Discuss
Kenmore top load won't agitate, spin, hums
 in
Washer Repair
My Kenmore washer tripped the breaker last night during the spin cycle, after draining the water. Everything seems fine with
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore top load won't agitate, spin, hums
  #1 (permalink)
Old 11-05-2009, 11:21 AM
jeffraab jeffraab is offline
Junior Member
jeffraab is on a distinguished road
Unhappy Kenmore top load won't agitate, spin, hums
Model Number: not sure   Brand: Kenmore   Age: 1 - 5 years
My Kenmore washer tripped the breaker last night during the spin cycle, after draining the water. Everything seems fine with the circuit in general, but the washer won't agitate, spin, or drain. I'm at work and don't have the exact model number right now, but it fits the description in general for "Kenmore top loader blues".
I had to replace the coupling once before, and I checked that it's fine. I took off the agitator and there's nothing stuck under it. I took the plastic rim off the top of the tub cylinder and there was 1 baby sock between the metal basket and the tub.
My guess is that there is another sock or something else either in the pump or wedged under the basket. I was able to manually move the basket in one direction but not the other (not sure which direction was OK, can check later) and after that kind of movement I was able to get the thing to agitate "once" before it would stop and hum again.
Questions are:
- How do I get in the pump hose to check for a clog?
- Can a pump clog stop the thing from agitating?
- How do I get the top of the agitator shaft off to remove the basket?
- Any other causes? Transmission?
Finally, if I get it working, the cabinet is starting to rust at the joint of the front face and top. Anybody been able to separate the surround and top and do something to fix/stop the rust?
Related Models
Admiral NR460 Ref - Single Door
Admiral NR460A Ref - Single Door
Admiral NR460H Ref - Single Door
Admiral NR530 Ref - Single Door
Admiral NR530A Ref - Single Door
Admiral NR530H Ref - Single Door
Admiral NR580 Ref - Single Door
Admiral NR580A Ref - Single Door
Admiral NR580H Ref - Single Door
Admiral NR640 Ref - Single Door
Admiral NR640A Ref - Single Door
Maytag NS207MA  Ref - Sxs
Maytag NS207MW  Ref - Sxs
Maytag NS207NA Ref - Sxs
Maytag NS207NW Ref - Sxs
Maytag NS207PA Ref - Sxs
Maytag NS207PW Ref - Sxs
Maytag NS208MA  Ref - Sxs
Maytag NS208MW  Ref - Sxs
Maytag NS208NA Ref - Sxs
Maytag NS208NW Ref - Sxs
Admiral NS20F7 Ref - Sxs
Admiral NS20F7A Ref - Sxs
Admiral NS20F7H Ref - Sxs
Admiral NS20F8 Ref - Sxs
Admiral NS20F8A Ref - Sxs
Admiral NS20F8H Ref - Sxs
Admiral NS20H7 Ref - Sxs
Admiral NS20H7A Ref - Sxs
Admiral NS20H7H Ref - Sxs
Admiral NS20H8 Ref - Sxs
Admiral NS20H8A Ref - Sxs
Admiral NS20H8H Ref - Sxs
Admiral NS20JX Ref - Sxs
Admiral NS20JXA Ref - Sxs
Admiral NS20JXH Ref - Sxs
Admiral NS20L7 Ref - Sxs
Admiral NS20L7A Ref - Sxs
Admiral NS20L7H Ref - Sxs
Maytag NS229NA Ref - Sxs
Maytag NS229NW Ref - Sxs
Admiral NS22F8 Ref - Sxs
Admiral NS22F8A Ref - Sxs
Admiral NS22F8H Ref - Sxs
Admiral NS22H7 Ref - Sxs
Admiral NS22H7A Ref - Sxs
Admiral NS22H7H Ref - Sxs
Admiral NS22H8 Ref - Sxs
Admiral NS22H8A Ref - Sxs
Admiral NS22H8C Ref - Sxs
Admiral NS22H8H Ref - Sxs
Admiral NS22HP8 Ref - Sxs
Admiral NS22HP8A Ref - Sxs
Admiral NS22HP8H Ref - Sxs
Admiral NS22L8 Ref - Sxs
Admiral NS22L8A Ref - Sxs
Admiral NS24F8 Ref - Sxs
Admiral NS24F8A Ref - Sxs
Admiral NS24F8H Ref - Sxs
Admiral NS24H8 Ref - Sxs
Admiral NS24H8A Ref - Sxs
Admiral NS24H8H Ref - Sxs
Maytag NT153MA  Ref - Top Mount
Maytag NT153MW  Ref - Top Mount
Maytag NT153NA Ref - Top Mount
Maytag NT153NW Ref - Top Mount
Maytag NT155MA  Ref - Top Mount
Maytag NT155MW  Ref - Top Mount
Maytag NT156MA  Ref - Top Mount
