Discuss
Oldkenmoreuser
 in
Washer Repair
My washer was running a load and then I noticed it was making a weird sound. Easily found the motor
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Oldkenmoreuser
  #1 (permalink)
Old 05-17-2018, 07:23 PM
Junior Member
olduser is on a distinguished road
Default Oldkenmoreuser
Model Number: 11082874120   Brand: Kenmore   Age: More than 10 years
My washer was running a load and then I noticed it was making a weird sound. Easily found the motor coupling broken and repaired. First time in 27 years of service. Kenmore model 11082874120
This got machine to fill and agitate, but it would not advance the timer. If I stopped and rotate the timer on around the cycle it would pump water and begin to spin in the appropriate place. The lid switch checks ok on continuity and stops the spin when opened as should.
I tried to clean the contacts on the timer. None of the visible ones seemed to have any corrosion. All looked clean. The small motor in the timer also checked ok for continuity. I tried a low water fill cycle but the timer would not advance while machine agitating. I then advanced timer on to the pause section of the permanent press. If I recall correctly it should pause about 10-15 minutes. I left it for over and hour and it had not moved.
If I understand correctly each component must send voltage to the timer for it to advance? Ok, the pressure switch for the water load must be working because it shut off water and began agitation.
My question is what else sends voltage to the timer for it to advance? After agitation? After drain? As machine spins etc.? Are these all the components? Then of course what voltage and where to check for it? App says it may not necessarily be the timer.
I realize Kenmore does not share wiring info, but since this is virtually a Whirlpool machine, I'm hoping someone can educate me where to follow up. I feel like I'm so close to solving this and I really want to keep my old machine. Thanks to all who take the time to read or contribute.
Related Models
Kenmore 11082874120 AUTOMATIC WASHER
Kenmore 11082874130 AUTOMATIC WASHER
Kenmore 11082874300 WASHER
Kenmore 11082874310 AUTOMATIC WASHER
Kenmore 11082874320 AUTOMATIC WASHER
Kenmore 11082874330 AUTOMATIC WASHER
Kenmore 11082874600 WASHER
Kenmore 11082874610 AUTOMATIC WASHER
Kenmore 11082874620 AUTOMATIC WASHER
Kenmore 11082874630 AUTOMATIC WASHER
Kenmore 11082874700 WASHER
Kenmore 11082874710 AUTOMATIC WASHER
Kenmore 11082874720 AUTOMATIC WASHER
Kenmore 11082874730 AUTOMATIC WASHER
Kenmore 11082874800 WASHER
Kenmore 11082874810 AUTOMATIC WASHER
Kenmore 11082874820 AUTOMATIC WASHER
Kenmore 11082874830 AUTOMATIC WASHER
Kenmore 11082880100 AUTOMATIC WASHER
Kenmore 11082880300 AUTOMATIC WASHER
Kenmore 11082880600 AUTOMATIC WASHER
Kenmore 11082880700 AUTOMATIC WASHER
Kenmore 11082880800 AUTOMATIC WASHER
Kenmore 11082881100 AUTOMATIC WASHER
Kenmore 11082881110 AUTOMATIC WASHER
Kenmore 11082881300 AUTOMATIC WASHER
Kenmore 11082881310 AUTOMATIC WASHER
Kenmore 11082881700 AUTOMATIC WASHER
Kenmore 11082881710 AUTOMATIC WASHER
Kenmore 11082881800 AUTOMATIC WASHER
Kenmore 11082881810 AUTOMATIC WASHER
Kenmore 11082882100 AUTOMATIC WASHER
Kenmore 11082882300 AUTOMATIC WASHER
Kenmore 11082882600 AUTOMATIC WASHER
Kenmore 11082882700 AUTOMATIC WASHER
