Discuss
E41 error, just want to confirm latch before buying
 in
Washer Repair
Thanks in advance! Washer not entering high speed spin, has code e41. I have tested resistance of wax motor, 1380,
Appliance Repair Forum > Appliance Repair Help > Washer Repair » E41 error, just want to confirm latch before buying
  #1 (permalink)
Old 01-25-2018, 04:59 PM
Junior Member
tpoynton is on a distinguished road
Default E41 error, just want to confirm latch before buying
Model Number: gltf2940fs1   Brand: Frigidaire   Age: More than 10 years
Thanks in advance!
I have tested resistance of wax motor, 1380, and checked to see if drain was plugged, both check out. Checked j2 black wire again other wire in plug and circuit was open. Striker looks fine, and door locks and I can not open. Everything seems to point to door latch, but I wanted to check before buying. I I
Opened up the latch assembly and a little spring was floating around in there, and I found a video showing where it went and put it back in place, but I still get the error. Ran through diagnostic cycle too, and high speed spin works there. Would you agree that the door latch is most likely culprit, and it is not as likely to be control board? Thanks again!
Related Models
Frigidaire GLTF2940FS1 WASHER
Frigidaire GLTF2940FS2 WASHER
Frigidaire GLTF530DS0 Frigidaire/washer
Frigidaire GLTF530DS1 Frigidaire/washer
Frigidaire GLTR1670AS0 Frtld Wshr - Frigidaire Gallery
Frigidaire GLTR1670AS1 Frigidaire/washer
Frigidaire GLTR1670FS0 WASHER
Frigidaire GLTR1670FS1 WASHER
General Electric GLWN5050M0WS WASHER
General Electric GLWP2000M0WW WASHER
General Electric GLWP2000M1WW WASHER
Frigidaire GLWS1233AQ1 Washer - Frig Gallery
Frigidaire GLWS1233AQ2 Frigidaire/washer
Frigidaire GLWS1233AS0 Washer - Frigidaire Gallery
Frigidaire GLWS1233AS1 Washer - Gallery
Frigidaire GLWS1233AS2 Frigidaire/washer
Frigidaire GLWS1233AS3 Frigidaire/washer
Frigidaire GLWS1339CC0 Frigidaire/washer
Frigidaire GLWS1339CS0 Frigidaire/washer
Frigidaire GLWS1339CS1 Frigidaire/washer
Frigidaire GLWS1339EC0 Frigidaire/washer
Frigidaire GLWS1339EC1 Frigidaire/washer
Frigidaire GLWS1339ES0 Frigidaire/washer
Frigidaire GLWS1339ES1 Frigidaire/washer
Frigidaire GLWS1349AS0 Washer - Frigidaire Gallery
Frigidaire GLWS1349AS1 Washer - Frig Gallery
Frigidaire GLWS1439FC0 WASHER
Frigidaire GLWS1439FC1 WASHER
Frigidaire GLWS1439FC2 WASHER
Frigidaire GLWS1439FS0 WASHER
Frigidaire GLWS1439FS1 WASHER
Frigidaire GLWS1439FS2 WASHER
Frigidaire GLWS1649AS0 Washer - Frig Gallery
Frigidaire GLWS1649AS1 Washer - Frig Gallery
Frigidaire GLWS1649AS2 Frigidaire/washer
Frigidaire GLWS1649AS4 Frigidaire/washer
Frigidaire GLWS1749AS0 Washer - Frigidaire Gallery
Frigidaire GLWS1749AS2 Washer - Frig Gallery
Frigidaire GLWS1749AS4 Frigidaire/washer
Frigidaire GLWS1749AS5 Frigidaire/washer
Frigidaire GLWS1749FS0 WASHER
Frigidaire GLWS1749FS1 WASHER
Frigidaire GLWS1749FS2 WASHER
Frigidaire GLWS1939AS0 Frigidaire/washer
Frigidaire GLWS1939AS1 Frigidaire/washer
Frigidaire GLWS1979AS0 Washer - Frigidaire Gallery
Frigidaire GLWS1979AS2 Washer - Frig Gallery
Frigidaire GLWS1979AS3 Frigidaire/washer
Frigidaire GLWY1343AS0 Frigidaire/washer
Frigidaire GLWY1343AS1 Frigidaire/washer
Gaggenau GM104-710
Gaggenau GM104-714
Admiral GM1110PRW RANGE- F/S STD GAS
Gaggenau GM215-721
Gaggenau GM215-760
Gaggenau GM215-761
Gaggenau GM286-710
Gaggenau GM286-720
Gaggenau GM286-760
Gaggenau GM288-710
