Discuss
Washer stopped and only fills water
 in
Washer Repair
Hi, I have a Whirlpool washer model LBR5432PQ0. Was working until it hit the rinse cycle and then stopped full
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer stopped and only fills water
  #1 (permalink)
Old 05-01-2018, 07:09 PM
Junior Member
ditomja is on a distinguished road
Default Washer stopped and only fills water
Model Number: LBR5432PQ0   Brand: Whirlpool   Age: More than 10 years
Hi, I have a Whirlpool washer model LBR5432PQ0. Was working until it hit the rinse cycle and then stopped full of water. There is a ticking sound coming from the timer box when the lid is closed (stops when open) and try to put it in any cycle. Pull the knob out ticking starts, push in and it stops. I made sure the drain pump is clear and the impeller is not jammed with anything. Also, I ensured the (3) hoses are not clogged. I tested the lid switch with a meter and 100% certain it works based on checking continuity. The motor coupling is fine. I removed water and started it up and puts water in. Please advise on what may be the problem. A big thanks in advance!
Related Models
Whirlpool LBR5432PQ0 AUTOMATIC WASHER
Whirlpool LBR5432PQ1 AUTOMATIC WASHER
Whirlpool LBR5432PQ2 AUTOMATIC WASHER
Whirlpool LBR5432PT0 AUTOMATIC WASHER
Whirlpool LBR5432PT1 AUTOMATIC WASHER
Whirlpool LBR5432PT2 AUTOMATIC WASHER
Whirlpool LBR6133DQ0
Whirlpool LBR6133DZ0
Whirlpool LBR6233AG0
Whirlpool LBR6233AN0
Whirlpool LBR6233AW0
Whirlpool LBR6233AW1
Whirlpool LBR6233DQ0
Whirlpool LBT6133AG0
Whirlpool LBT6133AN0
Whirlpool LBT6133AW0
Whirlpool LBT6133AW1
Whirlpool LBT6233DQ0
Whirlpool LBV5133AG0
Whirlpool LBV5133AN0
Whirlpool LBV5133AW0
Amana LC-10.000 COMMERCIAL MICROWAVES
Amana LC-10VP.000 COMMERCIAL MICROWAVES
Amana LC-14.000 COMMERCIAL MICROWAVES
Amana LC-14.001 COMMERCIAL MICROWAVES
Amana LC-14VP.000 COMMERCIAL MICROWAVES
Amana LC10EVP.000 COMMERCIAL MICROWAVES
Frigidaire LC120DH5 Frg(v2) / Laundry Center
Frigidaire LC120DL5 Frg(v3) / Laundry Center
Frigidaire LC120DW5 Frg(v1) / Laundry Center
Frigidaire LC120FH1 Frg(v3) / Laundry Center
Frigidaire LC120FL0 Frg(v2) / Laundry Center
Frigidaire LC120FL1 Frg(v2) / Laundry Center
Frigidaire LC120FW0 Frg(v1) / Laundry Center
Frigidaire LC120FW1 Frg(v1) / Laundry Center
Frigidaire LC120JL5 Frg(v1) / Laundry Center
Frigidaire LC120JW5 Frg(v2) / Laundry Center
Amana LC14EVP.000 COMMERCIAL MICROWAVES
Frigidaire LC248DH5 Frg(v2) / Laundry Center
Frigidaire LC248DL5 Frg(v3) / Laundry Center
Frigidaire LC248DW5 Frg(v1) / Laundry Center
Frigidaire LC248EH0 Frg(v2) / Laundry Center
Frigidaire LC248EL0 Frg(v3) / Laundry Center
Frigidaire LC248EW0 Frg(v1) / Laundry Center
Frigidaire LC248FL0 Frg(v2) / Laundry Center
Frigidaire LC248FW0 Frg(v1) / Laundry Center
Frigidaire LC248H1 Frg(v2) / Laundry Center
Frigidaire LC248JL6 Frg(v3) / Laundry Center
Frigidaire LC248JW6 Frg(v4) / Laundry Center
Frigidaire LC248L1 Frg(v3) / Laundry Center
Frigidaire LC248W1 Frg(v1) / Laundry Center
Frigidaire LC400RXD1 Wwh(v2) / 24 " Washer
Frigidaire LC400RXD2 Wwh(v2) / 24 " Washer
Frigidaire LC400RXD3 Wwh(v2) / 24 " Washer
Frigidaire LC400RXW1 Wwh(v1) / 24 " Washer
Frigidaire LC400RXW2 Wwh(v1) / 24 " Washer
