Discuss
Washer drum out of balance on spin
 in
Washer Repair
The basket stopped spinning so I replaced the motor couplings and later the transmission. After replacing the transmission and putting
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer drum out of balance on spin
  #1 (permalink)
Old 02-04-2018, 05:59 PM
Junior Member
breckrider is on a distinguished road
Default Washer drum out of balance on spin
Model Number: 11025842400   Brand: Kenmore   Age: More than 10 years
The basket stopped spinning so I replaced the motor couplings and later the transmission. After replacing the transmission and putting everything back together, I ran the washer on a spin cycle and noticed that it spun out of balance. I have since replaced all the balance springs but not the counterbalance spring. All of the springs appeared to be in good shape though. None of them had come loose or were broken.
It still spins out of balance. Not horribly but it's noticeable.
I talked with a tech on a repair site and they suggested I take the transmission back out and put it back in because it could have been installed incorrectly but I can't imagine how that could happen.
Any other suggestions? If I need to, I can make a video of the spin and upload it I think.
Related Models
Kenmore 11025842400 AUTOMATIC WASHER
Kenmore 11025844400 AUTOMATIC WASHER
Kenmore 11025852400 AUTOMATIC WASHER
Kenmore 11025854400 AUTOMATIC WASHER
Kenmore 11025862400 AUTOMATIC WASHER
Kenmore 11025864400 AUTOMATIC WASHER
Kenmore 11026002010 AUTOMATIC WASHER
Kenmore 11026002011 AUTOMATIC WASHER
Kenmore 11026012010 AUTOMATIC WASHER
Kenmore 11026012011 AUTOMATIC WASHER
Kenmore 11026051690 COMMERCIAL AUTOMATIC WASHER
Kenmore 11026058690 COMMERCIAL AUTOMATIC WASHER
Kenmore 11026071690 COMMERCIAL WASHER
Kenmore 11026071691 COMMERCIAL WASHER
Kenmore 11026152500 WASHER COMMERCIAL
Kenmore 11026292690 AUTOMATIC WASHER
Kenmore 11026292691 AUTOMATIC WASHER
Kenmore 11026292692 AUTOMATIC WASHER
Kenmore 11026292693 AUTOMATIC WASHER
Kenmore 11026292694 WASHER
Kenmore 11026292695 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11026294690 AUTOMATIC WASHER
Kenmore 11026294691 AUTOMATIC WASHER
Kenmore 11026294692 AUTOMATIC WASHER
Kenmore 11026294693 AUTOMATIC WASHER
Kenmore 11026294694 WASHER
Kenmore 11026294695 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11026322500 WASHER
Kenmore 11026322501 WASHER
Kenmore 11026322502 RESIDENTIAL WASHER
Kenmore 11026322503 RESIDENTIAL WASHER
Kenmore 11026332500 RESIDENTIAL WASHER
Kenmore 11026332501 WASHER
Kenmore 11026332502 RESIDENTIAL WASHER
Kenmore 11026332503 RESIDENTIAL WASHER
Kenmore 11026342500 RESIDENTIAL WASHER
Kenmore 11026342501 WASHER
Kenmore 11026342502 RESIDENTIAL WASHER
Kenmore 11026342503 RESIDENTIAL WASHER
Kenmore 11026422500 RESIDENTIAL WASHER
Kenmore 11026422501 WASHER
Kenmore 11026422502 RESIDENTIAL WASHER
Kenmore 11026422503 RESIDENTIAL WASHER
Kenmore 11026432500 WASHER
Kenmore 11026432501 WASHER
Kenmore 11026432502 RESIDENTIAL WASHER
Kenmore 11026432503 RESIDENTIAL WASHER
Kenmore 1102644182 RESIDENTIAL WASHER
Kenmore 11026442500 WASHER
Kenmore 11026442501 WASHER
Kenmore 11026442502 RESIDENTIAL WASHER
Kenmore 11026442503 RESIDENTIAL WASHER
Kenmore 1102644722 RESIDENTIAL WASHER
Kenmore 11026622690 WASHER
Kenmore 11026622691 AUTOMATIC WASHER
Kenmore 11026632500 WASHER
Kenmore 11026632501 WASHER
Kenmore 11026632502 WASHER
Kenmore 11026632503 RESIDENTIAL WASHER
Kenmore 11026642500 WASHER
Kenmore 11026642501 washer
Kenmore 11026642502 WASHER
Kenmore 11026642503 RESIDENTIAL WASHER
Kenmore 11026652500 WASHER
Kenmore 11026652501 WASHER
Kenmore 11026652502 WASHER
Kenmore 11026652503 RESIDENTIAL WASHER
Kenmore 11026682503 RESIDENTIAL WASHER
Kenmore 11026692503 RESIDENTIAL WASHER
Kenmore 11026702690 AUTOMATIC WASHER
Kenmore 11026702691 AUTOMATIC WASHER
Kenmore 11026702692 AUTOMATIC WASHER
Kenmore 11026702693 AUTOMATIC WASHER
Kenmore 11026702694 AUTOMATIC WASHER
Kenmore 11026712690 WASHER
Kenmore 11026712691 AUTOMATIC WASHER
Kenmore 11026712692 AUTOMATIC WASHER
Kenmore 11026712693 AUTOMATIC WASHER
Kenmore 11026722690 WASHER
Kenmore 11026722691 AUTOMATIC WASHER
Kenmore 11026722692 AUTOMATIC WASHER
Kenmore 11026722693 AUTOMATIC WASHER
Kenmore 11026732500 WASHER
Kenmore 11026732501 WASHER
Kenmore 11026732502 WASHER
Kenmore 11026732503 RESIDENTIAL WASHER
Kenmore 11026742500 WASHER
Kenmore 11026742501 WASHER
Kenmore 11026742502 WASHER
