Discuss
LG WM8000HWA Leak Outer Tub Seal
 in
Washer Repair
Hello all - I just joined the forum I have an LG WM8000HWA. After 3 yrs the bearing was rusted
Appliance Repair Forum > Appliance Repair Help > Washer Repair » LG WM8000HWA Leak Outer Tub Seal
  #1 (permalink)
Old 04-15-2018, 10:07 PM
Junior Member
Hogan773 is on a distinguished road
Default LG WM8000HWA Leak Outer Tub Seal
Model Number: WM8000HWA   Brand: -other-   Age: 1 - 5 years
I have an LG WM8000HWA. After 3 yrs the bearing was rusted and shot and machine shook like crazy. I paid LG tech to come out and for reasonable fixed price they replaced outer tub, inner tub, bearings, etc. Has worked well since. That was about 2 or 2.5 years ago.
I recently noticed leaking water from underneath inside. Looking at internet I assumed bad tub to pump hose. But I diagnosed with paper underneath while observing through open back panel and it is definitely leak from the clamshell plastic outer tub. No leak from the hose, but decent amount of drips from the bottom left side of the clamshell seam. When in spin it shakes and that must flex tub enough for small leak.
I see one of the bolts on the top side is not all the way in. Maybe the tech didn't do a good job snugging everything a few years ago when he took it all apart. I haven't taken the front off yet so I can't really see the condition of the underside of the tub and whether any bolts are not fully tight there.
I have 2 questions:
1) Maybe I can just take off front panel and then access the lower tub seal bolts and snug them harder? Maybe they have gotten loose a bit. Then I don't need to take all the hoses off and remove the whole tub? Also is there any torque specs on those bolts or you just hand tighten with a ratchet? I assume DO NOT use the 18V impact wrench that I use for lugnuts...might strip or break something.
2) IF that doesn't work or is a bad idea, I am curious why we need to remove the stator and rotor from the tub as shown in the video from this site in order to remove the tub from the machine? Is it because that is the only way to unclip the wire harnesses there? I was thinking if those can be unclipped why not just do that and leave the rotor and stator bolted to the tub while taking it out? Since I don't need to do anything with the tub bearings seal at this point.
Any thoughts would be appreciated thanks.
Related Models
General Electric WMCD2050G0WC Washer
General Electric WMCD2050H0WC WASHER
General Electric WMCD2050H1WC WASHER
General Electric WMCD2050H2WC WASHER
General Electric WMCD2050H3WC WASHER
General Electric WMCD2050H4WC WASHER
General Electric WMCD2050H5WC WASHER
General Electric WMCD2050H6WC COIN-OP WASHER
General Electric WMCD2050J0WC COIN-OP WASHER
General Electric WMCD2050J1WC WASHER
Jenn-Air WME3020B WALLOVEN- S/C MWAVE ELE
Jenn-Air WME3020W WALLOVEN- S/C MWAVE ELE
Jenn-Air WMG3020B WALLOVEN- S/C MWAVE GAS
Jenn-Air WMG3020W WALLOVEN- S/C MWAVE GAS
Whirlpool WMH1162XVB0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVB1 Microwave Oven 1.6 Cu. Ft.
Whirlpool WMH1162XVB2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVB3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVB4 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVD0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVD1 Microwave Oven 1.6 Cu. Ft.
Whirlpool WMH1162XVD2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVD3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVD4 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVQ0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVQ1 Microwave Oven 1.6 Cu. Ft.
Whirlpool WMH1162XVQ2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVQ3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVQ4 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVS0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVS1 Microwave Oven 1.6 Cu. Ft.
Whirlpool WMH1162XVS2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVS3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVS4 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVB0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVB1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVB2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVD0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVD1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVD2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVQ0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVQ1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVQ2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVS0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVS1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVS2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVS3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1164XVS0 MICROWAVE OVEN 1.6 Cu. Ft.
Whirlpool WMH1164XVS1 MICROWAVE OVEN 1.6 Cu. Ft.
Whirlpool WMH1164XVS2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1164XVS3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1164XWS0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1164XWS1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1164XWS2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH2175XVB0 Microwave Oven 1.7 Cu. Ft.
Whirlpool WMH2175XVB1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH2175XVB2 MICROWAVE OVEN 1.7 CU. FT.
