Discuss
Requesting Advice 'Four' Washer Issues...
 in
Washer Repair
Hi there friends.... I was hoping that y'all might be kind enough to assist me in diagnosing some issues I'm
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Requesting Advice 'Four' Washer Issues...
  #1 (permalink)
Old 02-03-2018, 11:29 AM
Junior Member
Mylan is on a distinguished road
Default Requesting Advice 'Four' Washer Issues...
Model Number: WTW5200VQ2   Brand: Whirlpool   Age: 5 - 10 years
Hi there friends.... I was hoping that y'all might be kind enough to assist me in diagnosing some issues I'm having with this Whirlpool WTW5200VQ2 washer... I know it's not the best unit out there but I got it for a steal at Lowes scratch n dent... The thing worked fine at first but a few years ago I started noticing a couple things that I presumed were not proper operating procedure but I guess I was too 'lazy' to investigate and address them... Now all of a sudden I have 4 issues that need attention... The first issue here was the breaking point that made me get off my butt to try and figure out what needed fixing or if it's too far gone and I need to get rid of it...
If it's possible (and not $ dumb) I'd rather fix it due to the hassle of removing and replacing since getting it outside will be a real challenge...... So anyway here I go...
#1: Cold water will not shut off when water level reaches proper level and machine starts agitating.... Turning power off has no effect and water continues flowing until closed at valve... When this problem first started happening in December, the water would shut off a couple seconds after agitation began... That turned into several seconds which soon turned into almost a full minute and now it will not stop at all without main valve action... upon troubleshooting, I determined that if it's on hot only setting, with cold main off, the washer fills, stops, and agitates properly....
My guess would be that the washer's cold fill valve is bad but that guess is just from a couple hours research I did today since I knew absolutely nothing about washing machine internals... I did take the body off the unit and checked the pressure hose which appears in good order.......
#2: A few years back, the washer would occasionally start spinning immediately or within 2 seconds of the commencement of tub draining... At first this rarely happened and when it did happen it would only do so under a very small light load... This started happening more frequently last year and would sometimes occur with a full tub of water although it was still somewhat sporadic.... Now it happens every time on every cycle no matter how heavy the load is...... I have no clue what problem is here.....
#3: A couple years ago, at the end of spin cycle, the tub started occasionally hard stopping... Stopping instantly and with a giant jerking and loud clunk... This still only happens occasionally and usually only with a light load or no load and I cringe every time it happens because I know this cant be good for the machine....
#4: The knob that pulls out to start the washer is connected to the dial (or whatever its called) with 4 little plastic tits- two on each side... one side has somehow broken off and now we must start unit by pulling out only the side of the knob that is still connected which is very annoying and will possibly cause the 'good' side to break off as well... I was thinking about permanently gluing or epoxying it on there but was afraid that doing so might affect or make impossible the later removal of anything on the selector....
woe is me... lol
Seriously though I do apologize for the long rambling post and would greatly appreciate any and all opinions and advice....
btw I'm somewhat old school and don't have any instant mobile notifications like most do these days so it may take a bit for me to get back to the computer to reply to any replies.....
