTF0
Whirlpool LA7900XTG0
Whirlpool LA7900XTG1
Whirlpool LA7900XTM0
Whirlpool LA7900XTN0
Whirlpool LA7900XTN1
Whirlpool LA7900XTW0
Whirlpool LA7900XTW1
Whirlpool LA7980XSW0
Frigidaire LA800AXD1 Wwh(v2) / 27 " Washer
Frigidaire LA800AXD2 Wwh(v2) / 27 " Washer
Frigidaire LA800AXW1 Wwh(v1) / 27 " Washer
Frigidaire LA800AXW2 Wwh(v1) / 27 " Washer
Frigidaire LA800JXD4 Wwh(v1) / Washer
Frigidaire LA800JXD5 Wwh(v1) / Top Load Washer
Frigidaire LA800JXF4 Wwh(v2) / Washer
Frigidaire LA800JXH4 Wwh(v3) / Washer
Frigidaire LA800JXH5 Wwh(v2) / Top Load Washer
Frigidaire LA800JXV4 Wwh(v4) / Washer
Frigidaire LA800JXW4 Wwh(v5) / Washer
Frigidaire LA800JXW5 Wwh(v3) / Top Load Washer
Frigidaire LA800MXD1 Wwh(v9) / 27 " Washer
Frigidaire LA800MXD2 Wwh(v9) / 27 " Washer
Frigidaire LA800MXH1 Wwh(v8) / 27 " Washer
Frigidaire LA800MXH2 Wwh(v8) / 27 " Washer
Frigidaire LA800MXW1 Wwh(v7) / 27 " Washer
Frigidaire LA800MXW2 Wwh(v7) / 27 " Washer
Maytag LA806 WASHER-TOP LOADING
Maytag LA806S WASHER-TOP LOADING
Maytag LA810 WASHER-TOP LOADING
Maytag LA8100 WASHER-TOP LOADING
  #2 (permalink)
Old 05-21-2018, 10:56 AM
Junior Member
Default
To continue, I have now disassembled the washer again, took the spin tub out, took the spanner nut off the stem, turned the pulley by hand and it turned easily in both directions. I put the nut back on hand tight with the spanner wrench, gave it one light tap with a hammer and put in the set screw then ran the machine. The washer ran in the spin cycle without a problem. I next put the spin tub back in taking caution it was centered and put the nut back on and ran the spin cycle, again no problem. I ran it through 6 or 8 complete spin cycles and it worked every time. I then ran the washer on the lowest water level, it worked perfectly in the agitation cycle, but when it came time to spin the motor overheated before the spin tub came up to speed.
I am thinking perhaps the centrifugal switch in the new motor might not be set correctly. I will try to troubleshoot the switch.
Any other suggestions would be appreciated.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Dishwasher begins wash cycle, fills and then stops tinfootoo Dishwasher Repair 1 11-02-2016 01:37 PM
Kitchenaid Dish washer begins to slowly fill up after cycle is completed inlet valve? mohunter68 Dishwasher Repair 1 01-08-2013 09:38 PM
Washer begins cycle then stops.. It won't go into diagnostic mode to determine probe frankiem Washer Repair 1 10-11-2012 03:41 PM
Cycle Never Begins cborden Dishwasher Repair 0 06-06-2009 04:27 PM
Washer won't spin, and motor overheats rwstern Washer Repair 3 08-30-2008 10:56 PM
