Discuss
washer/dryer combo washer wont spin
 in
Washer Repair
Got some undies wrapped in the motor pulley and locked up. I removed obstruction and ran cycle and it stops
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer/dryer combo washer wont spin
  #1 (permalink)
Old 03-21-2018, 05:08 PM
Junior Member
Bill.grieves is on a distinguished road
Default washer/dryer combo washer wont spin
Model Number: 2261532   Brand: Kenmore   Age: 1 - 5 years
Got some undies wrapped in the motor pulley and locked up. I removed obstruction and ran cycle and it stops as soon as the spin cycle starts. Motor made scratch noise when manually rotating so I replaced it.
I am able to go into diagnostic mode and run only the spin cycle and it works til I stop it. When running normal wash cycle the agitator fly wheel engages and the motor bogs down and faults out.
I am thinking its the control board? Any help is really appreciated
Thank you
Bill
Related Models
Roper 2265*0A Ranges, Electric*
Roper 2265W0A Ranges, Electric*
Hoover 2266
Amana 2274.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2274.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2274.A MWAVE - FAMILY SIZE (60 HZ)
Roper 2275*0A Ranges, Electric*
Roper 2275W0A Ranges, Electric*
Roper 2276*0A Ranges, Electric*
Roper 2276*1A Ranges, Electric*
Amana 2276.A MWAVE - FAMILY SIZE (60 HZ)
Roper 2276W0A Ranges, Electric*
Roper 2276W1A Ranges, Electric*
Jenn-Air 2280EEL WALLOVEN- STD ELE
Frigidaire 2281 GAS RANGE
Jenn-Air 2281EEL WALLOVEN- STD ELE
Magic Chef 22FA-2KLW RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FA-2KW WALLOVEN-STD DBL OVEN GAS
Magic Chef 22FA-6CKLXV8 Range - Cont Clean Mwave Gas
Magic Chef 22FA-6KLX RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FA-6KLX-6F RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FA-6KLXV8 RANGE- CONT CLEAN MWAVE GAS
Magic Chef 22FK-2KLW RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FK-2KW WALLOVEN-STD DBL OVEN GAS
Magic Chef 22FK-6KLX RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FK-6KLX-6F RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FK-6KLXV8 RANGE- CONT CLEAN MWAVE GAS
Magic Chef 22FN-2KLW RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FN-2KW WALLOVEN-STD DBL OVEN GAS
Magic Chef 22FN-6CKLXV8 MAGIC CHEF COOKING
Magic Chef 22FN-6KLX RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FN-6KLX-6F RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FN-6KLXV8 RANGE- CONT CLEAN MWAVE GAS
Magic Chef 22FY-2KLW RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FY-2KW WALLOVEN-STD DBL OVEN GAS
Magic Chef 22FY-6KLX RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FY-6KLX-6F RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FY-6KLXV8 RANGE- CONT CLEAN MWAVE GAS
Magic Chef 22JA-7KLXV8 RANGE- CONT CLEAN MWAVE GAS
Magic Chef 22JK-7KLXV8 RANGE- CONT CLEAN MWAVE GAS
Magic Chef 22JN-7KLXV8 RANGE- CONT CLEAN MWAVE GAS
Magic Chef 22JY-7KLXV8 RANGE- CONT CLEAN MWAVE GAS
Magic Chef 22M-7KLXV8 RANGE- CONT CLEAN MWAVE GAS
Magic Chef 22MA-7KLXV8 RANGE- CONT CLEAN MWAVE GAS
Magic Chef 22MN-7KLXV8 RANGE- CONT CLEAN MWAVE GAS
Magic Chef 22MW-7KLXV8 RANGE- CONT CLEAN MWAVE GAS
Magic Chef 22RA-3B-49 RV RANGE- GAS
Magic Chef 22RA-3BKZ RV RANGE- GAS
Magic Chef 22RA-3BTZ RV RANGE- GAS
Magic Chef 22RA-3BZ RV RANGE- GAS
Magic Chef 22RA-4 RV RANGE- GAS