Frigidaire LC400RXW3 Wwh(v1) / 24 " Washer
Whirlpool LC4500XKW0
Whirlpool LC4500XMW0
Whirlpool LC4500XMW1
Whirlpool LC4500XSW0
Whirlpool LC4500XTF0
Whirlpool LC4500XTG0
Whirlpool LC4500XTG1
Whirlpool LC4500XTM0
Whirlpool LC4500XTN0
Whirlpool LC4500XTN1
Whirlpool LC4500XTW0
Whirlpool LC4500XTW1
Whirlpool LC4600XKW0
Whirlpool LC4900XKW0
Whirlpool LC4900XMW0
Whirlpool LC4900XMW1
Whirlpool LC4900XSW1
Whirlpool LC4900XTF0
Whirlpool LC4900XTG0
Whirlpool LC4900XTM0
Whirlpool LC4900XTN0
Whirlpool LC4900XTW0
Whirlpool LC4900XTW1
Frigidaire LC550EXD3 Wwh(v1) / Top Loading Washer
Frigidaire LC550EXP3 Wwh(v2) / Top Loading Washer
Frigidaire LC550EXW3 Wwh(v3) / Top Loading Washer
Frigidaire LC550LXD0 Wwh(v2) / Washer
Frigidaire LC550LXD1 Wwh(v2) / Washer
Frigidaire LC550LXW0 Wwh(v1) / Washer
Frigidaire LC550LXW1 Wwh(v1) / Washer
Frigidaire LC590EXD2 Wwh(v4) / Top Loading Washer
Frigidaire LC590EXD3 Wwh(v5) / Top Loading Washer
Frigidaire LC590EXW2 Wwh(v6) / Top Loading Washer
Frigidaire LC590EXW3 Wwh(v7) / Top Loading Washer
Frigidaire LC590LXD0 Wwh(v2) / 24 " Top Load Washer
Frigidaire LC590LXD2 Wwh(v2) / 24 " Top Load Washer
Frigidaire LC590LXW0 Wwh(v1) / 24 " Top Load Washer
Frigidaire LC590LXW2 Wwh(v1) / 24 " Top Load Washer
Maytag LCBG500 RANGE- F/S STD GAS
Maytag LCBG501 RANGE- F/S STD GAS
Maytag LCCE700 WALLOVEN- S/C MWAVE ELE
Maytag LCCE701 WALLOVEN- S/C MWAVE ELE
 LCE3081ST Electric Range
 LCE30845 Electric Range
 LCE3681ST Electric Range
Whirlpool LCE4332PQ0 COMPACT AUTOMATIC WASHER
Whirlpool LCE4332PQ1 COMPACT AUTOMATIC WASHER
Frigidaire LCE441AL1 Frg(v2) / 24 " Laundry Center
Frigidaire LCE441AW1 Frg(v1) / 24 " Laundry Center
Frigidaire LCE441LL2 Frg(v1) / 24 " Laundry Center
Frigidaire LCE441LW1 Frg(v1) / 24 " Laundry Center
Frigidaire LCE441LW2 Frg(v2) / 24 " Laundry Center
Frigidaire LCE441PL0 Frg(v2) / 24 " Laundry Center
Frigidaire LCE441PL1 Frg(v2) / 24 " Laundry Center
Frigidaire LCE441PW0 Frg(v1) / 24 " Laundry Center
Frigidaire LCE441PW1 Frg(v1) / 24 " Laundry Center
Frigidaire LCE462AL1 Frg(v2) / 24 " Laundry Center
Frigidaire LCE462AW1 Frg(v1) / 24 " Laundry Center
Frigidaire LCE462LL1 Frg(v2) / 24 " Laundry Center
Frigidaire LCE462LL2 Frg(v1) / 24 " Laundry Center
Frigidaire LCE462LW1 Frg(v1) / 24 " Laundry Center
Frigidaire LCE462LW2 Frg(v2) / 24 " Laundry Center
Frigidaire LCE462PL0 Frg(v2) / 24 " Laundry Center
  #2 (permalink)
Old 05-01-2018, 10:36 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Sounds like the timer has gone bad. Unfortunately, this part has been discontinued by the manufacturer and is no longer available.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 05-06-2018, 07:13 PM
Junior Member
Default
Thanks Gene.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer starts fills with water then drains water without washing labystorm Washer Repair 0 11-13-2015 12:31 PM
Washer Fills With Water On Its Own metroid16 Washer Repair 6 05-31-2015 08:48 AM
Washer only fills with hot water, no water during rinse cycle rcmedrec1 Washer Repair 1 08-05-2011 06:28 PM
Washer fills with water and that's it marylousnews Washer Repair 3 10-12-2010 11:22 PM
Washer fills with water when OFF tballard Washer Repair 2 03-01-2010 07:43 AM
