Discuss
Whirlpool Duet Sport washer drains intermittently
 in
Washer Repair
My clothes washer seems to be draining erratically. Let me first explain that I thoroughly cleaned the entire drain system
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool Duet Sport washer drains intermittently
  #1 (permalink)
Old 01-27-2018, 09:45 AM
Junior Member
Paul_Iwema is on a distinguished road
Default Whirlpool Duet Sport washer drains intermittently
Model Number: WFW8300SW02   Brand: -brand-   Age: Less than 1 year
My clothes washer seems to be draining erratically. Let me first explain that I thoroughly cleaned the entire drain system with household vinegar including the boot at the bottom of the tub, drain ball. pressure sending unit, debris filter, pump and motor assembly, and discharge hose. After reassembling the drain system, I ran the washer through two "Clean Washer" cycles: the first with bleach, as directed, and the second with half a gallon of vinegar.
The machine performed both clean cycles perfectly. I am convinced the machine is suds free.
Now the troubles begin. I first ran a "Drain and Spin" load with clean, but wet socks and tee shirts, it was competed in the 15 minutes. Then, with the same small amount of suds free clothes, I ran the "Rinse and Spin" cycle with no fabric softener. At the 16 minutes remaining mark it failed to drain completely and gave a single F21 error code. Having unplugged the unit and opening the drain at the bottom, I ran the clean cycle again with water only. Finally, I put the same wet clothes through a "Normal/Casual" cycle without detergent or other additives. It ran well and on time until the 36 minutes remaining mark, where it tried to drain, stopped with a SD error code and filled up a little, and repeated the SD error code and fill once more. It all ended with another F21 error code.
I am baffled. Could it still be a pump problem? The impellers are not damaged and turn freely when bench tested. Is it the sensor unit itself?
I felt it necessary to give all the details in this lengthy post in order to receive an intelligent response. Does anyone have an idea what is going on?
Related Models
Whirlpool WFW8300SW02 AUTOMATIC WASHER
Whirlpool WFW8300SW03 AUTOMATIC WASHER
Whirlpool WFW8300SW04 AUTOMATIC WASHER
Whirlpool WFW8300SW05 AUTOMATIC WASHER
Whirlpool WFW8300SW1 AUTOMATIC WASHER
Whirlpool WFW8400TB00 AUTOMATIC WASHER
Whirlpool WFW8400TB01 AUTOMATIC WASHER
Whirlpool WFW8400TB02 AUTOMATIC WASHER
Whirlpool WFW8400TE00 AUTOMATIC WASHER
Whirlpool WFW8400TE01 AUTOMATIC WASHER
Whirlpool WFW8400TW00 AUTOMATIC WASHER
Whirlpool WFW8400TW01 AUTOMATIC WASHER
Whirlpool WFW8400TW02 AUTOMATIC WASHER
Whirlpool WFW8400TW03 AUTOMATIC WASHER
Whirlpool WFW8410SW0 AUTOMATIC WASHER
Whirlpool WFW8410SW01 AUTOMATIC WASHER
Whirlpool WFW8410SW02 AUTOMATIC WASHER
Whirlpool WFW8410SW03 AUTOMATIC WASHER
Whirlpool WFW8500SR0 AUTOMATIC WASHER
Whirlpool WFW8500SR01 AUTOMATIC WASHER
Whirlpool WFW8500SR02 AUTOMATIC WASHER
Whirlpool WFW8500SR03 AUTOMATIC WASHER
Whirlpool WFW8500SR04 AUTOMATIC WASHER
Whirlpool WFW9050XW00 AUTOMATIC WASHER
Whirlpool WFW9050XW01 AUTOMATIC WASHER
Whirlpool WFW9050XW02 AUTOMATIC WASHER
Whirlpool WFW9050XW03 AUTOMATIC WASHER
Whirlpool WFW9150WW00 AUTOMATIC WASHER
Whirlpool WFW9150WW01 AUTOMATIC WASHER
Whirlpool WFW9150WW02 AUTOMATIC WASHER
Whirlpool WFW9151YW00 WASHER
Whirlpool WFW9200SQ00 AUTOMATIC WASHER
Whirlpool WFW9200SQ01 AUTOMATIC WASHER
Whirlpool WFW9200SQ02 AUTOMATIC WASHER
Whirlpool WFW9200SQ03 AUTOMATIC WASHER
Whirlpool WFW9200SQ04 AUTOMATIC WASHER
Whirlpool WFW9200SQ10 AUTOMATIC WASHER
