Greetings. My washer is a Frigidaire model LTF2940ES0. The door closes and latches, and the washer operates correctly with no leaks, but the door alignment is off. Along the right edge of the rectangular door at the top it is smooth to the cabinet, but at the bottom, the right edge petrudes about 3/8 inch. The hinges appear to be in good shape. I'm concerned that this may eventually leak. Can this mis-alignment be corrected? Thanks.
