Discuss
Kenmore Elite - F20 error
 in
Washer Repair
Getting F20 error about 75% of the time we run washer. If I unplug it and then plug it back
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore Elite - F20 error
  #1 (permalink)
Old 03-07-2018, 05:17 AM
Junior Member
Rob W. is on a distinguished road
Default Kenmore Elite - F20 error
Model Number: 11047789701   Brand: Kenmore   Age: 5 - 10 years
Getting F20 error about 75% of the time we run washer. If I unplug it and then plug it back in, it will run fine for one cycle usually. It also seems that if I run a small load I don't get the F20 error. I've checked the intake hoses and screen. thoughts?
Related Models
Kenmore 11047789701 RESIDENTIAL WASHER
Kenmore 11047789702 WASHER
Kenmore 11047791700 RESIDENTIAL WASHER
Kenmore 11047791701 RESIDENTIAL WASHER
Kenmore 11047791702 WASHER
Kenmore 11047797800 RESIDENTIAL WASHER
Kenmore 11047797801 WASHER
Kenmore 11047798800 RESIDENTIAL WASHER
Kenmore 11047798801 WASHER
Kenmore 11047799701 RESIDENTIAL WASHER
Kenmore 11047799702 WASHER
Kenmore 11047852700 WASHER
Kenmore 11047852701 RESIDENTIAL WASHER
Kenmore 11047852702 RESIDENTIAL WASHER
Kenmore 11047852703 RESIDENTIAL WASHER
Kenmore 11047882700 WASHER
Kenmore 11047882701 RESIDENTIAL WASHER
Kenmore 11047882702 RESIDENTIAL WASHER
Kenmore 11047882703 RESIDENTIAL WASHER
Kenmore 11048182790 AUTOMATIC WASHER
Kenmore 11048182791 AUTOMATIC WASHER
Kenmore 11048184790 AUTOMATIC WASHER
Kenmore 11048184791 AUTOMATIC WASHER
Kenmore 11048722790 COMPACT AUTOMATIC WASHER
Kenmore 11048722791 COMPACT AUTOMATIC WASHER
Kenmore 11048724790 COMPACT AUTOMATIC WASHER
Kenmore 11048724791 COMPACT AUTOMATIC WASHER
Kenmore 11049182990 AUTOMATIC WASHER
Kenmore 11049182991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11049182992 WASHER
Kenmore 11049722990 AUTOMATIC WASHER
Kenmore 11049722991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11049722992 COMPACT WASHER
Kenmore 11049962600 WASHER
Kenmore 11049962601 RESIDENTIAL WASHER
Kenmore 11049962602 RESIDENTIAL WASHER
Kenmore 11049962603 RESIDENTIAL WASHER
Kenmore 11049972600 RESIDENTIAL WASHER
Kenmore 11049972601 RESIDENTIAL WASHER
Kenmore 11049972602 RESIDENTIAL WASHER
Kenmore 11049972603 RESIDENTIAL WASHER
Kenmore 1105062110 WASHER
Kenmore 110508802 KENMORE ELECTRIC DRYER
Kenmore 11051140 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11051309 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11051730 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11055592 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11055593 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11055610 WORM GEAR CASE ASSEMBLY
Kenmore 11055614 WORM GEAR CASE ASSEMBLY
Kenmore 11056171 WORM GEAR CASE ASSEMBLY
Kenmore 11056172 WORM GEAR CASE ASSEMBLY
Kenmore 11056464 WORM GEAR CASE ASSEMBLY
Kenmore 1105801100 KENMORE WRINGER WASHER
Kenmore 1105801200 KENMORE WRINGER WASHER
Kenmore 1105802301 KENMORE WRINGER WASHER
Kenmore 1105802330 KENMORE WRINGER WASHER
Kenmore 1105802331 KENMORE WRINGER WASHER
Kenmore 1105802400 KENMORE WRINGER WASHER
Kenmore 1105802600 KENMORE WRINGER WASHER
