Discuss
LG Washer wm2455hw, spin cycle nothing or grind sound
 in
Washer Repair
LG wm2455hw clothes washer, 9 years old, first problem ever with unit! Low and high speed spin either doesn't spin
Appliance Repair Forum > Appliance Repair Help > Washer Repair » LG Washer wm2455hw, spin cycle nothing or grind sound
  #1 (permalink)
Old 02-03-2018, 11:32 AM
Junior Member
dcbk is on a distinguished road
Unhappy LG Washer wm2455hw, spin cycle nothing or grind sound
Model Number: wm2455hw   Brand: -other-   Age: 5 - 10 years
LG wm2455hw clothes washer, 9 years old, first problem ever with unit! Low and high speed spin either doesn't spin at all with a sound like a faucet is on (not though), or labored grinding sound, for both low and high speed spin (using test mode). If I tip washer back about 6-12 inches, low and high speed spin works fine. Replaced three lower shocks already, and position sensor/hall sensor, neither had an effect. All other functions work fine (lock door, fill hot cold warm, drain etc). Eventually gives an LE error, which is load error (it's empty). which would be consistent with the drum having a hard time turning, either because of something jammed in there (although spins fine when off), or motor trying to turn and can't for whatever reason. Rotor assembly and bearings look and behave fine. Did reset, no change. Wires all seem to be in good shape, no leaks, inside clean. replaced stator motor assembly (the one with copper wires), no change.
Ordered rotor assembly (silver thing with magnets). When spin starts, the motor doesn't turn. I can give the silver stator a push and it runs slowly. Seems like that is the capacitor is dead? Replace control board? Checking voltages coming from control panel....
Update: Replaced Stator motor (copper and silver dish thing), bearings, checked spider which was solid but dirty. Old bearings seemed fine, but replaced anyway. Re-assembled, same problem. Motor either stalls at startup or runs really slow. At this point, I'm in $200 and suspect the control board and capacitor (if cap is dead, won't start drum to get up to speed?). New control board is a few hundred more, so throwing in the towel and getting a new washer. Trying Maytag this time. Wish me luck...hope the above helps someone else avoid the suffering I enjoyed trying to fix this LG washer!
Related Models
 WM2487HRM Washer
 WM2487HRMA Washer
 WM2487HWM Washer
 WM2487HWMA Washer
 WM2496HSM Washer
 WM2496HWM Washer
 WM2677HSM Washer
 WM2688HNM Washer
 WM2688HNMA Washer
 WM2688HWM Washer
 WM2688HWMA Washer
Jenn-Air WM27160B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM27160W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2720B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2720W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM27260B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM27260W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM27460B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM27460W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2750B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2750W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM277B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM277W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2780B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2780W WALLOVEN- S/C MWAVE ELE
 WM2801HLA Washer
 WM2801HRA Washer
 WM2801HWA Washer
 WM3001HPA Washer
 WM3001HRA Washer
 WM3001HWA Washer
Jenn-Air WM30460B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM30460W WALLOVEN- S/C MWAVE ELE
 WM3431HS Washer
 WM3431HW Washer
 WM3632HW Washer
 WM3677HW Washer
 WM3988HWA Washer
Amana WM612 MWAVE- CNTRTP / STAND ALONE
Amana WM614 MWAVE- CNTRTP / STAND ALONE
Amana WM615 MWAVE- CNTRTP / STAND ALONE
Amana WM712 MWAVE- CNTRTP / STAND ALONE
Amana WM714 MWAVE- CNTRTP / STAND ALONE
Amana WM715 MWAVE- CNTRTP / STAND ALONE
General Electric WMCD2050G0WC Washer
General Electric WMCD2050H0WC WASHER
General Electric WMCD2050H1WC WASHER
General Electric WMCD2050H2WC WASHER
General Electric WMCD2050H3WC WASHER
General Electric WMCD2050H4WC WASHER
General Electric WMCD2050H5WC WASHER
General Electric WMCD2050H6WC COIN-OP WASHER
General Electric WMCD2050J0WC COIN-OP WASHER
General Electric WMCD2050J1WC WASHER
Jenn-Air WME3020B WALLOVEN- S/C MWAVE ELE
Jenn-Air WME3020W WALLOVEN- S/C MWAVE ELE
Jenn-Air WMG3020B WALLOVEN- S/C MWAVE GAS
Jenn-Air WMG3020W WALLOVEN- S/C MWAVE GAS
Whirlpool WMH1162XVB0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVB1 Microwave Oven 1.6 Cu. Ft.
Whirlpool WMH1162XVB2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVB3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVB4 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVD0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVD1 Microwave Oven 1.6 Cu. Ft.
Whirlpool WMH1162XVD2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVD3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVD4 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVQ0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVQ1 Microwave Oven 1.6 Cu. Ft.
Whirlpool WMH1162XVQ2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVQ3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVQ4 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVS0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVS1 Microwave Oven 1.6 Cu. Ft.
Whirlpool WMH1162XVS2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVS3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVS4 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVB0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVB1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVB2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVD0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVD1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVD2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVQ0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVQ1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVQ2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVS0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVS1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVS2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVS3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1164XVS0 MICROWAVE OVEN 1.6 Cu. Ft.
Whirlpool WMH1164XVS1 MICROWAVE OVEN 1.6 Cu. Ft.
Whirlpool WMH1164XVS2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1164XVS3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1164XWS0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1164XWS1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1164XWS2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH2175XVB0 Microwave Oven 1.7 Cu. Ft.
Whirlpool WMH2175XVB1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH2175XVB2 MICROWAVE OVEN 1.7 CU. FT.
Whirlpool WMH2175XVQ0 Microwave Oven 1.7 Cu. Ft.
Whirlpool WMH2175XVQ1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH2175XVQ2 MICROWAVE OVEN 1.7 CU. FT.
Whirlpool WMH2175XVS0 Microwave Oven 1.7 Cu. Ft.
Whirlpool WMH2175XVS1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH2175XVS2 MICROWAVE OVEN 1.7 CU. FT.
Whirlpool WMH2175XVT0 Microwave Oven 1.7 Cu. Ft.
Whirlpool WMH2175XVT1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH2175XVT2 MICROWAVE OVEN 1.7 CU. FT.
Whirlpool WMH2205XVB0 Microwave Oven/Hood 2.0 Cu. Ft.
Whirlpool WMH2205XVB1 Microwave Oven/Hood 2.0 Cu. Ft.
Whirlpool WMH2205XVQ0 Microwave Oven/Hood 2.0 Cu. Ft.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer banging sound while in spin cycle avemaria Washer Repair 2 10-01-2014 05:22 PM
Washer wont spin motor runs but ticking sound occurs when on spin cycle D.Wick Washer Repair 1 01-07-2012 09:28 AM
Whirlpool Washer Scraping Sound in Spin Cycle daihatsuboy Washer Repair 1 06-25-2010 01:25 PM
Whirlpool washer grind noise in spin omnitool Washer Repair 1 04-12-2010 11:09 AM
Kenmore 90 srs thump/grind heard when braking down from spin cycle toddly Washer Repair 4 03-02-2008 04:46 AM
