Discuss
Can't Get the Gearbox Back IN
 in
Washer Repair
While chasing a problem with the washer not fully spinning the clothes dry I removed the gearbox/clutch assy to
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Can't Get the Gearbox Back IN
  #1 (permalink)
Old 11-05-2009, 10:12 AM
txrelined txrelined is offline
Junior Member
txrelined is on a distinguished road
Default Can't Get the Gearbox Back IN
Model Number: 110.15842400   Brand: Kenmore   Age: 1 - 5 years
While chasing a problem with the washer not fully spinning the clothes dry I removed the gearbox/clutch assy to check the clutch. Now I cannot get the gearbox/clutch assy to mate with the mounts. The clutch assy appears to be bottoming out on the basket drive assy but the gearbox is about an inch from it's mounting points. What am I doing wrong?
Related Models
Kenmore 110.16101690  AUTOMATIC WASHER
Kenmore 110.16101691  AUTOMATIC WASHER
Kenmore 110.16202690  WASHER
Sears 110.16202691  AUTOMATIC WASHER
Kenmore 110.16502690  WASHER
Sears 110.16502691  AUTOMATIC WASHER
Sears 110.16502692  AUTOMATIC WASHER
Kenmore 110.16512690  WASHER
Kenmore 110.18202790  AUTOMATIC WASHER
Kenmore 110.18522790  AUTOMATIC WASHER
Kenmore 110.18522791  AUTOMATIC WASHER
Kenmore 110.18532790  AUTOMATIC WASHER
Kenmore 110.18542891  AUTOMATIC WASHER
Kenmore 110.18609890  AUTOMATIC WASHER
Kenmore 110.18702790  AUTOMATIC WASHER
Kenmore 110.18702791  AUTOMATIC WASHER
Kenmore 110.19101990  AUTOMATIC WASHER-GALAXY
Kenmore 110.19101991  AUTOMATIC WASHER-GALAXY
Kenmore 110.19101992  WASHER
Kenmore 110.19202200  AUTOMATIC WASHER-GALAXY
Kenmore 110.19422200  AUTOMATIC WASHER-GALAXY
Kenmore 110.20052991  WASHER
Kenmore 110.20052992  WASHER
Kenmore 110.20052993  AUTOMATIC WASHER
Kenmore 110.20056993  AUTOMATIC WASHER
Kenmore 110.20112000  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.2011200A  WASHER
Kenmore 110.20132000  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.20132001  WASHER
Kenmore 110.20172000  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.20172001  COMMERICAL AUTOMATIC WASHER
Kenmore 110.20272000  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.20272001  COMMERICAL AUTOMATIC WASHER
Kenmore 110.26051690  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.26058690  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.26071690  COMMERCIAL WASHER
Kenmore 110.26071691  COMMERCIAL WASHER
Kenmore 110.26622690  WASHER
Kenmore 110.26702690  AUTOMATIC WASHER
Kenmore 110.26712690  WASHER
Kenmore 110.26808690  WASHER
Kenmore 110.26809690  AUTOMATIC WASHER
Kenmore 110.26902690  AUTOMATIC WASHER
Kenmore 110.26952690  AUTOMATIC WASHER
Kenmore 110.27802690  AUTOMATIC WASHER
Kenmore 110.279119  BURNER ASSEMBLY 60 HZ
Kenmore 110.279121  BURNER ASSEMBLY 50 HZ
Kenmore 110.27982790  AUTOMATIC WASHER
Kenmore 110.2870090  AUTOMATIC WASHER
Kenmore 110.29012990  COMMERICAL AUTOMATIC WASHER
Kenmore 110.29032990  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.29072990  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.3360630  GEARCASE
Kenmore 110.3360631  GEARCASE ASSEMBLY
Kenmore 110.3363361  GEARCASE
Kenmore 110.3387617  BURNER ASSEMBLY
Kenmore 110.3397617  BURNER ASSEMBLY
Kenmore 110.3398423  GAS BURNER
Kenmore 110.3401771  LAUNDRY SUB ASSEMBLIES
Kenmore 110.3401772  BURNER ASSEMBLY
Kenmore 110.3401795  3401795 BURNER ASSEMBLY
Kenmore 110.3401796  GAS DRYER BURNER
Kenmore 110.3401797  GAS BURNER ASSEMBLY
Kenmore 110.3401798  GAS DRYER BURNER
Kenmore 110.3401799  GAS DRYER BURNER ASSEMBLY
Kenmore 110.3402243  BURNER ASSEMBLY
Kenmore 110.3402844  BURNER ASSEMBLY
Kenmore 110.3402851  BURNER ASSEMBLY
Kenmore 110.3402855  BURNER ASSEMBLY
Kenmore 110.3402856  BURNER ASSEMBLY
Kenmore 110.341566  BURNER ASSEMBLY
Kenmore 110.343114  BURNER ASSEMBLY
Kenmore 110.344612  BURNER ASSEMBLY
Kenmore 110.344613  BURNER ASSEMBLY
Kenmore 110.349621  BURNER ASSEMBLY 60 HZ
Kenmore 110.349797  BURNER ASSEMBLY 60 HZ
Kenmore 110.349798  BURNER ASSEMBLY
Kenmore 110.349799  BURNER ASSEMBLY 60 HZ
Kenmore 110.349832  BURNER ASSEMBLY 50 HZ
Kenmore 110.349833  BURNER ASSEMBLY
Kenmore 110.349834  BURNER ASSEMBLY 50 HZ
Kenmore 110.349835  BURNER ASSEMBLY 50 HZ
Kenmore 110.357176  GEARCASE ASM
Kenmore 110.358486  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358488  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358519  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358794  GEAR CASE AND SUPERSTRUCTURE
Kenmore 110.359054  GEAR CASE AND SUPER STRUCTURE
Kenmore 110.359055  GEAR CASE AND SUPERSTRUCTURE
Kenmore 110.362140  GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110.42182200  AUTOMATIC WASHER
Kenmore 110.42182201  AUTOMATIC WASHER
Kenmore 110.42722200  AUTOMATIC WASHER
Kenmore 110.42722201  AUTOMATIC WASHER