Related Models
Whirlpool WTW5200VQ2 AUTOMATIC WASHER
Whirlpool WTW5300SQ0 AUTOMATIC WASHER
Whirlpool WTW5300SQ2 AUTOMATIC WASHER
Whirlpool WTW5300SQ3 AUTOMATIC WASHER
Whirlpool WTW5300VW0 AUTOMATIC WASHER
Whirlpool WTW5300VW1 AUTOMATIC WASHER
Whirlpool WTW5300VW2 AUTOMATIC WASHER
Whirlpool WTW5300VW3 AUTOMATIC WASHER
Whirlpool WTW5310SQ0 AUTOMATIC WASHER
Whirlpool WTW5310VQ0 AUTOMATIC WASHER
Whirlpool WTW5320SQ0 AUTOMATIC WASHER
Whirlpool WTW5321SQ0 AUTOMATIC WASHER
Whirlpool WTW5400TQ0 AUTOMATIC WASHER
Whirlpool WTW5500SQ0 AUTOMATIC WASHER
Whirlpool WTW5500SQ2 AUTOMATIC WASHER
Whirlpool WTW5500ST0 AUTOMATIC WASHER
Whirlpool WTW5500ST2 AUTOMATIC WASHER
Whirlpool WTW5500XL0 AUTOMATIC WASHER
Whirlpool WTW5500XL1 AUTOMATIC WASHER
Whirlpool WTW5500XL2 WASHER
Whirlpool WTW5500XW0 AUTOMATIC WASHER
Whirlpool WTW5500XW1 AUTOMATIC WASHER
Whirlpool WTW5500XW2 WASHER
Whirlpool WTW5505SQ0 AUTOMATIC WASHER
Whirlpool WTW5505SQ1 AUTOMATIC WASHER
Whirlpool WTW5505VQ0 AUTOMATIC WASHER
Whirlpool WTW5505VQ1 AUTOMATIC WASHER
Whirlpool WTW5510VQ0 AUTOMATIC WASHER
Whirlpool WTW5520SQ0 AUTOMATIC WASHER
Whirlpool WTW5521SQ0 AUTOMATIC WASHER
Whirlpool WTW5530SQ0 AUTOMATIC WASHER
Whirlpool WTW5540SQ0 AUTOMATIC WASHER
Whirlpool WTW5540ST0 AUTOMATIC WASHER
Whirlpool WTW5550SQ0 AUTOMATIC WASHER
Whirlpool WTW5550ST0 AUTOMATIC WASHER
Whirlpool WTW5550XW0 AUTOMATIC WASHER
Whirlpool WTW5550XW1 AUTOMATIC WASHER
Whirlpool WTW5550XW2 WASHER
Whirlpool WTW5560SQ0 AUTOMATIC WASHER
Whirlpool WTW5590SQ0 AUTOMATIC WASHER
Whirlpool WTW5590SQ2 AUTOMATIC WASHER
Whirlpool WTW5590ST0 AUTOMATIC WASHER
Whirlpool WTW5590ST2 AUTOMATIC WASHER
Whirlpool WTW5590VQ0 AUTOMATIC WASHER
Whirlpool WTW5590VQ1 AUTOMATIC WASHER
Whirlpool WTW5600SQ0 AUTOMATIC WASHER
Whirlpool WTW5600VQ0 AUTOMATIC WASHER
Whirlpool WTW5600XW0 AUTOMATIC WASHER
Whirlpool WTW5600XW1 AUTOMATIC WASHER
Whirlpool WTW5600XW2 WASHER
Whirlpool WTW5610XW0 AUTOMATIC WASHER
Whirlpool WTW5610XW1 AUTOMATIC WASHER
Whirlpool WTW5610XW2 WASHER
Whirlpool WTW5640XW0 AUTOMATIC WASHER
Whirlpool WTW5640XW1 AUTOMATIC WASHER
Whirlpool WTW5640XW2 WASHER
Whirlpool WTW5700SW0 AUTOMATIC WASHER
Whirlpool WTW5700XL0 AUTOMATIC WASHER
Whirlpool WTW5700XL1 AUTOMATIC WASHER
Whirlpool WTW5700XL2 WASHER
Whirlpool WTW5700XW0 AUTOMATIC WASHER
Whirlpool WTW5700XW1 AUTOMATIC WASHER
Whirlpool WTW5700XW2 WASHER
Whirlpool WTW5790SQ0 AUTOMATIC WASHER
Whirlpool WTW5790SQ2 AUTOMATIC WASHER
Whirlpool WTW5790ST0 AUTOMATIC WASHER
Whirlpool WTW5790ST2 AUTOMATIC WASHER
