Discuss
Help replacing suspension rod kit
 in
Washer Repair
I replace suspension rods with a new kit. Everything went well until I noticed space between inner & outer tub
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Help replacing suspension rod kit
  #1 (permalink)
Old 02-19-2018, 01:36 PM
Junior Member
Pbennedum is on a distinguished road
Default Help replacing suspension rod kit
Model Number: Rpw4640yq0   Brand: Roper   Age: 5 - 10 years
I replace suspension rods with a new kit. Everything went well until I noticed space between inner & outer tub in the back near lid hinge
Related Models
Amana RR MWAVE - FAMILY SIZE (60 HZ)
Amana RR-1 RANGE- S/C S/I DDRAFT GAS
Amana RR-10 MWAVE - FAMILY SIZE (60 HZ)
Amana RR-1000 RANGE- S/C S/I DDRAFT GAS
Amana RR-1000 MWAVE- CNTRTP / STAND ALONE
Amana RR-1010 RANGE- S/C S/I DDRAFT GAS
Amana RR-1010 MWAVE- CNTRTP / STAND ALONE
Amana RR-10A MWAVE - FAMILY SIZE (60 HZ)
Amana RR-10A MWAVE- CNTRTP / STAND ALONE
Amana RR-1110 MWAVE - FAMILY SIZE (60 HZ)
Amana RR-1225 MWAVE- CNTRTP / STAND ALONE
Amana RR-3H RANGE- S/C S/I DDRAFT GAS
Amana RR-4 RANGE- S/C S/I DDRAFT GAS
Amana RR-4D RANGE- S/C S/I DDRAFT GAS
Amana RR-4DW RANGE- S/C S/I DDRAFT GAS
Amana RR-5B MWAVE- CNTRTP / STAND ALONE
Amana RR-7 RANGE- S/C S/I DDRAFT GAS
Amana RR-700 RANGE- S/C S/I DDRAFT GAS
Amana RR-700 MWAVE- CNTRTP / STAND ALONE
Amana RR-7A MWAVE - FAMILY SIZE (60 HZ)
Amana RR-7B MWAVE - FAMILY SIZE (60 HZ)
Amana RR-7B MWAVE- CNTRTP / STAND ALONE
Amana RR-7D RANGE- S/C S/I DDRAFT GAS
Amana RR-7DA MWAVE - FAMILY SIZE (60 HZ)
Amana RR-8 MWAVE - FAMILY SIZE (60 HZ)
Amana RR-800 MWAVE- CNTRTP / STAND ALONE
Amana RR-810 MWAVE- CNTRTP / STAND ALONE
Amana RR-810 MWAVE - FAMILY SIZE (60 HZ)
Amana RR-820 MWAVE- CNTRTP / STAND ALONE
Amana RR-8A MWAVE - FAMILY SIZE (60 HZ)
Amana RR-8B MWAVE - FAMILY SIZE (60 HZ)
Amana RR-8T MWAVE- CNTRTP / STAND ALONE
Amana RR-8TC MWAVE- CNTRTP / STAND ALONE
Amana RR-9 RANGE- S/C S/I DDRAFT GAS
Amana RR-900 MWAVE- CNTRTP / STAND ALONE
Amana RR-910 RANGE- S/C S/I DDRAFT GAS
Amana RR-910 MWAVE- CNTRTP / STAND ALONE
Amana RR-9T MWAVE - FAMILY SIZE (60 HZ)
Amana RR-9TA MWAVE - FAMILY SIZE (60 HZ)
Amana RR-9TA MWAVE- CNTRTP / STAND ALONE
Amana RR-9TB MWAVE - FAMILY SIZE (60 HZ)
Amana RR-9TB MWAVE- CNTRTP / STAND ALONE
Amana RR-II RANGE- S/C S/I DDRAFT GAS
Amana RR1020 MWAVE- CNTRTP / STAND ALONE
Amana RR1220 MWAVE- CNTRTP / STAND ALONE
Amana RR2 MWAVE- CNTRTP / STAND ALONE
Amana RR510 MWAVE- CNTRTP / STAND ALONE
Amana RR510A MWAVE- CNTRTP / STAND ALONE
Amana RR52 MWAVE - FAMILY SIZE (60 HZ)
Amana RR54 MWAVE - FAMILY SIZE (60 HZ)
Amana RR54D MWAVE- CNTRTP / STAND ALONE
Amana RR56 MWAVE- CNTRTP / STAND ALONE
Amana RR57D MWAVE- CNTRTP / STAND ALONE
Amana RR59T MWAVE- CNTRTP / STAND ALONE
Amana RR6W MWAVE- CNTRTP / STAND ALONE
Amana RR7 MWAVE- CNTRTP / STAND ALONE
Amana RR720 MWAVE- CNTRTP / STAND ALONE
Amana RR9 MWAVE- CNTRTP / STAND ALONE
Amana RR920 MWAVE- CNTRTP / STAND ALONE
Amana RRC57D MWAVE- CNTRTP / STAND ALONE
Amana RRH-10 MWAVE - FAMILY SIZE (60 HZ)
Amana RRL-10A MWAVE - FAMILY SIZE (60 HZ)
Amana RRL-10A MWAVE- CNTRTP / STAND ALONE
Amana RRL-10C MWAVE- CNTRTP / STAND ALONE
Amana RRL-10TD MWAVE - FAMILY SIZE (60 HZ)
Amana RRL-10TD MWAVE- CNTRTP / STAND ALONE
Amana RRL-10XA MWAVE - FAMILY SIZE (60 HZ)
Amana RRL-5C MWAVE - FAMILY SIZE (60 HZ)
Amana RRL-5D MWAVE - FAMILY SIZE (60 HZ)
Amana RRL-5D MWAVE- CNTRTP / STAND ALONE
Amana RRL-7C MWAVE - FAMILY SIZE (60 HZ)
Amana RRL-7C MWAVE- CNTRTP / STAND ALONE
Amana RRL-8T MWAVE- CNTRTP / STAND ALONE
Amana RRL-8TC MWAVE- CNTRTP / STAND ALONE
Amana RRL-8TD MWAVE - FAMILY SIZE (60 HZ)
Amana RRL-8TD MWAVE- CNTRTP / STAND ALONE
Amana RRL-8X MWAVE - FAMILY SIZE (60 HZ)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fisher & Paykel Wobble after replacing Suspension Rods WL26CW1 Washer Repair 0 07-25-2017 01:14 PM
Replacing suspension assembly EKD88 Washer Repair 0 12-02-2014 07:38 AM
Replacing Rod & Spring suspension on WCRE6270D1WW bdlindberg Washer Repair 2 09-17-2010 11:49 AM
