Discuss
Maytag Washing Machine overheats during spin
 in
Washer Repair
Hi I have a Maytag LA512 washing machine. First issue I had was the transmission drive belt broke. I replaced
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Washing Machine overheats during spin
  #1 (permalink)
Old 04-21-2018, 07:44 AM
Junior Member
DaveCheck is on a distinguished road
Default Maytag Washing Machine overheats during spin
Model Number: LA512   Brand: Maytag   Age: More than 10 years
Hi
I have a Maytag LA512 washing machine. First issue I had was the transmission drive belt broke. I replaced both the transmission and pump belts. Upon trying the machine it would fill and agitate with no problems but on the spin cycle the drum would turn slowly and the water would not drain leading to the motor overheating a few seconds later. when the machine spins empty it runs with no problem. I checked the pump and the hoses for obstructions and found none. I then replaced the motor wondering if the motor had an issue. Is there anything else I should check?
Dave
Related Models
Maytag LA512 WASHER-TOP LOADING
Maytag LA512S WASHER-TOP LOADING
Frigidaire LA515LXD1 Wwh(v2) / Top Load Washer
Frigidaire LA515LXW1 Wwh(v1) / Top Load Washer
Whirlpool LA5200XTF0
Whirlpool LA5200XTF1
Whirlpool LA5200XTG0
Whirlpool LA5200XTG1
Whirlpool LA5200XTM0
Whirlpool LA5200XTM1
Whirlpool LA5200XTN0
Whirlpool LA5200XTN1
Whirlpool LA5200XTW0 WASHER
Whirlpool LA5200XTW1 WASHER
Whirlpool LA5243XYN0
Whirlpool LA5243XYN1
Whirlpool LA5243XYW0
Whirlpool LA5243XYW1
Whirlpool LA5280XTF0
Whirlpool LA5280XTF1
Whirlpool LA5280XTG0
Whirlpool LA5280XTG1
Whirlpool LA5280XTM0
Whirlpool LA5280XTM1
Whirlpool LA5280XTN0
Whirlpool LA5280XTN1
Whirlpool LA5280XTW0
Whirlpool LA5280XTW1
Whirlpool LA5300XKW0
Whirlpool LA5300XKW1
Whirlpool LA5300XMW0
Whirlpool LA5300XMW1
Whirlpool LA5300XPW0
Whirlpool LA5300XPW1
Whirlpool LA5300XPW2
Whirlpool LA5300XPW3
Whirlpool LA5300XPW4
Whirlpool LA5300XPW5
Whirlpool LA5300XSF1 AUTOMATIC WASHERS
Whirlpool LA5300XSF2 AUTOMATIC WASHER
Whirlpool LA5300XSG1 AUTOMATIC WASHERS
Whirlpool LA5300XSG2 AUTOMATIC WASHER
Whirlpool LA5300XSM1 AUTOMATIC WASHERS
Whirlpool LA5300XSM2 AUTOMATIC WASHER
Whirlpool LA5300XSN0 AUTOMATIC WASHER
Whirlpool LA5300XSN1 AUTOMATIC WASHERS
Whirlpool LA5300XSN2 AUTOMATIC WASHER
Whirlpool LA5300XSW0
Whirlpool LA5300XSW1
Whirlpool LA5300XSW2
Whirlpool LA5300XTF0 AUTOMATIC WASHER
Whirlpool LA5300XTF1 AUTOMATIC WASHER
Whirlpool LA5300XTG0 AUTOMATIC WASHER
Whirlpool LA5300XTG1 AUTOMATIC WASHER
Whirlpool LA5300XTM0 AUTOMATIC WASHER
Whirlpool LA5300XTM1 AUTOMATIC WASHER
Whirlpool LA5300XTN0 AUTOMATIC WASHER
Whirlpool LA5300XTN1 AUTOMATIC WASHER
Whirlpool LA5300XTW0
Whirlpool LA5300XTW1
Whirlpool LA5310XPW0
Whirlpool LA5310XSW0
Whirlpool LA5311XPW3
Whirlpool LA5311XPW4
Whirlpool LA5311XPW5
Whirlpool LA5320XTF0
Whirlpool LA5320XTG0
Whirlpool LA5320XTM0
Whirlpool LA5320XTN0
Whirlpool LA5320XTW0
Whirlpool LA5330XSW0
Whirlpool LA5330XSW1
Whirlpool LA5330XTF0
Whirlpool LA5330XTG0
Whirlpool LA5330XTM0
Whirlpool LA5330XTN0
Whirlpool LA5330XTW0
Whirlpool LA5360XSW0
Whirlpool LA5360XSW1
Whirlpool LA5360XTF0
Whirlpool LA5360XTG0
Whirlpool LA5360XTM0
Whirlpool LA5360XTN0
Whirlpool LA5360XTW0
Whirlpool LA5380XMW0
Whirlpool LA5380XPW0
Whirlpool LA5380XPW1
Whirlpool LA5380XPW2
Whirlpool LA5380XSW0
Whirlpool LA5380XSW1
Whirlpool LA5380XTF0
Whirlpool LA5380XTF1
Whirlpool LA5380XTG0
Whirlpool LA5380XTG1
Whirlpool LA5380XTM0
Whirlpool LA5380XTM1
Whirlpool LA5380XTN0
Whirlpool LA5380XTN1
Whirlpool LA5380XTW0
Whirlpool LA5380XTW1
Whirlpool LA5381XXF0
Whirlpool LA5381XXF1
Whirlpool LA5381XXG0
Whirlpool LA5381XXG1
Whirlpool LA5381XXM0
Whirlpool LA5381XXM1
Whirlpool LA5381XXN0
Whirlpool LA5381XXN1
Whirlpool LA5381XXW0
Whirlpool LA5381XXW1
Whirlpool LA5400XMW0
Whirlpool LA5400XMW1
Whirlpool LA5400XMW2
Whirlpool LA5400XMW3
Whirlpool LA5400XPW0
Whirlpool LA5400XPW1
Whirlpool LA5400XPW3
Whirlpool LA5400XPW5
Whirlpool LA5400XSW0
Whirlpool LA5400XSW1
  #2 (permalink)
Old 05-22-2018, 02:26 PM
Junior Member
Harley Monster is on a distinguished road
Default
Dave, this is exactly the problem I am having with my Maytag LA712. I have changed the motor, the brake, the mounting stem and boot and a tub bearing kit.
I can run the machine dry with both belts and the washer will spin the way it should. I have run the machine with only the pump belt and it will pump the way it should, but if I run the machine at the lowest water level and no clothes the motor overheats before the pump can pump. The water pump is a little stiff when turned by hand, but I wouldn't think this would overheat the 1/2 HP motor. My water pump also has a crack in it so it should be replaced, but I hesitate to spend more money on this machine if it won't fix it.
Dave, I am hoping you fixed your machine, if so, would you please let me know what your solution was.
Thanks!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Bravos Washing Machine wont Spin stevenL Washer Repair 0 07-08-2014 09:29 PM
Maytag washing machine drum does not spin Bruce Kile Washer Repair 8 01-17-2011 08:47 AM
Maytag Washing machine will not spin water out schrades712 Washer Repair 1 10-08-2010 02:15 PM
Maytag Neptune washing machine doesn't spin Jeneanne Washer Repair 14 08-16-2010 07:25 AM
Maytag washing PAV2300 machine will not agitate BUT will spin pperovich Washer Repair 3 08-11-2009 03:11 PM
