Discuss
Whirlpool Thin Twin Washer Repair Advice
 in
Washer Repair
I have a Whirlpool Thin Twin washer which has been leaking out from underneath the left side as the tub
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool Thin Twin Washer Repair Advice
  #1 (permalink)
Old 03-08-2018, 09:37 PM
Junior Member
sdl5 is on a distinguished road
Default Whirlpool Thin Twin Washer Repair Advice
Model Number: lte5243dt3   Brand: Whirlpool   Age: 5 - 10 years
I have a Whirlpool Thin Twin washer which has been leaking out from underneath the left side as the tub is filling when the washer is turned on. I took off the panels and was able to determine that once the water started filling the tub the water was coming out of the two holes I circled in red on the attached photo.
Can you tell me what I need to do to fix this problem?
Related Models
Whirlpool LTE5243DT3 LAUNDRY CENTER
Whirlpool LTE5243DT4 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DT5 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DT6 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DT7 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DZ0 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DZ1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DZ2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5500W1 ELECTRIC DRYER
Whirlpool LTE6234AN0 WASHER/DRYER
Whirlpool LTE6234AN1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234AN2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234AN3 COMBINATION UNITS
Whirlpool LTE6234AW0 WASHER/DRYER
Whirlpool LTE6234AW1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234AW2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234AW3 COMBINATION UNITS
Whirlpool LTE6234DQ0
Whirlpool LTE6234DQ1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DQ2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DQ3 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DQ4 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DQ5 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DQ6 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DT2 LAUNDRY CENTER
Whirlpool LTE6234DT3 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DT4 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DT5 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DT6 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DZ0
Whirlpool LTE6234DZ1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DZ2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6243AN2 LAUNDRY CENTER
Whirlpool LTE6243AW2 LAUNDRY CENTER
Whirlpool LTE7245AN0 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE7245AW0 WASHER/DRYER LAUNDRY SYSTEM
Frigidaire LTF1670DS0 Frigidaire/washer
Admiral LTF1812ARB REF - TOP MOUNT
Admiral LTF1812ARW REF - TOP MOUNT
Admiral LTF1812ARZ REF - TOP MOUNT
Admiral LTF2112ARB REF - TOP MOUNT
Admiral LTF2112ARW REF - TOP MOUNT
Admiral LTF2112ARZ REF - TOP MOUNT
Frigidaire LTF2140ES0 Frigidaire/washer
Frigidaire LTF2140ES1 Frigidaire/washer
Frigidaire LTF2140ES2 Frigidaire/washer
Frigidaire LTF2140ES3 Frigidaire/washer
Frigidaire LTF2140FS0 Frigidaire/washer
Frigidaire LTF2140FS1 WASHER
Frigidaire LTF2140FS2 WASHER
Frigidaire LTF2940EE0 Frigidaire/washer
Frigidaire LTF2940ES0 Frigidaire/washer
Frigidaire LTF2940ES1 Frigidaire/washer
Frigidaire LTF2940ES2 Frigidaire/washer
Frigidaire LTF2940ES3 Frigidaire/washer
Frigidaire LTF2940FE0 Frigidaire/washer
Frigidaire LTF2940FE1 WASHER
Frigidaire LTF2940FS1 WASHER
Frigidaire LTF530DS0 Frigidaire/washer
Frigidaire LTF530DS1 Frigidaire/washer
Frigidaire LTF530FS0 Frigidaire/washer
Frigidaire LTF530FS1 WASHER
Frigidaire LTF6000ES0 Frigidaire/washer
Frigidaire LTF6000ES1 Frigidaire/washer
Frigidaire LTF6000FS0 Frigidaire/washer
Frigidaire LTF6700FS0 WASHER
Frigidaire LTF7000EG0 Frigidaire/washer
Frigidaire LTF7000ES0 Frigidaire/washer
Frigidaire LTF7000ES1 Frigidaire/washer
Frigidaire LTF7000FG0 Frigidaire/washer
Frigidaire LTF8000FE0 WASHER
Whirlpool LTG5243BN0 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243BN1 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243BN2 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243BW0 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243BW1 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243BW2 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ0 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ1 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ2 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ3 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ4 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ5 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ6 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ7 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ8 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ9 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQA WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DT2 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DT3 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DT4 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DT5 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DT6 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DT7 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DT8 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DZ0 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DZ1 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DZ2 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG6234AN0 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234AN1 COMBINATION UNITS
Whirlpool LTG6234AN2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234AN3 COMBINATION UNITS
Whirlpool LTG6234AW0 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234AW1 COMBINATION UNITS
Whirlpool LTG6234AW2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234AW3 COMBINATION UNITS
Whirlpool LTG6234DQ0
Whirlpool LTG6234DQ1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234DQ2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234DQ3 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234DQ4 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234DQ5 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234DT1 LAUNDRY CENTER
Whirlpool LTG6234DT2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234DT3 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234DT4 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234DT5 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234DZ0
Whirlpool LTG6234DZ1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG7245AN0 WASHER/DRYER
  #2 (permalink)
Old 03-09-2018, 06:08 AM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
I've seen this a few times back when I used to work on appliances. Usually it was hard water building up in the center of that plastic part. The hard water deposits would make water spray out at odd angles instead of straight down.