Whirlpool WTW5790VQ0 AUTOMATIC WASHER
Whirlpool WTW5790VQ1 AUTOMATIC WASHER
Whirlpool WTW5790VQ2 AUTOMATIC WASHER
Whirlpool WTW57ESVH0 AUTOMATIC WASHER
Whirlpool WTW57ESVH1 AUTOMATIC WASHER
Whirlpool WTW57ESVW0 AUTOMATIC WASHER
Whirlpool WTW57ESVW1 AUTOMATIC WASHER
Whirlpool WTW5800SG0 AUTOMATIC WASHER
Whirlpool WTW5800SW0 AUTOMATIC WASHER
Whirlpool WTW5810SW0 AUTOMATIC WASHER
Whirlpool WTW5820SW0 AUTOMATIC WASHER
Whirlpool WTW5821SW0 AUTOMATIC WASHER
Whirlpool WTW5830SW0 AUTOMATIC WASHER
Whirlpool WTW5840SG0 AUTOMATIC WASHER
Whirlpool WTW5840SW0 AUTOMATIC WASHER
Whirlpool WTW5850SG0 AUTOMATIC WASHER
Whirlpool WTW5850SW0 AUTOMATIC WASHER
Whirlpool WTW5860SG0 AUTOMATIC WASHER
Whirlpool WTW5860SW0 AUTOMATIC WASHER
Whirlpool WTW58ESVW0 AUTOMATIC WASHER
Whirlpool WTW58ESVW1 AUTOMATIC WASHER
Whirlpool WTW5900SB0 AUTOMATIC WASHER
Whirlpool WTW5900SW0 AUTOMATIC WASHER
Whirlpool WTW5900TB0 AUTOMATIC WASHER
Whirlpool WTW5900TW0 AUTOMATIC WASHER
Whirlpool WTW6200SW0 AUTOMATIC WASHER
Whirlpool WTW6200SW1 AUTOMATIC WASHER
Whirlpool WTW6200SW2 AUTOMATIC WASHER
Whirlpool WTW6200SW3 AUTOMATIC WASHER
Whirlpool WTW6200VW0 AUTOMATIC WASHER
Whirlpool WTW6200VW1 AUTOMATIC WASHER
Whirlpool WTW6300SB0 AUTOMATIC WASHER
Whirlpool WTW6300SB1 AUTOMATIC WASHER
Whirlpool WTW6300SB2 AUTOMATIC WASHER
Whirlpool WTW6300SG0 AUTOMATIC WASHER
Whirlpool WTW6300SG1 AUTOMATIC WASHER
Whirlpool WTW6300SG2 AUTOMATIC WASHER
Whirlpool WTW6300SW0 AUTOMATIC WASHER
Whirlpool WTW6300SW1 AUTOMATIC WASHER
Whirlpool WTW6300SW2 AUTOMATIC WASHER
Whirlpool WTW6300WW0 AUTOMATIC WASHER
Whirlpool WTW6340WW0 AUTOMATIC WASHER
Whirlpool WTW6400SW0 AUTOMATIC WASHER
Whirlpool WTW6400SW1 AUTOMATIC WASHER
Whirlpool WTW6400SW2 AUTOMATIC WASHER
Whirlpool WTW6400SW3 AUTOMATIC WASHER
Whirlpool WTW6500WW1 AUTOMATIC WASHER
Whirlpool WTW6600SB0 AUTOMATIC WASHER
Whirlpool WTW6600SB1 AUTOMATIC WASHER
Whirlpool WTW6600SB2 AUTOMATIC WASHER
Whirlpool WTW6600SB3 AUTOMATIC WASHER
Whirlpool WTW6600SG0 AUTOMATIC WASHER
Whirlpool WTW6600SG1 AUTOMATIC WASHER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Requesting help identifying gasket Sonics Dishwasher Repair 0 11-13-2016 07:36 AM
Requesting service manual crunchtime2k Dishwasher Repair 0 11-10-2014 04:10 AM
Whirlpool Side By Side Cooling Issues Need Advice....... CaptainWarmFridge Refrigerator & Freezer Repair 6 07-07-2014 01:42 AM
Requesting help with a GE igniter replacement cfbeebe Oven Repair (including Ranges and Cooktops) 15 02-24-2011 02:08 PM