Kenmore 11082882800 AUTOMATIC WASHER
Kenmore 11082883100 AUTOMATIC WASHER
Kenmore 11082883300 AUTOMATIC WASHER
Kenmore 11082883600 AUTOMATIC WASHER
Kenmore 11082883700 AUTOMATIC WASHER
Kenmore 11082883800 AUTOMATIC WASHER
Kenmore 11082884100 AUTOMATIC WASHER
Kenmore 11082884300 AUTOMATIC WASHER
Kenmore 11082884600 AUTOMATIC WASHER
Kenmore 11082884700 AUTOMATIC WASHER
Kenmore 11082884800 AUTOMATIC WASHER
Kenmore 11082891100 AUTOMATIC WASHER
Kenmore 11082891110 AUTOMATIC WASHER
Kenmore 11082891120 AUTOMATIC WASHER
Kenmore 11082891130 AUTOMATIC WASHER
Kenmore 11082891300 AUTOMATIC WASHER
Kenmore 11082891310 AUTOMATIC WASHER
Kenmore 11082891320 AUTOMATIC WASHER
Kenmore 11082891330 AUTOMATIC WASHER
Kenmore 11082891610 AUTOMATIC WASHER
Kenmore 11082891620 AUTOMATIC WASHER
Kenmore 11082891630 AUTOMATIC WASHER
Kenmore 11082891700 AUTOMATIC WASHER
Kenmore 11082891710 AUTOMATIC WASHER
Kenmore 11082891720 AUTOMATIC WASHER
Kenmore 11082891730 AUTOMATIC WASHER
Kenmore 11082891800 AUTOMATIC WASHER
Kenmore 11082891810 AUTOMATIC WASHER
Kenmore 11082891820 AUTOMATIC WASHER
Kenmore 11082891830 AUTOMATIC WASHER
Kenmore 11082892100 AUTOMATIC WASHER
Kenmore 11082892300 AUTOMATIC WASHER
Kenmore 11082892600 AUTOMATIC WASHER
Kenmore 11082892700 AUTOMATIC WASHER
Kenmore 11082892800 AUTOMATIC WASHER
Kenmore 11082979100 AUTOMATIC WASHER
Kenmore 11082979110 AUTOMATIC WASHER
Kenmore 11082979300 AUTOMATIC WASHER
Kenmore 11082979310 AUTOMATIC WASHER
Kenmore 11082979600 AUTOMATIC WASHER
Kenmore 11082979610 AUTOMATIC WASHER
Kenmore 11082979700 AUTOMATIC WASHER
Kenmore 11082979710 AUTOMATIC WASHER
Kenmore 11082979800 AUTOMATIC WASHER
Kenmore 11082979810 AUTOMATIC WASHER
Kenmore 11082980100 AUTOMATIC WASHER
Kenmore 11082980110 AUTOMATIC WASHER
Kenmore 11082980120 AUTOMATIC WASHER
Kenmore 11082980130 AUTOMATIC WASHER
Kenmore 11082980300 AUTOMATIC WASHER
Kenmore 11082980310 AUTOMATIC WASHER
Kenmore 11082980320 AUTOMATIC WASHER
Kenmore 11082980330 AUTOMATIC WASHER
Kenmore 11082980620 AUTOMATIC WASHER
Kenmore 11082980630 AUTOMATIC WASHER
Kenmore 11082980700 AUTOMATIC WASHER
Kenmore 11082980710 AUTOMATIC WASHER
Kenmore 11082980720 AUTOMATIC WASHER
Kenmore 11082980730 AUTOMATIC WASHER
Kenmore 11082980800 AUTOMATIC WASHER
Kenmore 11082980810 AUTOMATIC WASHER
Kenmore 11082980820 AUTOMATIC WASHER
Kenmore 11082980830 AUTOMATIC WASHER
Kenmore 11082982100 AUTOMATIC WASHER
Kenmore 11082982110 AUTOMATIC WASHER
Kenmore 11082982120 AUTOMATIC WASHER
Kenmore 11082982130 AUTOMATIC WASHER
Kenmore 11082982300 AUTOMATIC WASHER
Kenmore 11082982310 AUTOMATIC WASHER
Kenmore 11082982320 AUTOMATIC WASHER
Kenmore 11082982330 AUTOMATIC WASHER
Kenmore 11082982620 AUTOMATIC WASHER
Kenmore 11082982630 AUTOMATIC WASHER
Kenmore 11082982700 AUTOMATIC WASHER
Kenmore 11082982710 AUTOMATIC WASHER
Kenmore 11082982720 AUTOMATIC WASHER
Kenmore 11082982730 AUTOMATIC WASHER
Kenmore 11082982800 AUTOMATIC WASHER
Kenmore 11082982810 AUTOMATIC WASHER
Kenmore 11082982820 AUTOMATIC WASHER
Kenmore 11082982830 AUTOMATIC WASHER
Kenmore 11082983100 AUTOMATIC WASHER
Kenmore 11082983110 AUTOMATIC WASHER
Kenmore 11082983120 AUTOMATIC WASHER
Kenmore 11082983130 AUTOMATIC WASHER
  #2 (permalink)
Old 05-27-2018, 10:34 AM
Junior Member
Default
Replaced the timer and solved the problem. Works as good as new.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
