Discuss
Maytag Centennial stuck at Sensing
 in
Washer Repair
I have a Maytag Centennial that will not start. The lid locks ok, red led stays on, then Sensing light
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Centennial stuck at Sensing
  #1 (permalink)
Old 03-06-2018, 09:02 AM
Junior Member
mjd50 is on a distinguished road
Default Maytag Centennial stuck at Sensing
Brand: Maytag   Age: 1 - 5 years
I have a Maytag Centennial that will not start. The lid locks ok, red led stays on, then Sensing light comes on, stays on and I hear the motor? trying to start up for a second then nothing. It will do this forever until i cancel.
It ran through the manual diag cycle normally. So water, spins, rinse, drain all work.
I tried to get error codes, but when I cycle through the codes, I just get 1,2,3,4,5....1F. It doesn't flash LEDs with a code. I'm thinking it never stops trying to run, so no code generated.
any help is greatly appreciated. I'm guess a sensing issue.
thanks
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Maxima gets stuck in sensing amgropl Washer Repair 0 02-06-2018 10:30 AM
Maytag Bravos MCT stuck in sensing trusbos25 Washer Repair 0 01-12-2018 10:14 PM
Maytag Centennial Alternating Between Cold and Hot Water in Sensing and Wash Cycle ptnb1582 Washer Repair 0 02-11-2017 09:40 AM
Maytag Centennial sits on sensing mode. nadroj186 Washer Repair 0 03-16-2013 12:46 PM