Usually disassembly and a complete cleaning restored it to working order.
Its part no. 16 on this diagram if you should need a new one.
Parts for Whirlpool LTE5243DT3: Washer Cabinet Parts - AppliancePartsPros.com
  #3 (permalink)
Old 03-10-2018, 10:23 PM
Junior Member
Default
Thanks you helped me out a lot. There was hard water buildup inside that part. Removed hoses and the siphon and immersed the siphon in vinegar solution for an hour or two then used a pocketknife to scrape the hard water buildup away. Buildup easily came off. Rinsed with water, then reinstalled and tested. Worked like a charm. No more leaking.
  #4 (permalink)
Old 03-11-2018, 12:14 AM
ThatGuy's Avatar
Expert
APP Volunteer
Default
You're welcome.
  #5 (permalink)
Old 03-23-2018, 01:39 AM
Junior Member
Default New Issues
Quote:
Originally Posted by ThatGuy View Post
You're welcome.
So I had a few separate issues pop up since you last helped me. I'll list them out below:
1. The washer tub is off centered as seen in the attached photo when empty. If I try to pull the tub back to the center of the opening from the bottom of the tub I hear the sound of spring(s) creaking and it returns to the off centered position when I let go. Not sure if this is related to my next issue but..
2. During the spin cycle I have a repetitive squeaking noise.
I'm guessing I'll need to replace parts this time so if you've seen this before any help would be appreciated.
  #6 (permalink)
Old 03-23-2018, 05:12 AM
ThatGuy's Avatar
Expert
APP Volunteer
Default
You're going to need to pull the front and check the springs. Parts no. 4 and 5 on this diagram.
Parts for Whirlpool LTE5243DT3: Machine Base Parts - AppliancePartsPros.com
Also check the base and the support (part 19). Check them for cracks and loose or worn parts.
  #7 (permalink)
Old 03-30-2018, 01:12 AM
Junior Member
Default
I took apart the washing machine and put new suspension and stabilizing springs in but I think there's another problem. I basically took apart and put the entire machine back together (checked clutch as well).
I did 2 wash cycles and during the second cycle the front panel of the washing machine was quite hot to the touch. Hot enough that I thought it was abnormal and stopped the wash cycle. Do you know what could be causing this? I don't know if I put something back together incorrectly or what
Also this silver colored part fell out from under the washing machine during the first cycle. I'm not sure where the rubber pieces came from but I didn't know where to put them back when I re-assembled.
  #8 (permalink)
Old 03-30-2018, 01:17 AM
Junior Member
Default
Here's the photo of the parts. Btw the heat on the front panels is coming from the area of the water pump/electrical connection in the front left. I'll see if it does it on the lighter clothes cycle days from now if I can't resolve it before then.
  #9 (permalink)
Old 03-30-2018, 01:31 AM
Junior Member
Default
Remembering where everything was when it was opened up the strongest heat feels like it's coming from the area of where the ground wire is bolted to the bottom of the front panel. Why is this getting hot all of a sudden?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Thin Twin washer not draining computer_dr Washer Repair 4 05-04-2016 08:10 PM
Thin-Twin whirlpool LTE6234DQ2 washer levendel Washer Repair 6 11-03-2012 07:29 PM
leaking whirlpool thin twin washer trevorroehl Washer Repair 1 09-06-2009 05:21 PM
Whirlpool Thin Twin Washer Problem mineolabauer Dryer Repair 1 12-01-2008 08:45 AM
