Discuss
"Best Practices" for extending spider arm life
 in
Washer Repair
Having read so much about spider arm failures and corrosion on FL washers, and having had this happen on my
Appliance Repair Forum > Appliance Repair Help > Washer Repair » "Best Practices" for extending spider arm life
  #1 (permalink)
Old 02-15-2018, 11:03 AM
Junior Member
rschleicher is on a distinguished road
Default "Best Practices" for extending spider arm life
Model Number: WM3670HWA (LG)   Brand: -other-   Age: Less than 1 year
Having read so much about spider arm failures and corrosion on FL washers, and having had this happen on my prior GE, I am interested in doing whatever I can to ensure a long life for the spider arm in my new FL washer (an LG).
So I'd like to tap into the collective wisdom of this forum, for "best practices", aimed at extending the lifetime of aluminum spider arms, and minimizing long-term failures due to corrosion. (I realize that there are also multiple schools of thought on the root cause of corrosion, including the use of dissimilar metals (aluminum mated to stainless steel), as well as the effects of alkalinity.... Basically, what are you all doing, or not doing?
So here's what I've gleaned so far:
1. Use as little HE detergent as possible - 1 or 2 tablespoons, tops.
I've seen some recommendations to use powdered HE detergent, and not liquid, due to the use of animal fats in the liquids. Does this really matter?
2. Don't use liquid fabric softener at all (mostly for the same animal fats reasoning, but also related to the fact that it is dispensed later in the cycle, and therefore isn't rinsed away as much).
3. Avoid use of bleaches that raise the alkalinity, which might contribute to corrosion of the aluminum spider arm.
4. Use the washer's "clean cycle" frequently, say once a month.
Ah, but with what? It seems that most washer makers recommend a commercial "washer cleaner" product, or chlorine bleach, for their clean cycle. But those are fairly highly alkaline, so do they cause more harm than good?
I've also seen multiple recommendations (internet sites, not from manufacturers) to use white vinegar in the clean cycle, and even to use white vinegar as a fabric softener. Seems like a potentially good idea - any reason NOT to do this?
As a side comment, I notice that Samsung's current model owner's manuals call for running their clean cycle with nothing added to the dispenser - just a very hot water cycle. Is this an acknowledgement that the usual bleach and washer cleaner products are NOT good?
Of course, bleach and washer cleaner products are presumably more effective at preventing mold, versus using vinegar or just hot water, so there's that trade-off to consider...
All of the above may well be a case of "over-thinking" things - maybe the real best practice is just to not worry about it, and hope for the best!
As another side comment, our local tap water is fairly alkaline, at least at the water treatment plant - it's above 9.0. So maybe my worrying about using a little bleach is foolish....
Related Models
 WM3677HW Washer
 WM3988HWA Washer
Amana WM612 MWAVE- CNTRTP / STAND ALONE
Amana WM614 MWAVE- CNTRTP / STAND ALONE
Amana WM615 MWAVE- CNTRTP / STAND ALONE
Amana WM712 MWAVE- CNTRTP / STAND ALONE
Amana WM714 MWAVE- CNTRTP / STAND ALONE
Amana WM715 MWAVE- CNTRTP / STAND ALONE
General Electric WMCD2050G0WC Washer
General Electric WMCD2050H0WC WASHER
General Electric WMCD2050H1WC WASHER
General Electric WMCD2050H2WC WASHER
General Electric WMCD2050H3WC WASHER
General Electric WMCD2050H4WC WASHER
General Electric WMCD2050H5WC WASHER
General Electric WMCD2050H6WC COIN-OP WASHER
General Electric WMCD2050J0WC COIN-OP WASHER
General Electric WMCD2050J1WC WASHER
Jenn-Air WME3020B WALLOVEN- S/C MWAVE ELE
Jenn-Air WME3020W WALLOVEN- S/C MWAVE ELE
Jenn-Air WMG3020B WALLOVEN- S/C MWAVE GAS
Jenn-Air WMG3020W WALLOVEN- S/C MWAVE GAS
Whirlpool WMH1162XVB0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVB1 Microwave Oven 1.6 Cu. Ft.
Whirlpool WMH1162XVB2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVB3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVB4 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVD0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVD1 Microwave Oven 1.6 Cu. Ft.
Whirlpool WMH1162XVD2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVD3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVD4 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVQ0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVQ1 Microwave Oven 1.6 Cu. Ft.
