Discuss
Washer does not flood on small loads, floods on larger loads.
 in
Washer Repair
Last weekend I bought a matching washer/ dryer set for $50. The dryer works great, but the washer floods on
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer does not flood on small loads, floods on larger loads.
  #1 (permalink)
Old 02-04-2018, 10:42 AM
Junior Member
Mimi1964 is on a distinguished road
Default Washer does not flood on small loads, floods on larger loads.
Model Number: LSQ8520JQ0   Brand: Whirlpool   Age: More than 10 years
Last weekend I bought a matching washer/ dryer set for $50. The dryer works great, but the washer floods on any load larger than small. Does anyone have an idea what this could be before we start poking around? I already checked the hoses and it's not that. Thank you so much!
Related Models
Whirlpool LSQ8520JQ0 AUTOMATIC WASHER
Whirlpool LSQ8520JQ1 WASHER
Whirlpool LSQ8543JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ8543JQ1 WASHER
Whirlpool LSQ8543JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ8543JT1 WASHER
Whirlpool LSQ8543JZ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ8543JZ1 WASHER
Whirlpool LSQ9010KQ0 WASHER
Whirlpool LSQ9010KT0 WASHER
Whirlpool LSQ9010LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9010LG1 AUTOMATIC WASHER
Whirlpool LSQ9010LG2 AUTOMATIC WASHER
Whirlpool LSQ9010LG3 AUTOMATIC WASHER
Whirlpool LSQ9010LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9010LQ1 AUTOMATIC WASHER
Whirlpool LSQ9010LQ2 AUTOMATIC WASHER
Whirlpool LSQ9010LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9010LW1 AUTOMATIC WASHER
Whirlpool LSQ9010LW2 AUTOMATIC WASHER
Whirlpool LSQ9010LW3 AUTOMATIC WASHER
Whirlpool LSQ9010PG0 AUTOMATIC WASHER
Whirlpool LSQ9010PG1 AUTOMATIC WASHER
Whirlpool LSQ9010PG2 AUTOMATIC WASHER
Whirlpool LSQ9010PG3 AUTOMATIC WASHER
Whirlpool LSQ9010PG5 AUTOMATIC WASHER
Whirlpool LSQ9010PG6 AUTOMATIC WASHER
Whirlpool LSQ9010PW0 AUTOMATIC WASHER
Whirlpool LSQ9010PW1 AUTOMATIC WASHER
Whirlpool LSQ9010PW2 AUTOMATIC WASHER
Whirlpool LSQ9010PW3 AUTOMATIC WASHER
Whirlpool LSQ9010PW5 AUTOMATIC WASHER
Whirlpool LSQ9010PW6 AUTOMATIC WASHER
Whirlpool LSQ9030PQ0 AUTOMATIC WASHER
Whirlpool LSQ9030PQ1 AUTOMATIC WASHER
Whirlpool LSQ9030PQ2 AUTOMATIC WASHER
Whirlpool LSQ9030PQ4 AUTOMATIC WASHER
Whirlpool LSQ9030PQ5 AUTOMATIC WASHER
Whirlpool LSQ9110KQ0 WASHER
Whirlpool LSQ9110KQ1 WASHER
Whirlpool LSQ9110LG0 WASHER
Whirlpool LSQ9110LG1 AUTOMATIC WASHER
Whirlpool LSQ9110LW0 WASHER
Whirlpool LSQ9110LW1 AUTOMATIC WASHER
Whirlpool LSQ9110PW0 AUTOMATIC WASHER
Whirlpool LSQ9110PW1 AUTOMATIC WASHER
Whirlpool LSQ9110PW2 AUTOMATIC WASHER
Whirlpool LSQ9110PW3 AUTOMATIC WASHER
Whirlpool LSQ9110PW4 AUTOMATIC WASHER
Whirlpool LSQ9200KQ0 WASHER
Whirlpool LSQ9200KT0 WASHER
Whirlpool LSQ9200LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9200LQ1 AUTOMATIC WASHER
Whirlpool LSQ9200LQ2 AUTOMATIC WASHER
Whirlpool LSQ9200LQ3 AUTOMATIC WASHER
Whirlpool LSQ9200LT0 WASHER - DIRECT DRIVE
Whirlpool LSQ9200LT1 AUTOMATIC WASHER
Whirlpool LSQ9200LT2 AUTOMATIC WASHER
Whirlpool LSQ9200LT3 AUTOMATIC WASHER
Whirlpool LSQ9200PQ0 AUTOMATIC WASHER
Whirlpool LSQ9200PQ1 AUTOMATIC WASHER
Whirlpool LSQ9200PQ3 AUTOMATIC WASHER
Whirlpool LSQ9200PQ4 AUTOMATIC WASHER
Whirlpool LSQ9200PT0 AUTOMATIC WASHER
Whirlpool LSQ9200PT1 AUTOMATIC WASHER
Whirlpool LSQ9200PT3 AUTOMATIC WASHER
Whirlpool LSQ9200PT4 AUTOMATIC WASHER
Whirlpool LSQ9210HQ0 AUTOMATIC WASHER
Whirlpool LSQ9210HZ0 AUTOMATIC WASHER
Whirlpool LSQ9211KQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9211KQ1 WASHER - DIRECT DRIVE
Whirlpool LSQ9211KT0 WASHER - DIRECT DRIVE
Whirlpool LSQ9211KT1 WASHER - DIRECT DRIVE
Whirlpool LSQ9244EQ0 AUTOMATIC WASHER
Whirlpool LSQ9244EZ0 AUTOMATIC WASHER
Whirlpool LSQ9264HQ0 AUTOMATIC WASHER
Whirlpool LSQ9264HZ0 AUTOMATIC WASHER
Whirlpool LSQ9500LQ0 WASHER
Whirlpool LSQ9500LT0 WASHER