Whirlpool WMH2175XVQ0 Microwave Oven 1.7 Cu. Ft.
Whirlpool WMH2175XVQ1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH2175XVQ2 MICROWAVE OVEN 1.7 CU. FT.
Whirlpool WMH2175XVS0 Microwave Oven 1.7 Cu. Ft.
Whirlpool WMH2175XVS1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH2175XVS2 MICROWAVE OVEN 1.7 CU. FT.
Whirlpool WMH2175XVT0 Microwave Oven 1.7 Cu. Ft.
Whirlpool WMH2175XVT1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH2175XVT2 MICROWAVE OVEN 1.7 CU. FT.
Whirlpool WMH2205XVB0 Microwave Oven/Hood 2.0 Cu. Ft.
Whirlpool WMH2205XVB1 Microwave Oven/Hood 2.0 Cu. Ft.
Whirlpool WMH2205XVQ0 Microwave Oven/Hood 2.0 Cu. Ft.
Whirlpool WMH2205XVQ1 Microwave Oven/Hood 2.0 Cu. Ft.
Whirlpool WMH2205XVS0 Microwave Oven/Hood 2.0 Cu. Ft.
Whirlpool WMH2205XVS1 Microwave Oven/Hood 2.0 Cu. Ft.
Whirlpool WMH3205XVB0 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Whirlpool WMH3205XVB1 MICROWAVE HOOD COMBO
Whirlpool WMH3205XVB2 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Whirlpool WMH3205XVQ0 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Whirlpool WMH3205XVQ1 MICROWAVE HOOD COMBO
Whirlpool WMH3205XVQ2 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Whirlpool WMH3205XVS0 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Whirlpool WMH3205XVS1 MICROWAVE HOOD COMBO
Whirlpool WMH3205XVS2 MICROWAVE OVEN/HOOD 2.0 CU. FT.
General Electric WMR03GAZABB REFRIGERATOR
General Electric WMR04BANABB Refrigerator
General Electric WMR04BANBBB Refrigerator
General Electric WMR04BANCBB Refrigerator
General Electric WMR04BANDBB Refrigerator
General Electric WMR04BAPABB Refrigerator
General Electric WMR04BAVABB REFRIGERATOR
General Electric WMR04DATABB Refrigerator
General Electric WMR04GAVABB REFRIGERATOR
General Electric WMR04GAVBBB REFRIGERATOR
General Electric WMR04GAVCBB REFRIGERATOR
General Electric WMR04GAZABB REFRIGERATOR
General Electric WMR04GAZAWW REFRIGERATOR
General Electric WMSE3140A0AA Washer
General Electric WMSE3140A0WW Washer
General Electric WMSE3140A2WW Washer
General Electric WMSE3140A3WW Washer
General Electric WMSE4190A0AA Washer
General Electric WMSE4190A0WW Washer
General Electric WMSE4230A0WW Washer
General Electric WMSR2090T2AA Washer
General Electric WMSR2090T2WW Washer
General Electric WMSR2090T3AA Washer
General Electric WMSR2090T3WW Washer
General Electric WMSR2090T5AA Washer
General Electric WMSR2090T5WW Washer
General Electric WMSR2100T6AA Washer
General Electric WMSR2100T6WW Washer
General Electric WMSR2100T8AA Washer
General Electric WMSR2100T8WW Washer
General Electric WMSR2100TAAA Washer
General Electric WMSR2100TAWW Washer
General Electric WMSR2100TBAA Washer
General Electric WMSR2100TBWW Washer
General Electric WMSR3110W1WW Washer
General Electric WMSR3110W2WW Washer
General Electric WMXR3080T2AA Washer
General Electric WMXR3080T2WW Washer
General Electric WMXR3080T3AA Washer
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Water leak at seal between outer drum & balance weight dwhsparky Washer Repair 1 07-06-2015 03:13 PM
Outer Tub Seal Leak edatlarge Washer Repair 2 09-09-2010 05:12 PM
leak under outer tub jdog Washer Repair 7 11-11-2009 04:31 AM
leak under outer tub jdog Dishwasher Repair 0 10-22-2009 04:14 PM
Is seal in outer tub replaceble? rproefrock Washer Repair 1 12-17-2008 04:28 PM