Magic Chef 22RA-4K RV RANGE- GAS
Magic Chef 22RA-4K-49 RV RANGE- GAS
Magic Chef 22RA-4KVX RV RANGE- GAS
Magic Chef 22RA-4KX RV RANGE- GAS
Magic Chef 22RA-4KZ RV RANGE- GAS
Magic Chef 22RA-4T RV RANGE- GAS
Magic Chef 22RA-4TVX RV RANGE- GAS
Magic Chef 22RA-4TX RV RANGE- GAS
Magic Chef 22RA-4TZ RV RANGE- GAS
Magic Chef 22RB-3B RV RANGE- GAS
Magic Chef 22RB-3BKZ RV RANGE- GAS
Magic Chef 22RB-3BTVX RV RANGE- GAS
Magic Chef 22RB-3BTZ RV RANGE- GAS
Magic Chef 22RB-3BZ RV RANGE- GAS
Magic Chef 22RB-4K RV RANGE- GAS
Magic Chef 22RB-4KX RV RANGE- GAS
Magic Chef 22RB-4KZ RV RANGE- GAS
Magic Chef 22RB-4T RV RANGE- GAS
Magic Chef 22RB-4TX RV RANGE- GAS
Magic Chef 22RB-4TZ RV RANGE- GAS
Magic Chef 22RS-4KVX RV RANGE- GAS
Magic Chef 22RS-4KX RV RANGE- GAS
Magic Chef 22RS-4KZ RV RANGE- GAS
Magic Chef 22RS-4TVX RV RANGE- GAS
Magic Chef 22RS-4TX RV RANGE- GAS
Magic Chef 22RS-4TZ RV RANGE- GAS
Magic Chef 22RW-3B-49 RV RANGE- GAS
Magic Chef 22RW-3BK RV RANGE- GAS
Magic Chef 22RW-3BK49 RV RANGE- GAS
Magic Chef 22RW-3BKZ RV RANGE- GAS
Magic Chef 22RW-3BTVX RV RANGE- GAS
Magic Chef 22RW-3BTZ RV RANGE- GAS
Magic Chef 22RW-3BZ RV RANGE- GAS
Magic Chef 22RW-4 RV RANGE- GAS
Magic Chef 22RW-4K RV RANGE- GAS
Magic Chef 22RW-4K-49 RV RANGE- GAS
Magic Chef 22RW-4KX RV RANGE- GAS
Magic Chef 22RW-4KZ RV RANGE- GAS
Magic Chef 22RW-4T RV RANGE- GAS
Magic Chef 22RW-4TX RV RANGE- GAS
Magic Chef 22RW-4TZ RV RANGE- GAS
Magic Chef 22TA-3BKZ RV RANGE- GAS
Magic Chef 22TA-3BZ RV RANGE- GAS
Magic Chef 22TA-4-49 RV RANGE- GAS
Magic Chef 22TA-4KZ RV RANGE- GAS
Magic Chef 22TA-4Z RV RANGE- GAS
Magic Chef 22TB-3B RV RANGE- GAS
Magic Chef 22TB-3BKZ RV RANGE- GAS
Magic Chef 22TB-3BZ RV RANGE- GAS
Magic Chef 22TW-3B-49 RV RANGE- GAS
Magic Chef 22TW-3BK RV RANGE- GAS
Magic Chef 22TW-3BK49 RV RANGE- GAS
Magic Chef 22TW-3BKE RV RANGE- GAS
Magic Chef 22TW-3BKZ RV RANGE- GAS
Magic Chef 22TW-3BZ RV RANGE- GAS
Magic Chef 22TW-4KZ RV RANGE- GAS
Jenn-Air 2300 SURFACE UNIT- DDRAFT ELE
Jenn-Air 2300ERS SURFACE UNIT- DDRAFT ELE
Jenn-Air 2320ERS SURFACE UNIT- DDRAFT ELE
Roper 2323*0A Ranges, Electric*
Roper 2323W0A Ranges, Electric*
Roper 2324W0A Ranges, Electric*
Jenn-Air 2325ERS SURFACE UNIT- DDRAFT ELE
Roper 2326*0A Ranges, Electric*
Roper 2326W0A Ranges, Electric*
Kenmore 23310428 RANGE HOOD
Kenmore 23310442 RANGE HOOD
Kenmore 23334201 RANGE HOOD
Kenmore 23334202 RANGE HOOD
  #2 (permalink)
Old 03-21-2018, 06:28 PM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
That's not a Kenmore model number. They have three digits then a period then many more digits.
xxx.xxxxxxxxxx?
  #3 (permalink)
Old 03-21-2018, 07:03 PM
Junior Member
Default
It says mod: 2261532 on the sticker inside the door. If you search the sears manual many come up under these model numbers
  #4 (permalink)
Old 03-21-2018, 07:21 PM
Junior Member
Default
Ser: Ra002282c
189d7217p005
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire washer dryer combo won't spin or drain MikeeD Washer Repair 2 09-30-2015 01:55 AM
Kenmore Washer/Dryer combo won't drain or spin uttdawg Washer Repair 5 12-30-2014 09:01 AM
GE combo washer intermittent spin jrschatz Washer Repair 5 05-27-2014 06:38 PM
Maytag Neptune Combo Washer/ Dryer wont spin (washer) HLSerrano Washer Repair 5 04-02-2012 01:20 PM
Combo washer/dryer no power to washer raamw Washer Repair 6 04-11-2009 03:07 PM