Whirlpool WFW9200SQA10 AUTOMATIC WASHER
Whirlpool WFW9200SQA11 AUTOMATIC WASHER
Whirlpool WFW9200SQA12 AUTOMATIC WASHER
Whirlpool WFW9250WL00 AUTOMATIC WASHER
Whirlpool WFW9250WL01 AUTOMATIC WASHER
Whirlpool WFW9250WL02 AUTOMATIC WASHER
Whirlpool WFW9250WR00 AUTOMATIC WASHER
Whirlpool WFW9250WR01 AUTOMATIC WASHER
Whirlpool WFW9250WR02 AUTOMATIC WASHER
Whirlpool WFW9250WW00 AUTOMATIC WASHER
Whirlpool WFW9250WW01 AUTOMATIC WASHER
Whirlpool WFW9250WW02 WASHER
Whirlpool WFW9300VU02 AUTOMATIC WASHER
Whirlpool WFW9300VU03 AUTOMATIC WASHER
Whirlpool WFW9300VU04 AUTOMATIC WASHER
Whirlpool WFW9351YL00 AUTOMATIC WASHER
Whirlpool WFW9351YW00 AUTOMATIC WASHER
Whirlpool WFW9400SB00 AUTOMATIC WASHER
Whirlpool WFW9400SB01 AUTOMATIC WASHER
Whirlpool WFW9400SB02 AUTOMATIC WASHER
Whirlpool WFW9400SBA10 AUTOMATIC WASHER
Whirlpool WFW9400ST00 AUTOMATIC WASHER
Whirlpool WFW9400ST01 AUTOMATIC WASHER
Whirlpool WFW9400ST02 AUTOMATIC WASHER
Whirlpool WFW9400STA10 AUTOMATIC WASHER
Whirlpool WFW9400SU00 AUTOMATIC WASHER
Whirlpool WFW9400SU01 AUTOMATIC WASHER
Whirlpool WFW9400SU02 AUTOMATIC WASHER
Whirlpool WFW9400SW00 AUTOMATIC WASHER
Whirlpool WFW9400SW01 AUTOMATIC WASHER
Whirlpool WFW9400SW02 AUTOMATIC WASHER
Whirlpool WFW9400SW03 AUTOMATIC WASHER
Whirlpool WFW9400SW04 AUTOMATIC WASHER
Whirlpool WFW9400SWA10 AUTOMATIC WASHER
Whirlpool WFW9400SZ00 AUTOMATIC WASHER
Whirlpool WFW9400SZ01 AUTOMATIC WASHER
Whirlpool WFW9400SZ02 AUTOMATIC WASHER
Whirlpool WFW9400SZ03 AUTOMATIC WASHER
Whirlpool WFW9400SZ04 AUTOMATIC WASHER
Whirlpool WFW9400SZA10 AUTOMATIC WASHER
Whirlpool WFW9400VE01 AUTOMATIC WASHER
Whirlpool WFW9400VE02 AUTOMATIC WASHER
Whirlpool WFW9400VE03 AUTOMATIC WASHER
Whirlpool WFW9410XW00 WASHER
Whirlpool WFW9450WL00 AUTOMATIC WASHER
Whirlpool WFW9450WR00 AUTOMATIC WASHER
Whirlpool WFW9450WW00 AUTOMATIC WASHER
Whirlpool WFW9451XW00 AUTOMATIC WASHER
Whirlpool WFW9470WL00 AUTOMATIC WASHER
Whirlpool WFW9470WL01 AUTOMATIC WASHER
Whirlpool WFW9470WR00 AUTOMATIC WASHER
Whirlpool WFW9470WR01 AUTOMATIC WASHER
Whirlpool WFW9470WW00 AUTOMATIC WASHER
Whirlpool WFW9470WW01 AUTOMATIC WASHER
Whirlpool WFW94HEXL0 WASHER
Whirlpool WFW94HEXL1 AUTOMATIC WASHER
Whirlpool WFW94HEXL2 AUTOMATIC WASHER
Whirlpool WFW94HEXR0 WASHER
Whirlpool WFW94HEXR1 AUTOMATIC WASHER
Whirlpool WFW94HEXR2 AUTOMATIC WASHER
Whirlpool WFW94HEXW0 WASHER
Whirlpool WFW94HEXW1 AUTOMATIC WASHER
Whirlpool WFW94HEXW2 AUTOMATIC WASHER
Whirlpool WFW9500TC00 AUTOMATIC WASHER
Whirlpool WFW9500TC01 AUTOMATIC WASHER
Whirlpool WFW9500TC02 AUTOMATIC WASHER
Whirlpool WFW9500TC03 AUTOMATIC WASHER
Whirlpool WFW9500TW00 AUTOMATIC WASHER
Whirlpool WFW9500TW01 AUTOMATIC WASHER
Whirlpool WFW9500TW02 AUTOMATIC WASHER
Whirlpool WFW9500TW03 AUTOMATIC WASHER
Whirlpool WFW9550WL00 AUTOMATIC WASHER
Whirlpool WFW9550WL01 AUTOMATIC WASHER
Whirlpool WFW9550WL10 AUTOMATIC WASHER
Whirlpool WFW9550WR00 AUTOMATIC WASHER
Whirlpool WFW9550WR01 AUTOMATIC WASHER
Whirlpool WFW9550WW00 AUTOMATIC WASHER
Whirlpool WFW9550WW01 AUTOMATIC WASHER
Whirlpool WFW9550WW10 AUTOMATIC WASHER
Whirlpool WFW95HEXL0 WASHER
Whirlpool WFW95HEXL1 AUTOMATIC WASHER
Whirlpool WFW95HEXL2 AUTOMATIC WASHER
Whirlpool WFW95HEXR0 WASHER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Duet Sport Washer F-21 bradlawson Washer Repair 1 04-17-2014 04:25 PM
Whirlpool Washer Sport Duet montanez_alex Washer Repair 1 05-14-2013 04:12 PM
Whirlpool duet sport washer jomarshall Washer Repair 1 09-30-2011 06:37 PM
Whirlpool Duet Sport Washer tonyarayburn Refrigerator & Freezer Repair 3 08-22-2011 06:39 AM
whirlpool duet sport washer sheryl luker Washer Repair 1 09-03-2009 08:10 PM
