Discuss
Can a defective actuator ever cause a no-fill situation?
 in
Washer Repair
This is a follow up to an earlier question today. I have a Kenmore 11026002010 that will not fill. When
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Can a defective actuator ever cause a no-fill situation?
  #1 (permalink)
Old 03-30-2018, 03:25 PM
Junior Member
ken su is on a distinguished road
Default Can a defective actuator ever cause a no-fill situation?
Model Number: 11026002010   Brand: Kenmore   Age: 5 - 10 years
This is a follow up to an earlier question today. I have a Kenmore 11026002010 that will not fill. When I try to start it, I get a "sensing" and "lid locked" light but it won't add water. The unit start sounded like it was agitating before I powered it off. I tested the inlet valves good by applying power directly to them and water started to fill the tub.
I was told that the actuator could be defective and may not be sending a signal to the control board to start the fill. Is this correct? I hate to spend the bucks on a new control board if the problem could be the actuator. Your best guess?
Related Models
Kenmore 11026002010 AUTOMATIC WASHER
Kenmore 11026002011 AUTOMATIC WASHER
Kenmore 11026012010 AUTOMATIC WASHER
Kenmore 11026012011 AUTOMATIC WASHER
Kenmore 11026051690 COMMERCIAL AUTOMATIC WASHER
Kenmore 11026058690 COMMERCIAL AUTOMATIC WASHER
Kenmore 11026071690 COMMERCIAL WASHER
Kenmore 11026071691 COMMERCIAL WASHER
Kenmore 11026152500 WASHER COMMERCIAL
Kenmore 11026292690 AUTOMATIC WASHER
Kenmore 11026292691 AUTOMATIC WASHER
Kenmore 11026292692 AUTOMATIC WASHER
Kenmore 11026292693 AUTOMATIC WASHER
Kenmore 11026292694 WASHER
Kenmore 11026292695 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11026294690 AUTOMATIC WASHER
Kenmore 11026294691 AUTOMATIC WASHER
Kenmore 11026294692 AUTOMATIC WASHER
Kenmore 11026294693 AUTOMATIC WASHER
Kenmore 11026294694 WASHER
Kenmore 11026294695 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11026322500 WASHER
Kenmore 11026322501 WASHER
Kenmore 11026322502 RESIDENTIAL WASHER
Kenmore 11026322503 RESIDENTIAL WASHER
Kenmore 11026332500 RESIDENTIAL WASHER
Kenmore 11026332501 WASHER
Kenmore 11026332502 RESIDENTIAL WASHER
Kenmore 11026332503 RESIDENTIAL WASHER
Kenmore 11026342500 RESIDENTIAL WASHER
Kenmore 11026342501 WASHER
Kenmore 11026342502 RESIDENTIAL WASHER
Kenmore 11026342503 RESIDENTIAL WASHER
Kenmore 11026422500 RESIDENTIAL WASHER
Kenmore 11026422501 WASHER
Kenmore 11026422502 RESIDENTIAL WASHER
Kenmore 11026422503 RESIDENTIAL WASHER
Kenmore 11026432500 WASHER
Kenmore 11026432501 WASHER
Kenmore 11026432502 RESIDENTIAL WASHER
Kenmore 11026432503 RESIDENTIAL WASHER
Kenmore 1102644182 RESIDENTIAL WASHER
Kenmore 11026442500 WASHER
Kenmore 11026442501 WASHER
Kenmore 11026442502 RESIDENTIAL WASHER
Kenmore 11026442503 RESIDENTIAL WASHER
Kenmore 1102644722 RESIDENTIAL WASHER
Kenmore 11026622690 WASHER
Kenmore 11026622691 AUTOMATIC WASHER
Kenmore 11026632500 WASHER
Kenmore 11026632501 WASHER
Kenmore 11026632502 WASHER
Kenmore 11026632503 RESIDENTIAL WASHER
Kenmore 11026642500 WASHER
Kenmore 11026642501 washer
Kenmore 11026642502 WASHER
Kenmore 11026642503 RESIDENTIAL WASHER
Kenmore 11026652500 WASHER
Kenmore 11026652501 WASHER
Kenmore 11026652502 WASHER
Kenmore 11026652503 RESIDENTIAL WASHER
Kenmore 11026682503 RESIDENTIAL WASHER
Kenmore 11026692503 RESIDENTIAL WASHER
Kenmore 11026702690 AUTOMATIC WASHER
Kenmore 11026702691 AUTOMATIC WASHER
Kenmore 11026702692 AUTOMATIC WASHER
Kenmore 11026702693 AUTOMATIC WASHER
Kenmore 11026702694 AUTOMATIC WASHER
Kenmore 11026712690 WASHER
Kenmore 11026712691 AUTOMATIC WASHER
Kenmore 11026712692 AUTOMATIC WASHER
Kenmore 11026712693 AUTOMATIC WASHER
Kenmore 11026722690 WASHER
Kenmore 11026722691 AUTOMATIC WASHER
Kenmore 11026722692 AUTOMATIC WASHER
Kenmore 11026722693 AUTOMATIC WASHER
Kenmore 11026732500 WASHER
Kenmore 11026732501 WASHER
Kenmore 11026732502 WASHER
Kenmore 11026732503 RESIDENTIAL WASHER
Kenmore 11026742500 WASHER
Kenmore 11026742501 WASHER
Kenmore 11026742502 WASHER
Kenmore 11026742503 RESIDENTIAL WASHER
Kenmore 11026752500 WASHER
Kenmore 11026752501 WASHER
Kenmore 11026752502 WASHER
Kenmore 11026752503 RESIDENTIAL WASHER
Kenmore 11026791690 AUTOMATIC WASHER
Kenmore 11026791691 AUTOMATIC WASHER
Kenmore 11026801690 AUTOMATIC WASHER
Kenmore 11026801691 AUTOMATIC WASHER
Kenmore 11026801692 AUTOMATIC WASHER
Kenmore 11026808690 WASHER
Kenmore 11026808691 AUTOMATIC WASHER
Kenmore 11026808692 AUTOMATIC WASHER
Kenmore 11026809690 AUTOMATIC WASHER
Kenmore 11026812690 WASHER
Kenmore 11026812691 AUTOMATIC WASHER
Kenmore 11026814690 WASHER
Kenmore 11026814691 AUTOMATIC WASHER
Kenmore 11026822690 WASHER
Kenmore 11026822691 AUTOMATIC WASHER
Kenmore 11026822692 AUTOMATIC WASHER
Kenmore 11026824690 WASHER
Kenmore 11026824691 AUTOMATIC WASHER
Kenmore 11026824692 AUTOMATIC WASHER
Kenmore 11026832690 AUTOMATIC WASHER
Kenmore 11026832691 AUTOMATIC WASHER
Kenmore 11026832692 AUTOMATIC WASHER
Kenmore 11026832694 AUTOMATIC WASHER
Kenmore 11026834690 WASHER
Kenmore 11026834691 AUTOMATIC WASHER
Kenmore 11026834692 AUTOMATIC WASHER
Kenmore 11026834694 AUTOMATIC WASHER
Kenmore 11026842690 WASHER
Kenmore 11026842691 AUTOMATIC WASHER
Kenmore 11026842692 AUTOMATIC WAHSER
Kenmore 11026842694 AUTOMATIC WASHER
Kenmore 11026844690 WASHER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Can a defective actuator ever cause a no-fill situation? ken su Washer Repair 0 03-30-2018 03:24 PM