Maytag NT156MW  Ref - Top Mount
Maytag NT156NW Ref - Top Mount
Maytag NT156PW Ref - Top Mount
Admiral NT15A5V Ref - Top Mount
Admiral NT15A5VA Ref - Top Mount
Admiral NT15A5VH Ref - Top Mount
Admiral NT15B43G Ref - Top Mount
Admiral NT15B43GA Ref - Top Mount
Admiral NT15B43GH Ref - Top Mount
Admiral NT15B43GL Ref - Top Mount
Admiral NT15B43GLA Ref - Top Mount
  #2 (permalink)
Old 11-06-2009, 12:07 PM
sidfink43 sidfink43 is offline
Senior Expert
APP Volunteer
sidfink43 is on a distinguished road
Default
You need to take off the cabinet, this video will show you how. You can then examine the drains and pump.
YouTube - Direct Drive Washing Machine Repair Video Tutorial *Watch in HIGH Quality!*
A pump clog can stop the machine from agitating since the motor shaft which causes agitation also is trying to turn the pump.
Remove the fabric softener module and you will find a 7/16's bolt which will come out and allow you to remove the agitator. If there is no bolt you may have a square opening which can be inscrewed.
If your motor is operating freely and has power then the problem may be in the transmission.
__________________
  #3 (permalink)
Old 11-06-2009, 12:16 PM
Junior Member
Default
Since I posted I checked the pump, motor, trans, and clutch and everything individually seems to be turning fine. Once I got it all back together it still has the same problem.
With the pump off if I turn the motor by hand it gets hard to do when the clutch engages. It might be the normal behavior though, I have nothing to compare it to.
Only things I can think of that are left are is the motor fried and doesn't have enough torque to turn, is there some kind of failsafe or brake that is engaged, or is there something stuck under the basket that's holding it back. I was able to turn the basket in the tub by hand with the thing on its side, but when it's upright and I turn the basket by hand through the lid it is hard to move and feels like something's engaged.
  #4 (permalink)
Old 11-06-2009, 01:36 PM
Senior Expert
APP Volunteer
Default
There is a brake assembly, so look at the post by Richappy on direct drive brakes. That is why the basket is hard to turn by hand. With the motor off turn the transmission using the coupling on the shaft. It should turn fairly easy in each direction.
If it hangs up, take out the transmission (you will need to take off the agitator) and inspect things, but I am guessing that your transmission has hung up in some way as these motors are like rocks, they almost never wear out.
__________________
  #5 (permalink)
Old 11-06-2009, 01:58 PM
Junior Member
Default
Excellent, thanks sidfink43. I did turn the trans using the coupling and I could see in 1 direction that the shaft turned slowly one way then reversed direction (agitate?). In the other direction it turned more quickly and always went the same way (spin?). This would seem to make a brake issue more likely, I think.
I'll check out the Richappy post on the brakes when I get home. Thanks again!
  #6 (permalink)
Old 11-06-2009, 06:29 PM
Junior Member
Default
Was a baby sock, see here:
Kenmore won't agitate or spin Help!
Sorry for the double-post. I couldn't edit the model number in the thread after I created it.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer wont agitate or spin out just hums bobcat1206 Washer Repair 3 07-10-2009 04:57 AM
My GE top load washer does not agitate or spin. jenjenrosebud Washer Repair 1 12-30-2008 04:05 PM
Kenmore top-load washer does not spin or agitate HarryD Washer Repair 6 09-19-2008 03:57 PM
Frigidaire F/Load Won't agitate or spin dfran Dishwasher Repair 1 06-08-2008 10:12 AM
Washer motor hums, but won't drain, agitate or spin redwood646 Washer Repair 2 09-11-2007 08:39 PM