Kenmore 11026742503 RESIDENTIAL WASHER
Kenmore 11026752500 WASHER
Kenmore 11026752501 WASHER
Kenmore 11026752502 WASHER
Kenmore 11026752503 RESIDENTIAL WASHER
Kenmore 11026791690 AUTOMATIC WASHER
Kenmore 11026791691 AUTOMATIC WASHER
Kenmore 11026801690 AUTOMATIC WASHER
Kenmore 11026801691 AUTOMATIC WASHER
Kenmore 11026801692 AUTOMATIC WASHER
Kenmore 11026808690 WASHER
Kenmore 11026808691 AUTOMATIC WASHER
Kenmore 11026808692 AUTOMATIC WASHER
Kenmore 11026809690 AUTOMATIC WASHER
Kenmore 11026812690 WASHER
Kenmore 11026812691 AUTOMATIC WASHER
Kenmore 11026814690 WASHER
Kenmore 11026814691 AUTOMATIC WASHER
Kenmore 11026822690 WASHER
Kenmore 11026822691 AUTOMATIC WASHER
Kenmore 11026822692 AUTOMATIC WASHER
Kenmore 11026824690 WASHER
Kenmore 11026824691 AUTOMATIC WASHER
Kenmore 11026824692 AUTOMATIC WASHER
Kenmore 11026832690 AUTOMATIC WASHER
Kenmore 11026832691 AUTOMATIC WASHER
Kenmore 11026832692 AUTOMATIC WASHER
Kenmore 11026832694 AUTOMATIC WASHER
Kenmore 11026834690 WASHER
Kenmore 11026834691 AUTOMATIC WASHER
Kenmore 11026834692 AUTOMATIC WASHER
  #2 (permalink)
Old 02-05-2018, 05:20 AM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
Yeah, it's pretty hard to put the gearcase in wrong. You could have a damaged tub/basket. You could have damaged or missing suspension pads or tub suspension pads. Or a misaligned skate plate.
Whirlpool 285744 Tub Suspension Pads - AppliancePartsPros.com
Whirlpool 285219 Suspension Pad Kit - AppliancePartsPros.com
Whirlpool WP3946509 Skate Plate - AppliancePartsPros.com
Posting a video of the problem would be helpful.
  #3 (permalink)
Old 02-05-2018, 06:21 AM
Junior Member
Default
I'll get video today. I'm gonna have to take this thing apart again to check all of that aren't I?
  #4 (permalink)
Old 02-05-2018, 06:39 AM
Junior Member
Default
Disregard. I found that answer.
  #5 (permalink)
Old 02-05-2018, 11:29 AM
Junior Member
Default
https://www.youtube.com/watch?v=lsz88bjdXMs
This video shows about how much my tub is out of balance. It's not walking across the room or anything. The machine in this video isn't my model.
  #6 (permalink)
Old 02-06-2018, 03:14 AM
ThatGuy's Avatar
Expert
APP Volunteer
Default
The machine in the video is a Maytag and it has a spinning transmission. It's a completely different design.
What was the solution?
  #7 (permalink)
Old 02-06-2018, 06:24 AM
Junior Member
Default
I haven't fixed it yet. I know the machine was a different machine than mine. I was only using it to show about how much my machine was wobbling on the spin cycle.
  #8 (permalink)
Old 02-10-2018, 10:16 AM
Junior Member
Default
I've now replaced the suspension pads and suspension pad kit and it still does this. Is this normal? Here's a video I made. If it's not normal, I don't know what else to change.
https://www.youtube.com/watch?v=NYrFYDYHqwc
  #9 (permalink)
Old 02-10-2018, 04:46 PM
ThatGuy's Avatar
Expert
APP Volunteer
Default
That looks pretty normal to me. Can you feel the vibrations in the floor or is it shaking the machine?
The top of the basket is a balance ring and it is half full of fluid. It helps balance the loads, but when they are empty it makes the whole tub and basket go through this kind of vibration pulse that is constantly repeated as long as it spins. Its not enough to be able to notice unless you have the lid open and can see it. I've never timed this pulse, but everyone of these washers has it.
Its very important to level the washer and then lock the front legs. Then I usually tip the washer forward so the rear self leveling legs drop down and set it back. If they are on a good solid floor they run smooth.
  #10 (permalink)
Old 02-10-2018, 08:17 PM
Junior Member
Default
The machine is level. I've checked that. I really only feel the vibration in the machine. I've run a couple of loads and it feels ok to me.
Is there a way to refill the balance ring or does it have to be replaced?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Drum in washer out of balance on spin cycle Lawrence Zielinsky Washer Repair 1 12-01-2012 05:00 PM
Whirlpool Washer Drum Off Balance DeanaM Washer Repair 2 09-05-2011 07:02 AM
GE front load washer smokes and sounds like the drum is off balance!! sbaty Washer Repair 1 01-10-2011 07:43 AM
out of balance washer drum dorman Washer Repair 0 02-01-2009 10:10 AM
Washer Drum out of balance dcophil Washer Repair 1 01-06-2008 10:09 PM
