Discuss
Washer drum out of balance on spin
 in
Washer Repair
No, its half full by design. When the basket stops spinning you can hear the water stop about half a
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer drum out of balance on spin
  #11 (permalink)
Old 02-11-2018, 07:26 AM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
No, its half full by design. When the basket stops spinning you can hear the water stop about half a second later. Its a neat system. Before this most companies used concrete rings and blocks. Some still do.
BTW this balance ring system has been around since the 80's.
  #12 (permalink)
Old 02-11-2018, 07:42 AM
Junior Member
breckrider is on a distinguished road
Default
I'll listen for the swoosh of water. If I don't hear it, I can assume the ring is now empty and needs to be replaced?
  #13 (permalink)
Old 02-11-2018, 11:29 AM
ThatGuy's Avatar
Expert
APP Volunteer
Default
Probably not. It would have to be cracked or have a hole worn in it. The only cracked ones I ever saw had been subjected to temperatures of -10 degrees F. for days.
  #14 (permalink)
Old 02-15-2018, 07:37 AM
ThatGuy's Avatar
Expert
APP Volunteer
Default
I uploaded a video of my washer so you can see the "pulse".
https://www.youtube.com/watch?v=TsrgDGlHIBM
  #15 (permalink)
Old 02-15-2018, 02:09 PM
Junior Member
unie01 is on a distinguished road
Default
interesting thread, I too was having the same problem
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Drum in washer out of balance on spin cycle Lawrence Zielinsky Washer Repair 1 12-01-2012 06:00 PM
Whirlpool Washer Drum Off Balance DeanaM Washer Repair 2 09-05-2011 08:02 AM
GE front load washer smokes and sounds like the drum is off balance!! sbaty Washer Repair 1 01-10-2011 08:43 AM
out of balance washer drum dorman Washer Repair 0 02-01-2009 11:10 AM
Washer Drum out of balance dcophil Washer Repair 1 01-06-2008 11:09 PM