Kenmore 110.42822200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42822201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42824200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42824201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42826200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42826201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42832200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42832201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42834200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42834201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42836200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42836201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42922200  WASHER
Kenmore 110.42924200  WASHER
Kenmore 110.42926200  WASHER
Kenmore 110.42932200  WASHER
Kenmore 110.42934200  WASHER
Kenmore 110.42936200  WASHER
Kenmore 110.4319351  BURNER ASSEMBLY
Kenmore 110.4319410  GAS DRYER BURNER
Kenmore 110.44832200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44834200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44836200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44932200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44934200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44936200  AUTOMATIC WASHER HORIZONTAL AXIS
  #2 (permalink)
Old 11-06-2009, 12:03 PM
sidfink43 sidfink43 is offline
Senior Expert
APP Volunteer
sidfink43 is on a distinguished road
Default
Two possibilities.
One is that you do not have the plastic cam that releases the brakes in the correct position. The second is that you do not have the transmission oriented in the right direction.
I have spent some frustrating times making these mistakes, so keep trying.
__________________
  #3 (permalink)
Old 11-06-2009, 12:20 PM
Junior Member
Default
Thanks Sidfink43. I was able to get the gearbox back in. The problem was the brake assy had dropped about an inch, a result of dropping the gearbox without unbolting the agitator first I guess. I was able to force the brake assy back into position and things seem to be running fine until the machine goes into the spin cycle. During the spin cycle everything goes out of balance. I have checked the springs and leveled the machine.
  #4 (permalink)
Old 11-06-2009, 01:37 PM
Senior Expert
APP Volunteer
Default
Yep, that will do it. Glad you got it figured out and back together.
Thanks also for the update.
__________________
  #5 (permalink)
Old 11-06-2009, 02:37 PM
Junior Member
Default
Sidfink43, Unfortunatley I have not been able to fix the violent agitator during spin cycle. Is there a chance that when the brake assembly dropped that it messed up the basket drive block or something else ? The spin cycle starts out normally but as it gains speed goes violently out of balance.
Thanks for the help
  #6 (permalink)
Old 11-06-2009, 02:46 PM
Senior Expert
APP Volunteer
Default
Can you tell us what the original problem was, and when you say violent agitator do you mean the agitator is moving, or is the tub moving rather wobbly and noisy.
If it is the tub the problem is typically the springs. You cannot tell anything about them by looking at them, you have to replace all three, which is a pretty good idea even if they are not the problem.
I have occasionally forgotten to take out he agitator bolt when removing a transmission, but after I went back and did it nothing seemed to be harmed, but I don't know what happened in your case. I doubt if it is the problem, so replace the springs and see how that works out.
__________________
  #7 (permalink)
Old 11-06-2009, 03:25 PM
Junior Member
Default
The original problem was I dropped the gearbox to check the clutch as the machine was not spinning the clothes entirely dry. It is the tub that is going nuts. It may be that when I laid the machine down it overstretched the springs. To get the gearbox to mate up I had to lightly tap the brake assy back into the brake drum with a wood block and hammer. I do not think it messed anything up as the wash cycle seems to work fine. So I will order some new springs and see if that stops the problem.
Thanks again for the support and advice.
  #8 (permalink)
Old 11-06-2009, 09:14 PM
Junior Member
Default
Found another post in your fourm that had a similar spin shake problem. Turns out the suspension plate had shifted when I laid the machine down to work on the gearbox. I followed the instructions in the post and reset the plate. everything is good. Thanks again for all the help.
  #9 (permalink)
Old 11-07-2009, 05:16 AM
Senior Expert
APP Volunteer
Default
Great, glad that fixed it and thanks again for the update.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Ice on back wall ? alcan Refrigerator & Freezer Repair 2 08-25-2009 08:44 AM
gearbox diagram bdail99 Washer Repair 2 03-29-2009 08:33 AM
How do I put belt back on? carlin_michael Washer Repair 1 02-09-2009 02:32 PM
having pronblem with puttin clip back on for top and back robert mcwhirter Washer Repair 1 11-06-2008 08:08 AM
Gearbox spin gear jhlash Washer Repair 1 06-13-2008 04:29 AM
