Discuss
Kenmore Washer 400 series
 in
Washer Repair
Washer doesnt agitate . replaced dog gears . replaced shift actuator . There is a plastic gear at the bottom
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore Washer 400 series
  #1 (permalink)
Old 04-06-2018, 02:50 PM
Junior Member
Ohio Bob is on a distinguished road
Default Kenmore Washer 400 series
Brand: Kenmore   Age: 1 - 5 years
Washer doesnt agitate . replaced dog gears . replaced shift actuator . There is a plastic gear at the bottom that drops down and engages when the washer starts . The motor turns it back and forth a couple times sensing I guess ? The washer then fills with water . When the water reaches the proper level the plastic gear at the bottom retracts and the motor turns left then right then left and right . If the gear would stay engaged it would be agitating but it retracted . Once the agitate cycle is complete the gear re engages and spins the water out . Any and all help is greatly appreciated
  #2 (permalink)
Old 04-07-2018, 03:16 AM
Junior Member
Default
washer spins but wont agitate?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore 90 Series Washer hookman Washer Repair 0 08-08-2017 04:29 PM
kenmore 90 series washer givens777 Washer Repair 0 03-06-2014 06:34 AM
kenmore washer 80 series Grover327 Washer Repair 1 05-24-2011 05:30 PM
Kenmore 70 series washer Jody G Washer Repair 1 01-05-2009 04:22 PM
kenmore 70 series washer lafamiliallanes Washer Repair 1 05-17-2008 07:21 PM