Gaggenau GM288-714
Admiral GM3110MPAW RANGE- F/S STD GAS
Admiral GM3110MXAW RANGE- F/S STD GAS
Admiral GM3110PRAM RANGE- F/S STD GAS
Admiral GM3110PRWM RANGE- F/S STD GAS
Admiral GM31113WAM RANGE- F/S STD GAS
Admiral GM31113WAV RANGE- F/S STD GAS
Admiral GM3111GXAW RANGE- F/S STD GAS
Admiral GM3111SXAW RANGE- F/S STD GAS
Admiral GM31211XAW RANGE- F/S STD GAS
Admiral GM3167WUA RANGE- F/S STD GAS
Admiral GM3167WUV RANGE- F/S STD GAS
Admiral GM3210MXAW RANGE-F/S CONT CLEAN GAS
Admiral GM3211GXAA RANGE-F/S CONT CLEAN GAS
Admiral GM3211GXAW RANGE-F/S CONT CLEAN GAS
Admiral GM3211SXAA RANGE-F/S CONT CLEAN GAS
Admiral GM3211SXAW RANGE-F/S CONT CLEAN GAS
Admiral GM3216WRWM RANGE-F/S CONT CLEAN GAS
Admiral GM32211XAW RANGE-F/S CONT CLEAN GAS
Admiral GM3267WUAM RANGE-F/S CONT CLEAN GAS
Admiral GM3267WUWM RANGE-F/S CONT CLEAN GAS
Admiral GM3267XUA RANGE-F/S CONT CLEAN GAS
Admiral GM3267XUAM RANGE-F/S CONT CLEAN GAS
Admiral GM3267XUW RANGE-F/S CONT CLEAN GAS
Admiral GM3267XUWM RANGE-F/S CONT CLEAN GAS
Gaggenau GM335-760
Maytag GM3468XUW-X RANGE- S/C F/S GAS
Admiral GM3510PRW RANGE- F/S STD ELE
Admiral GM3531WUV RANGE- S/C F/S ELE
Admiral GM3531WUW RANGE- S/C F/S ELE
Admiral GM3631XUA RANGE- F/S STD ELE
Admiral GM3631XUW RANGE- F/S STD ELE
Admiral GM3862XUW RANGE- S/C F/S ELE
Admiral GM3868XUA RANGE- S/C F/S ELE
Admiral GM3868XUW RANGE- S/C F/S ELE
Maytag GM4151WTA RANGE- F/S STD GAS
Maytag GM4151WTW RANGE- F/S STD GAS
Maytag GM4251WTA RANGE-F/S CONT CLEAN GAS
Maytag GM4251WTW RANGE-F/S CONT CLEAN GAS
Whirlpool GM8131XEB0 CONVECTION MICROWAVE OVEN
Whirlpool GM8131XEB1 MICROWAVE
Whirlpool GM8131XEQ0 CONVECTION MICROWAVE OVEN
Whirlpool GM8131XEQ1 MICROWAVE
Whirlpool GM8155XJB0 MICROWAVE-COUNTERTOP
Whirlpool GM8155XJB1 CONVECTION MICROWAVE OVEN
Whirlpool GM8155XJB2 CONVECTION MICROWAVE OVEN
Whirlpool GM8155XJQ0 MICROWAVE-COUNTERTOP
Whirlpool GM8155XJQ1 CONVECTION MICROWAVE OVEN
Whirlpool GM8155XJQ2 CONVECTION MICROWAVE OVEN
Whirlpool GM8155XJT0 MICROWAVE
Whirlpool GM8155XJT1 CONVECTION MICROWAVE OVEN
Whirlpool GM8155XJT2 CONVECTION MICROWAVE OVEN
Gaggenau GM915-710 UC/06 (FD 7710-7912)
Gaggenau GM915-710 UC/11 (FD 7912-8003)
Gaggenau GM915-710 UC/12 (FD 8003-)
Gaggenau GM926-710 UC/06 (FD 7710-7912)
Gaggenau GM926-710 UC/11 (FD 7912-8003)
Gaggenau GM926-710 UC/12 (FD 8003-)
General Electric GMAN1200L2WW WASHER
General Electric GMAN3000M0WS WASHER
  #2 (permalink)
Old 01-28-2018, 05:51 PM
Junior Member
Default
An update, replaced door lock mechanism, worked for a few loads, but now it is back with e41
  #3 (permalink)
Old 02-02-2018, 01:13 PM
Junior Member
Default final update
Final update on this...appreciate all the input
the error comes back when there is a very small load in the washer, so it is probably something else and I now have an extra door latch assembly. Can either not do small loads or just spin it out in diagnostic mode.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Door Latch error codes but latch is working mykhalz@gmail.com Washer Repair 0 06-27-2017 01:07 PM
F22 error/door won't latch/start tman5711 Washer Repair 0 06-24-2013 01:42 AM
f9 door latch error jean vinet Oven Repair (including Ranges and Cooktops) 0 01-02-2012 01:09 PM
Amana oven F9 error- bad latch richappy Oven Repair (including Ranges and Cooktops) 0 12-29-2009 04:53 PM
Door latch error code KEVMC Oven Repair (including Ranges and Cooktops) 0 12-26-2008 06:52 PM
