Register | FAQ's | New Posts | Today's Posts | Extras |
» Electrolux Washer load buzz noise at drain |
![]() Model Number: EIFLW55HIW0 Brand: Electrolux Age: 5 - 10 years
![]() Washer has started to make a really load buzz and some additional vibration during drain. Happens at initial start, when washer expels any residual water, and later on during the cycle as it needs to drain. Unit normally has a buzzing during the drain, but this is much much louder. Doesn't always happen, and water does drain, even with noise. "Install" diagnostic cycle runs with no error (but buzz sound present). Occasional other noise during drain (not typical). No error coes have come up (yet) either during use. It is still working/draining, but sound makes me think its going to go. What do you think? Drain Pump is going? Also, there is no easy off bottom access, as shown in the sample video for pump replacement ("Duet" example). Do you have to disassemble the entire front (or is it rear access) to get to the pump? Related Models |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Electrolux washer trickle fill and drain | ds4604 | Washer Repair | 0 | 05-13-2017 06:46 AM |
Drain Pump Noise - Frigidaire Affinity Front Load Washer | mschlott | Washer Repair | 0 | 08-19-2016 07:16 AM |
Electrolux front load washer over filling, E35 code | Janf-1 | Washer Repair | 0 | 09-28-2014 05:46 PM |
G E Top Load Washer wont drain w/full load | Mike 384 | Washer Repair | 1 | 02-05-2011 05:11 PM |
Load Thumping Noise & Unbalanced Condition On GE front load washer | Luke Vincent | Washer Repair | 2 | 08-06-2009 05:43 PM |