Whirlpool LSQ9510JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9510JQ1 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9510LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9510LT0 WASHER - DIRECT DRIVE
Whirlpool LSQ9520LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9520LT0 WASHER - DIRECT DRIVE
Whirlpool LSQ9544KQ0 WASHER
Whirlpool LSQ9544KT0 WASHER
Whirlpool LSQ9549LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9549LG1 AUTOMATIC WASHER
Whirlpool LSQ9549LG2 AUTOMATIC WASHER
Whirlpool LSQ9549LG3 AUTOMATIC WASHER
Whirlpool LSQ9549LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9549LQ1 AUTOMATIC WASHER
Whirlpool LSQ9549LQ2 AUTOMATIC WASHER
Whirlpool LSQ9549LQ3 AUTOMATIC WASHER
Whirlpool LSQ9549LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9549LW1 AUTOMATIC WASHER
Whirlpool LSQ9549LW2 AUTOMATIC WASHER
Whirlpool LSQ9549LW3 AUTOMATIC WASHER
Whirlpool LSQ9549PG0 AUTOMATIC WASHER
Whirlpool LSQ9549PG1 AUTOMATIC WASHER
Whirlpool LSQ9549PG2 AUTOMATIC WASHER
Whirlpool LSQ9549PG3 AUTOMATIC WASHER
Whirlpool LSQ9549PG5 AUTOMATIC WASHER
Whirlpool LSQ9549PG6 AUTOMATIC WASHER
Whirlpool LSQ9549PW0 AUTOMATIC WASHER
Whirlpool LSQ9549PW1 AUTOMATIC WASHER
Whirlpool LSQ9549PW2 AUTOMATIC WASHER
Whirlpool LSQ9549PW3 AUTOMATIC WASHER
Whirlpool LSQ9549PW5 AUTOMATIC WASHER
Whirlpool LSQ9549PW6 AUTOMATIC WASHER
Whirlpool LSQ9550PW0 AUTOMATIC WASHER
Whirlpool LSQ9550PW1 AUTOMATIC WASHER
Whirlpool LSQ9550PW2 AUTOMATIC WASHER
Whirlpool LSQ9550PW3 AUTOMATIC WASHER
Whirlpool LSQ9550PW4 AUTOMATIC WASHER
Whirlpool LSQ9560PW0 AUTOMATIC WASHER
Whirlpool LSQ9560PW1 AUTOMATIC WASHER
Whirlpool LSQ9560PW2 Residential Washer
Whirlpool LSQ9560PW3 AUTOMATIC WASHER
  #2 (permalink)
Old 02-05-2018, 06:32 AM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
It might be your pressure switch/water level switch. Or there could be a hole in the tubing to it. Or the pressure dome on the side of tub could be partiality blocked.
It depends on what you mean by overflows. Does the water fill the tub to the top then run over the top?
Whirlpool W10337780 Water Level Switch Kit - AppliancePartsPros.com
  #3 (permalink)
Old 02-05-2018, 11:24 AM
Junior Member
Default
Thank you for your comments. The water actually comes out from the bottom. I know it's coming from the tub because it is soapy. I will have to do an experiment and see if it leaks when it fills or only when it agitates.
  #4 (permalink)
Old 02-06-2018, 11:26 AM
Junior Member
Default
Okay I conducted the experiment...by just filling up the washer, it leaks underneath, before agitation. Does this help to identify the issue? Thanks again!
  #5 (permalink)
Old 02-07-2018, 12:44 AM
ThatGuy's Avatar
Expert
APP Volunteer
Default
There are several places that could be leaking. The pump seal, one of the hoses, the spin tube gasket, the tub gasket, and there could be a hole worn through the tub.
Your going to need to take the shell off and watch as it fills. This video tells how to remove the case. Don't pay any attention to the part. Just watch the first 2 minutes of the video. Make sure the washer is level and solid on the floor. Take out 2 screws and 2 clips and the whole case comes off. Watch out for sharp edges.
Washer Centerpost Gasket (part #W10814296) - How To Replace
  #6 (permalink)
Old 02-11-2018, 11:25 PM
Junior Member
Default
Well we took the washer apart like the video said, and oddly enough it WAS the center seal. After watching the video we decided that was way beyond what we were going to do for this appliance. Thank you so much for helping us figure out what was wrong!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE washer won't drain for large or normal loads. Only very small. joel_m_michael Washer Repair 3 01-10-2012 06:11 AM
Agitates only small loads ricks48038 Washer Repair 1 08-26-2011 02:40 PM
GE Washer No Spin For Larger Loads ACEMANNW Washer Repair 1 04-12-2011 02:01 PM
Larger loads wont properly run thru spin cycle BBSTEVE Washer Repair 0 01-21-2011 12:23 PM
only fills small loads for water jeff n Washer Repair 1 11-16-2010 08:19 AM