Kenmore 1105802601 KENMORE WRINGER WASHER
Kenmore 1105802700 KENMORE WRINGER WASHER
Kenmore 1105802701 KENMORE WRINGER WASHER
Kenmore 1105802800 KENMORE WRINGER WASHER
Kenmore 1105802801 KENMORE WRINGER WASHER
Kenmore 1105802901 KENMORE WRINGER WASHER
Kenmore 1105802910 KENMORE WRINGER WASHER
Kenmore 1105803000 KENMORE SEMI-AUTOMATIC WASHER
Kenmore 1105804100 KENMORE AUTOMATIC WASHER
Kenmore 1105804200 KENMORE AUTOMATIC WASHER
Kenmore 1105804201 KENMORE AUTOMATIC WASHER
Kenmore 1105804202 KENMORE AUTOMATIC WASHER
Kenmore 1105804203 KENMORE AUTOMATIC WASHER
Kenmore 1105804300 KENMORE AUTOMATIC WASHER
Kenmore 1105804301 KENMORE AUTOMATIC WASHER
Kenmore 1105804302 KENMORE AUTOMATIC WASHER
Kenmore 1105804303 KENMORE AUTOMATIC WASHER
Kenmore 1105804500 KENMORE AUTOMATIC WASHER
Kenmore 1105804501 KENMORE AUTOMATIC WASHER
Kenmore 1105804550 KENMORE AUTOMATIC WASHER
Kenmore 1105804551 KENMORE AUTOMATIC WASHER
Kenmore 1105804700 KENMORE AUTOMATIC WASHER
Kenmore 1105804702 KENMORE AUTOMATIC WASHER
Kenmore 1105804750 KENMORE AUTOMATIC WASHER
Kenmore 1105804752 KENMORE AUTOMATIC WASHER
Kenmore 1105804800 KENMORE AUTOMATIC WASHERS
Kenmore 1105804801 KENMORE AUTOMATIC WASHER
Kenmore 1105804802 KENMORE AUTOMATIC WASHER
Kenmore 1105804803 KENMORE AUTOMATIC WASHER
Kenmore 1105804804 KENMORE AUTOMATIC WASHER
Kenmore 1105804850 KENMORE AUTOMATIC WASHERS
Kenmore 1105804851 KENMORE AUTOMATIC WASHER
Kenmore 1105804852 KENMORE AUTOMATIC WASHER
Kenmore 1105804853 KENMORE AUTOMATIC WASHER
Kenmore 1105804854 KENMORE AUTOMATIC WASHER
Kenmore 1105804950 KENMORE AUTOMATIC WASHER
Kenmore 1105804951 KENMORE AUTOMATIC WASHER
Kenmore 1105804952 KENMORE AUTOMATIC WASHER
Kenmore 1105804953 KENMORE AUTOMATIC WASHER
Kenmore 1105805100 KENMORE AUTOMATIC WASHER
Kenmore 1105805200 KENMORE AUTOMATIC WASHER
Kenmore 1105805201 KENMORE AUTOMATIC WASHER
Kenmore 1105805202 KENMORE AUTOMATIC WASHER
Kenmore 1105805203 KENMORE AUTOMATIC WASHER
Kenmore 1105805300 KENMORE AUTOMATIC WASHER
Kenmore 1105805301 KENMORE AUTOMATIC WASHER
Kenmore 1105805302 KENMORE AUTOMATIC WASHER
Kenmore 1105805303 KENMORE AUTOMATIC WASHER
Kenmore 1105805500 KENMORE AUTOMATIC WASHER
Kenmore 1105805501 KENMORE AUTOMATIC WASHER
Kenmore 1105805550 KENMORE AUTOMATIC WASHER
Kenmore 1105805551 KENMORE AUTOMATIC WASHER
Kenmore 1105805700 KENMORE AUTOMATIC WASHER
Kenmore 1105805702 KENMORE AUTOMATIC WASHER
Kenmore 1105805750 KENMORE AUTOMATIC WASHER
Kenmore 1105805752 KENMORE AUTOMATIC WASHER
Kenmore 1105805800 KENMORE AUTOMATIC WASHERS
Kenmore 1105805801 KENMORE AUTOMATIC WASHER
Kenmore 1105805802 KENMORE AUTOMATIC WASHER
Kenmore 1105805803 KENMORE AUTOMATIC WASHER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Elite F02 error elrothir Washer Repair 0 06-14-2017 01:51 PM
Kenmore Elite Error Er rf ressman Refrigerator & Freezer Repair 0 10-25-2016 07:15 PM
Kenmore Elite HE 3t F02 Error KCPL Washer Repair 1 01-28-2013 05:22 PM
F-13 error on Kenmore Elite 2wideglide4 Oven Repair (including Ranges and Cooktops) 2 04-02-2010 08:24 AM
kenmore elite he3 -- F 05 error??? deannahoffmann Washer Repair 1 02-26-2009 05:46 AM