Whirlpool WMH1162XVQ2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVQ3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVQ4 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVS0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVS1 Microwave Oven 1.6 Cu. Ft.
Whirlpool WMH1162XVS2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVS3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVS4 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVB0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVB1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVB2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVD0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVD1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVD2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVQ0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVQ1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVQ2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVS0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVS1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVS2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVS3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1164XVS0 MICROWAVE OVEN 1.6 Cu. Ft.
Whirlpool WMH1164XVS1 MICROWAVE OVEN 1.6 Cu. Ft.
Whirlpool WMH1164XVS2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1164XVS3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1164XWS0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1164XWS1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1164XWS2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH2175XVB0 Microwave Oven 1.7 Cu. Ft.
Whirlpool WMH2175XVB1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH2175XVB2 MICROWAVE OVEN 1.7 CU. FT.
Whirlpool WMH2175XVQ0 Microwave Oven 1.7 Cu. Ft.
Whirlpool WMH2175XVQ1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH2175XVQ2 MICROWAVE OVEN 1.7 CU. FT.
Whirlpool WMH2175XVS0 Microwave Oven 1.7 Cu. Ft.
Whirlpool WMH2175XVS1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH2175XVS2 MICROWAVE OVEN 1.7 CU. FT.
Whirlpool WMH2175XVT0 Microwave Oven 1.7 Cu. Ft.
Whirlpool WMH2175XVT1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH2175XVT2 MICROWAVE OVEN 1.7 CU. FT.
Whirlpool WMH2205XVB0 Microwave Oven/Hood 2.0 Cu. Ft.
Whirlpool WMH2205XVB1 Microwave Oven/Hood 2.0 Cu. Ft.
Whirlpool WMH2205XVQ0 Microwave Oven/Hood 2.0 Cu. Ft.
Whirlpool WMH2205XVQ1 Microwave Oven/Hood 2.0 Cu. Ft.
Whirlpool WMH2205XVS0 Microwave Oven/Hood 2.0 Cu. Ft.
Whirlpool WMH2205XVS1 Microwave Oven/Hood 2.0 Cu. Ft.
Whirlpool WMH3205XVB0 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Whirlpool WMH3205XVB1 MICROWAVE HOOD COMBO
Whirlpool WMH3205XVB2 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Whirlpool WMH3205XVQ0 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Whirlpool WMH3205XVQ1 MICROWAVE HOOD COMBO
Whirlpool WMH3205XVQ2 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Whirlpool WMH3205XVS0 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Whirlpool WMH3205XVS1 MICROWAVE HOOD COMBO
Whirlpool WMH3205XVS2 MICROWAVE OVEN/HOOD 2.0 CU. FT.
General Electric WMR03GAZABB REFRIGERATOR
General Electric WMR04BANABB Refrigerator
General Electric WMR04BANBBB Refrigerator
General Electric WMR04BANCBB Refrigerator
General Electric WMR04BANDBB Refrigerator
General Electric WMR04BAPABB Refrigerator
General Electric WMR04BAVABB REFRIGERATOR
General Electric WMR04DATABB Refrigerator
General Electric WMR04GAVABB REFRIGERATOR
General Electric WMR04GAVBBB REFRIGERATOR
General Electric WMR04GAVCBB REFRIGERATOR
General Electric WMR04GAZABB REFRIGERATOR
General Electric WMR04GAZAWW REFRIGERATOR
General Electric WMSE3140A0AA Washer
General Electric WMSE3140A0WW Washer
General Electric WMSE3140A2WW Washer
General Electric WMSE3140A3WW Washer
General Electric WMSE4190A0AA Washer
General Electric WMSE4190A0WW Washer
General Electric WMSE4230A0WW Washer
General Electric WMSR2090T2AA Washer
General Electric WMSR2090T2WW Washer
General Electric WMSR2090T3AA Washer
General Electric WMSR2090T3WW Washer
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Getting error code display on indicator "Er" & "uo"" Jereaves Dishwasher Repair 0 03-25-2014 07:54 PM
Neptune MD5500 Washer:Error Codes "do" and "FL" with a triple beep and a buzzer sound neptune123 Washer Repair 1 06-12-2011 04:14 PM
oven "moaning" sound then faint "poof" sound; later, large "poof" popped door open samej71 Oven Repair (including Ranges and Cooktops) 2 03-24-2010 07:05 AM
